Question about Mitsubishi VS-5043 50" Rear Projection Television
More info about my 1995 mitsubishi tv
I have a few more details about my 1995 Mitsubishi bigscreen tv- I originally said it was a 1994-but it is a 1995 Model #VS4551, 45 inch, PIP, surround sound, projection tv. I am the original owner-this has been a wonderful tv, it has been moved many times, but it has kept going really well, and I would love for this problem to be fixed. It is still a great tv. It is just now, no power. please help if you can. thanks.
    Top Expert:
  • Mitsubishi Master
  • 49,934 Answers
There could be an open internal fuse or power supply failure.
Posted on Jul 13, 2017
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Posted on Jun 16, 2006
  • 3 Answers
SOURCE: mitsubishi vs 50607
CHeck 9 V circuit.. Change caps C2p04 & 5.. 100uf 16V & 47uf 50V..Both electrolytics....Directly behind shield on Signal PCB..
Posted on Nov 24, 2007
SOURCE: mitsubishi model vs-5043
I just had this same exact problem. I looked for an answer on here and could not find one. So I took the back off, vacuumed and cleaned everything out with the hose on my house vacuum, cleaned the bulbs and wiggled them around some. Voila !!!! lights on and all is working fine and better then ever. I hope this helps someone fix their problem. Just saved me tons of money and a morning of hassle.
Posted on May 06, 2008
stonephoenix
  • 563 Answers
SOURCE: I have a Mitsubishi hd 1080 series 60 inch model # vs-60111
G'Day!
What you're describing is a repair issue. Unfortunately, there is nothing you can do through troubleshooting to correct that problem. There is an internal part that has to be replaced. If you're under warranty or have an extended service plan, the repair will cost you nothing.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need further assistance so that I can help you further.
Posted on Jul 11, 2009
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi Bigscreen WS-65869 the power went off
This information applies to Mitsubishi sets that have a Model number beginning with VS, WS, WT etc. It does not apply to the WD series of sets made later.
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver.
There are sites on the internet selling a "kit" with the caps etc and instructions for replacing them---if they are bad the silver tops of them will be bulged up and not flat.
Let me know what more information you need--I am here to help.
If this information has helped you rate it as I do this here for free.
SD TECH
Posted on Dec 10, 2009
WHAT CAR WILL INERCHANGE WITH 94 GEO METRO FOR SPARE TIRE
These are the same bolt patterns, bolt pattern is 4 X 4.5 or also known as 4 X 114MM. Measure 2 lugholes across from each other and it should measure 4 1/2" US or 114MM. the center hubs may be smaller/larger. Check the center hub size before purchasing:
1997 Acura- CL 16 x 6 (5 straight spokes)
1998 Acura- CL 16 x 6 (5 dual straight spokes)
1998 Acura- CL 16 x 6 (7 straight spokes
1990-89 Acura- Legend 15 x 5.5
1996-95 Acura- TL 15 x 6 (5 straight spokes with groove)
1997-98 Acura- TL 15 x 6 (11 straight spokes)
1994-92 Acura- Vigor 15 x 6 (11 triangular slots)
1999-98 Chevrolet- Metro
1989-85 Chevrolet- Sprint
1991 Dodge- Colt Vista 13 x 5 (15 slots)
1993-92 Dodge- Colt Vista 14 x 5.5 (5 straight spokes)
1992-84 Eagle- Summit/Summit Wagon
1992-91 Eagle- Summit 13 x 5 (15 slots)
1993-88 Ford- Festiva 12 x 4 40mm offset
1993-91 Ford- Festiva 12 x 4.5 40mm offset (8 elongated triangle slots)
1997-89 Geo- Metro
1999-92 Honda- Prelude
1999-90 Honda- Accord (4 cylinder models)
1999-91 Hyundai- Elantra
1995-92 Hyundai- Elantra 14 x 6 (16 slots)
1995-92 Hyundai- Elantra 14 x 5.5 (7 curved spokes)
1998-96 Hyundai- Elantra 14 x 5.5 (5 straight spokes)
1999-90 Hyundai- Accent/Excel/Pony
1994-92 Hyundai- Excel 13 x 5
1991 Hyundai- Sonata 15 x 6 (18 rectangular slots)
1994-92 Hyundai- Sonata 15 x 6 (9 triangular slots)
1996-95 Hyundai- Sonata 15 x 6 (9 straight spokes)
1997-95 Hyundai- Sonata 15 x 6 (5 twisted spokes)
1998-97 Hyundai- Sonata 15 x 6 (5 straight single groove spokes)
1995-90 Hyundai- Scoupe
1992-91 Hyundai- Scoupe 14 x 5 (6 curved spokes)
1995-93 Hyundai- Scoupe 14 x 5 (5 curved spokes)
1998-97 Hyundai- Tiburon 15 x 6 (5 twisted spokes)
1998-97 Hyundai- Tiburon 15 x 6 (5 raised straight spokes)
1989-81 Mazda- 323/GLC
1985-84 Mazda- RX7 GSL-SE 14 x 5.5 40mm offset
1991-86 Mazda- RX7 14 x 5.5 40mm offset
1987-85 Mazda- 626/MX-6
1994-91 Mercury- Capri 14 x 5.5 45mm offset (16 holes)
1994-91 Mercury- Capri 15 x 6 45mm offset (3 curved spokes
1994-91 Mercury- Topaz 14 x 5.5 (16 holes)
1998-92 Mitsubishi- Expo/Expo LRV/Vista Wagon
1994-92 Mitsubishi- Expo 14 x 5.5 (5 straight spokes)
1999-84 Mitsubishi- Galant
1991 Mitsubishi- Galant 14 x 5.5 (18 slots)
1991 Mitsubishi- Galant 15 x 6 (8 straight spokes)
1991 Mitsubishi- Galant 15 x 6 (5 straight spokes)
1993-91 Mitsubishi- Galant 14 x 5.5 (15 slanted spokes)
1992 Mitsubishi- Galant 15 x 6 (5 straight spokes)
1993 Mitsubishi- Galant 15 x 6 (8 triangular and 8 rectangular slots)
1993-84 Mitsubishi- Mirage
1993-91 Mitsubishi- 2000GTX 14 x 5.5 (18 slots)
1991-80 Mitsubishi- Tredia
1999-93 Nissan- Altima
1995-82 Nissan- Stanza
1991-84 Nissan- Maxima
1990-78 Nissan- B310/Pulsar
1989-94 Nissan 240sx
1989-94 Nissan Silvia
1986-82 Nissan- Sentra
1993-84 Plymouth- Colt
1985-79 Plymouth- Arrow/Champ
1999-89 Suzuki- Swift
1991-80 Toyota- Cressida
1985-80 Toyota- Celica
Oct 30, 2017 | Geo Cars & Trucks
Black screen
Sounds like you need to replace the lamp. An original Mitsubishi lamp will last 7 to 10000 hours. It's a no brainer to replace. Buy the lamp from Mitsubishi or a dealer. Do not buy one over the internet. Those are awful...
Dec 31, 2013 | Mitsubishi Televison & Video
1995 Mitsubishi 20" TV/VCR combo TV
What is the problem you faces with this Como? Provide more details please.
Jan 03, 2013 | Mitsubishi Televison & Video
60'' Mitsubishi bigscreen will not power up
this could be a lamp our a ballast issue
regards
Dec 12, 2009 | Televison & Video
Estimated Weight
Direct quote from 2001 Mitsubishi Product Catalog Specs. Gold Series
VS-70707
Weight (approx. lbs.) 365
Jul 19, 2009 | Mitsubishi VS-70707 70" Rear Projection...
Antenna mast replacement
you basically have to take out the entire left hand side of the interior of the trunk. make sure you label screws from which you took them. very easy to do! if you need more detailed info, you can e-mail me @ ralph_111@msn.com. I have a 95 also!
Jun 18, 2008 | 1995 Mitsubishi 3000GT
Lines through picture
this unit needs new convergence ics.It should run about 250 for repair from a honest tv repair shop.
Mar 22, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
