Question about Toshiba 50H81 50" Rear Projection Television
Toshiba 50h81 Red Blinking light
I recently got a Toshiba 50H81 free. It will not turn on and has a blinking red light. Many people have said it is a "board" or that it needs re-soldered in a couple of conections. I want to try to fix it my self to save some money. What is the board and how easy is it to replace. How can I be sure thid is what is needs? I am comfterble soldering and working with small wires but I just don't know what the problem is. Please help with any suggestions.
  • vanman22 Jan 29, 2008
    I have same problem, blinking red light. where are the convergance IC's located? also, can a schematic be provided?
    President:
  • 4,402 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 08, 2008
The protection circuit has been activated and has taken over the power management. It means there is a shorted condition somewhere in one of the 8 or 10 major sections of the set.
The repair involves downloading the error codes into the Toshiba test box and from that determine what section failed and why; then troubleshooting and repairing.
It's a job for a trained tech with the right instruments. The problem could be something as simple as a shorted electrolytic cap in the ripple filters of the main power supply to a massive failure of the high voltage - which is expensive
also see this post and this link is your owners manual
Dec 02, 2007 | Toshiba 50H81 50" Rear Projection...
My Toshiba 50H81 screen black, no sound & power light blinking
sounds as if your power supply needs to be repaired. the capacitors over heat and crown or leak.
Jan 01, 2010 | Toshiba 50H81 50" Rear Projection...
When we turn on our Toshiba 50h81, it will work ok for 45-90 minutes, then without warning, the picture and sound will go off and the power light blinks. We have to let it set for awhile (I've never timed...
These Toshiba TVs have a problem on the power board that causes this issue and it is a common one. There are several capacitors on the power board that seem prone to coming loose over time. When they lose connection for a moment the TV's protection system steps in and cuts off power. This causes the 'blinking power light' issue. The last one I repaired was a 43V71 model and I re-soldered one loose capacitor on the power board and it has worked perfectly ever since. Toshiba put out a service bulletin on this problem. It is well known and well worth fixing.
Nov 11, 2009 | Toshiba 50H81 50" Rear Projection...
No picture and the power light blinks
A red blinking light could mean that the lamp timer is at it's limit and it is time to change the lamp. You will also have to reset the lamp timer by pushing and holding down 2-3 buttons on the tv or remote. Refer to your user guide for the proper way to reset and or change your lamp.
Oct 04, 2009 | Toshiba 50H81 50" Rear Projection...
Tv won't come on
Mine is Toshiba 55 TZ, have it since 98', shutdown and red light blinking problem, search the ned and found out, generally a Convergence IC (stk392-110) problem. bought 2 for $15 at suburban-elect.com (ebay). replaced following direction from http://www.casiasfamily.com/repairlog/tp50h15.html
Open back cover, 9 screws and wirings (pls mark), removed(soldered) a electronic board infront of convergence ic. removed IC (stk392-110) (screwed and soldered).
Replaced everything and voila...! it is now working again..
no more shutsdown and red blinking light. Saves mo $400 for a repariman. of course just be careful with static and stuff.
Feb 29, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50h81
it happens to my toshiba.. once in a while and gradually shutsdown every minute during the last 2 mos..
Mine is Toshiba 55 TZ, have it since 98', shutdown and red light blinking problem, search the net and found out, generally a Convergence IC (stk392-110) problem. bought 2 for $15 at suburban-elect.com (ebay). replaced following direction from http://www.casiasfamily.com/repairlog/tp50h15.html
I don't know how to solder, so I ask friend to do it for me. But I did the rest. Just to give you an idea that it can be done even if you don't know much about electronics. This in no way a recommendation but just stating my experience. Follow at own risk.
Feb 05, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81
most commom problem is convergance ic gone bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Jan 08, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 Re Blinking Light...wont work
best advice is go get a manual book on how to fix tv
May 07, 2007 | Toshiba 50H81 50" Rear Projection...
Toshiba 50H81 50" Rear Projection Television Logo
349 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
