Question about ViewSonic VX1932wm Monitor
ViewSonic vx1932wm comes on for a second then shutdown.
The front light goes amber like i is not getting a video signal for the computer. When put the old monitor on it works fine.
SOURCE: Viewsonic VA1912wb power goes off
xZAxZC
Posted on Sep 03, 2008
bammbammfran
  • 159 Answers
SOURCE: viewsonic va1912wb monitor goes blank for few seconds and comes back and this happens very often
Your power/inverter board needs to be overhauled.
Your capacitors on the board are probably burned out.
If you open it up and send me a picture , I may be able to tell you if they are or aren't.
There is also a chance a transistor has gone bad on the board.
I repair many viewsonic boards on ebay
bammbammfran
Posted on Oct 21, 2008
budmrtn
  • 11361 Answers
SOURCE: Viewsonic VA912b. Monitor will only turn on for a
Bad caps in the power supply, common problems. See examples here: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20V912B/
Posted on Jan 07, 2010
budmrtn
  • 11361 Answers
SOURCE: It's a Viewsonic VX715 Monitor. When it's turned
It can be one of thses: bad caps (bulging top or bottom seal) in the power supply, bad backlight inverter circuits, bad lamps. You need to open it up and lool for bad caps first, then measure the voltages across the filter caps, you should have 5vdc and 12~18vdc (there are two power supplies: 5vdc for logic, 12~18vdc for backlights citcuits) Post back what you find so we can guide you further, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Jan 25, 2010
Testimonial: "Thank you very much!That solved my problem.Keep up this good work, guys!"
SOURCE: vx1932wm-3 monitor has stopped working properly,it
I had the exact same problem. It's a bad capacitor on your power board. It's most likely the 1000uF 25v one towards the center of the board. I noticed it on mine because the top of the capacitor was pushed out more than usual and it has some residue, which are signs of a burnt out/bad capacitor. (WARNING: There is a risk of electric shock when opening the power supply unit. Leave the unit unplugged for at least a few hours before working on it. Proceed at own risk!) Read on for a fix:
1. In the back, remove the stand screw covers (x2) to access and remove the stand screws (x4).
2. There will be a single screw under where the stand was attached on the screen. Remove it.
The LCD/unit is sandwiched between the thin faceplate and back cover, which are held together by several clips:
3. Carefully pry and remove the faceplate with a flathead screwdriver or other flat tool.
4. There will be 2 screws holding the button circuit board in place. Remove the screws, unplug the small cable from the board, and remove the board.
5. There are a few clips towards the bottom that hold the back panel onto the LCD frame. Pick at those until you completely remove the LCD unit.
6. Remove the 4 side screws holding the LCD panel to the frame.
7. Carefully disconnect the 2 sets of wires and the single ribbon cable from the LCD panel, taking note of their direction.
8. Remove the 4 screws holding the large power control board in place, and disconnect the 2 cables connected to it (the smaller cable disconnects from the power control board, while the larger one disconnects from the other end).
9. Locate the faulty capacitor and take note of its direction/polarity (+ and -). Use a powerful soldering iron to remove it from the board. I say 'powerful' because I could not get the factory solder to melt with my Weller at full 850 degrees. If you can't get it unsoldered, you can CAREFULLY pry it off with some pliers. If the connectors remain attached on the board, pry them off as well.
10. Put in the new capacitor ($1.73 at Radio Shack), taking care not to bend or break the leads and taking note of its polarity. Trim the excess lead wire off and carefully solder into place.
To finish, follow steps in reverse 8 through 1. Plug it in and test. If all is good, it should remain on. You might hear a tiny high-pitched sound when there is no signal or screen is idle. This happens with mine, but should be no cause for concern.
Hope this helps and good luck!
Questions? Email me: kings128@hotmail.com
Posted on Mar 10, 2010
How do I remove the back of my ViewSonic VX1932WM-LED monitor
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Oct 03, 2014 | ViewSonic VX1932WM LCD Monitor
Vx1932wm-led background lighting goes out
That is a very common symptom of a failure in the power supply board. This model uses the same power supply board that the VA1930 model uses. Here is a link to repair information that shows what capacitors to replace on the power board to repair it.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_34&products_id=168
I hope this helps,
BuddyMc
Jul 20, 2012 | ViewSonic VX1932wm Monitor
Monitor will not awake from sleep mode. Pilot light is amber when asleep. If the monitor is turned off pilot light goes from amber to off or black or nothing. Turning the monitor back on the pilot light...
That means your monitor is not receiving a signal from your video card.
A couple things to check:
*Make sure your cable is ok - unplug and replug the cable to see if it is a loose connection. Or try a different cable.
*Make sure your computer is not in sleep mode - Move your mouse or otherwise ensure your computer is awake and sending a video signal
*If you have another computer, try the monitor on the other system and see if it works.
Sep 03, 2017 | LG L196WTQ-BF 19" Monitor
Viewsonic VX1932wm goes black after a few seconds of being on. I need to turn it off and back on to get a few more seconds, then it goes black again.
It probably has dying power supply due to bad DC filter caps, see pictures of fails VIEWSONIC due to bad caps at my Photobucket.com.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 05, 2010 | ViewSonic Computers & Internet
3 shaded vertical bars on monitor about 3 inches
That the sign of failed T-CON board on the LCD panel, new panel will be needed. It will get worst with more lines appear.
Apr 24, 2010 | ViewSonic VX1932wm Monitor
I have an Acer AL1912 that when you plug in the ac, the green power light will blink for about a minute and a half then go solid. The backlight will come on and you can see a faint ghost of vertical lines...
If it is still in warranty call the manufacturer.
if not give more info elah4@zoominternet.net. May be somthing simple like a cable
shutdown computer unplug then disconnect the video cable on the computer from the monitor, plug monitor back in and turn it on, there should be a display that says no video source within a few seconds, if unit is working properly. shutdown and connect video again and then reboot computer. sometimes it just takes a compleat power disconect to reset things,
Jan 30, 2010 | Acer AL1912B 19" LCD Monitor
No display (black) - power light is amber color
The video signal is not reaching your monitor, check the pins on the connector from the monitor to the computer, then check the video card:
Turn off your computer, unplg the power, and then take out the video card. Wait 5 minutes and then put the card back into the computer and turn it on. For onboard video; turn off the computer, unplug the power, then hold down the power button on the front for 5-10 seconds, then plug back in and turn on.
Make sure the video card is snug in the AGP/PCI slot. If this is built-in video, try borrowing a video card from another computer and install it in this one. If the borrowed card works, then replace you card. If video is built in, then you can disble the onboard video and use the new card without having to replace your motherboard.
Jul 14, 2008 | ViewSonic VX910 19" LCD Monitor
ViewSonic VX1932wm Monitor Logo
100 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
