Question about NEC PX-42VP5HA 42 in. EDTV-Ready Plasma Television
2 inch Black strip on screen
There is a Black two inch strip on the screen all the time does any one know what is wrong?
    Champion:
  • 217 Answers
It all depends where this strip is and exactly how wide it is, it could be a panel problem or one of the pcb's that control that part of the screen, if you can post a photo of it, I can tell you what is wrong with it.
Posted on Apr 16, 2007
Bottom half of screen is black
The display strip is not properly seated in the connector base. That is a hardware problem so dont think of a software error.
Oct 07, 2014 | Samsung Un46eh6000 46-inch 1080p 120hz Led...
When the TV is turned on there is a @1.5 inch black strip along the top. I was told the TV has a way to adjust the screen. Is this true and is it something I can do by myself?
I'm sorry that the TV is displaying 1.5" black strip on the top of the screen. Please let me know the model # of the TV so that I can give the specific instructions to resolve the issue.
Thanks for understanding.
Aug 22, 2011 | Televison & Video
Indicating a carrage problem, carrage going to fast and slaming into one on start up
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test. If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
try this printer self-test by following the steps given below:
1. Please press the "Options" button 10 times. "Cartridges" should now appear in the display screen.
2. Press the "Left Arrow" button once, which then brings you to the "Self-Test" option.
3. Press the "Select" button once. You will hear a series of clicks.
4. It should print out a sheet of paper with horizontal color and black lines and smaller vertical lines.
You should see text followed by a thick 1-inch black bar. Under this bar, should be a process gray bar about ½-inch thick. Below this line should be a set of railroad like bars of cyan, magenta, and yellow.
Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Oct 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
Kodak camera shows me a blank/black screen
You have a bad CCD imager. Find a repair shop that can strip a CCD from a camera with a bad lens. This is the least costly repair.
Jul 02, 2009 | Kodak EasyShare P850 Digital Camera
Strips of 2 inch wide black and white, running top to bottom
Definately a damaged screen, no way to fix it for less than the cost of a replacement screen sorry.
Jun 16, 2009 | Philips 200P4 (Silver/White) 20.1 in. Flat...
Display has 2 inch black stripe running vertically down screen
I have an IBM think pad that developed a 2 inch black strip on the left side of my dispaly. I tried restoring to a previous setting, I updated video drivers, I reset display properties. None of the above worked and am now thinking of formatting and reinstalling windows as a last hope unless someone has any other ideas.
Dec 26, 2008 | Toshiba Satellite P105-S6104 Notebook
HP Pavilion dv6337us screen problem
Place you cursor on a blank spot on the black area, Hold the left mouse/touchpad button down and drag it back down to the bottom of the screen. That should get you back to where you want things to be.
If that fixes it, please return here to rank this as solved. If it doesn't, let me know and we'll see what else we can come up with. ;o)
Ron-
Nov 08, 2007 | HP Pavilion dv1000 Notebook
Vertical black line on screen
Your set has either a bad driver board or more likely a bad plasma panel.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 18, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
NEC PX-42VP5HA 42 in. EDTV-Ready Plasma Television Logo
140 people viewed this question
Top NEC Televison & Video Experts
Kyle Steven OHare
Kyle Steven OHare
Jaime Hernandez
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
