Question about Candy CPCA240FFK Bottom Freezer Refrigerator
Temp control is the fridge freezer coldest at 1 or 5 hotpoint ffa40x...please reply
    Problem Solver:
  • 6 Answers
Most refrigerator settings are in numbers like yours, the higher number will be colder setting.
Posted on Dec 20, 2008
Why is Fridge not cooling well?
The part number you need is going to be WR09X10050. This is for the damper assembly, but while you are at it change out part number WR55X10150. this is the part that controls the damper and more than likely if one fails the other will be soon to follow
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 05, 2012 | Hotpoint Refrigerators
What setting is the coldest on refrigerator? it goes 1-6
#6 is the coolest on the fridge, with the #1 being least coldest to #6 being the coldest setting.
Apr 04, 2011 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
I have a Kenmore bottom freezer fridge. Can't find the manual. Is 7 the coldest setting or 1? We keep the fridge in our garage and with the artic temps we are having we need to adjust it.
most refr's dont so well when the ambiant temps fall below 50 degrees. you should not need to adjust the controls must past the "midpoint" usually 4. but 7 is the coldest setting.
the best thing you can do is check what the actual temps are in your garage and if you can warm it up to above 50, then the unit should run properly again.
if the ambiant temps are too cold, the freezer wont be cold enough and the refr section will freeze things.
Jan 06, 2010 | Refrigerators
My Hotpoint ffa40x fridge freezerhas a problem,the freezer gets a build up of ice inside the freezer under the bottom drawer which makes the drawer stuck fast until i cut through the ice to release it.This...
your auto defrost heater is not working or you need to defrost it yourself ... turn unit off for a day with doors open. ***********PUT YOUR FOOD IN SOME ONES ELSES FRIDGE ************
Dec 30, 2009 | Hotpoint Refrigerators
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Freezer -5 Fridge 50
You have a defrost problem. Refrigerator gets cold via freezer. If blocked with frost, will restrict cold air into refrigerator.
Apr 26, 2009 | Refrigerators
Consul gas fridge .freezer working fridge not.
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Dec 15, 2008 | Refrigerators
Fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Nov 04, 2007 | Hotpoint FFA90 Bottom Freezer Refrigerator
Candy CPCA240FFK Bottom Freezer Refrigerator Logo
402 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
