Question about Samsung Digimax S800 Digital Camera
Samsung digimax s800 not swiching on
When switched on lens does not fully gives three beeps and switches off. any ideas??? Thank you
    Problem Solver:
  • 6 Answers
The problem is that the lens is jammed. I had to take my camera apart to unjam mine manually, the cogs that move the lens are not lined up with each other, thats why you hear the motor turning and then you get the 3 beeps because the lens hasnt initialised
Posted on Feb 24, 2009
Samsung Digimax S800 has lens stuck in open position. Replaced with fresh alkaline batteries, pressed on button, screen lit up for a second or so, turned off and gave 3 beeps. Any ideas? Thanks, Kevin
Did you accidentally drop it? If you did then there is a big chance that the lens is busted. If you didn't drop it, then it could be just dust/dirt inside the lens mechanism. Hold your camera with the lens facing the ground and then repeatedly tap it your camera gently - moderately to remove the dirt. You can also try spraying compressed air into it.
Sep 07, 2011 | Samsung Digimax S800 Digital Camera
My Samsung Digimax S800 Camera, when push power bottom, the camera green lite near power button and camera bleeps twice. Then turn off. Zoom len is fully extended. Chnage Battery three times.
this problem is a is usual occurrence when the camera is not well powered.
ie. the battery might not have enough charge on it or might have gone bad and require you to replacei it.
please ensure you get the battery with right voltage and wattage, the required is usually written around or in the battery compartment.
Jan 14, 2011 | Samsung Digimax S800 Digital Camera
Digimax S800 Samsung : Lens won't retract
check first if battery is ok, maybe your problem is your barrel, if barrel not function properly you need to change motor or barrel allignment. if barrel is ok you have short circuit in your assy pcb main.
Apr 23, 2010 | Samsung Digimax S800 Digital Camera
S800 lens won't close, can't take photos
The lens was bent to one side, so bump with my palm to straighten it back. I was able to start using my Samsung again.
Mar 21, 2009 | Samsung Digimax 800K Digital Camera
My samsung digimax s800 won't turn on,the batterys are ok
the lens mechanism is not initialising, the cogs that move the lens are out of alignment slightly. you colud try and fix this yourself by taking the camera apart and realigning it manually, or sometimes you can get hold of the prodtruding lens and gently pull, be carefull !! you might hear a grinding noise as you pull this is just the main lens cog turning. once fully out put batterys back in and give it a go
Dec 14, 2008 | Samsung Digimax S800 Digital Camera
Put new batteries in, camera bleeps three times & switches off
hi meeshfriel,
The battery might be damaged. try recharged the battery at least 2 hours maximum of 4 hours. If the problem persist it is your battery needs to be replaced......
Samsung S800
If the camera fell on it's lens it is probably jammed. Try to find something small, strong and thin, possibly a hairpin and slide it into the barrel while gently trying to force it outwards immediately after switching it on. When it does extend, try to clean or blow out any grit that may be inside the mechanism. The batteries are hot as your camera does not switch off and may be remain on for hours
Feb 23, 2008 | Samsung Digimax S800 Digital Camera
3 beeps and nothing else
just three months old?- return it to the Vendor for replacement and get onto the Samsung Tech support Team
Jul 10, 2007 | Samsung Digimax S800 Digital Camera
Samsung Digimax S800 Digital Camera Logo
257 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
