Question about Insignia IS-PDVD10 Portable DVD Player
SATELLITE SIGNAL I HAVE 4 SATELLITE BOXES AND THREE TV'S HOOKED UP. BUT I CAN NOT WATCH MY SHARP TV WHILE THE OTHER TV'S ARE ON. EVERYTIME I TRY THE SCREEN IS SCRAMBLED. ONCE I CUT THOSE TV'S OFF IT SHOWS CLEAR. I HAVE HOOKED THAT TV UP TO ALL FOUR OF THE BOXES BUT IT STILL SCRAMBLES WHEN THE OTHER TWO TV'S ARE ON. HELP!
We have a motor home with a tv in the living room and one under the coach in the bay (factory installed). We have Direct TV and both are connected to one satellite receiver. The TV in the bay has a blue screen so that it is not getting a signal. It did this last year and we forgot what we did (by accident) to make it work. It seems that the insde TV remote was used but we can con remember what we did to make it work. When working they both receive the same channel and turn off the power to the inside tv and watch the outside tv. Any ideas????
Posted on Jun 05, 2011
    President:
  • 814 Answers
This is a problem with the shielding on the television the other signals are interfering with the reception. Call the television maker and ask the for advise on how best to shield the television from the other signals. You could also try shielding the television with tin foil wrapped around the critical area of the television. This might work, but it better to talk to the television customer service they may have some filters that can block the noise causing your interference problems or go online and check their website for the frequently ask questions and see if a problem like yours has been answered. Hope this helps you with your problem.
Posted on May 10, 2009
I have a Philips soundbar that I have hooked up to my flat screen tv using audio (red,white) cables directly from soundbar to tv and there is no sound coming out.
Be sure you are hooking up the Audio Output from the TV or satellite to the soundbar.
From the satellite box both Audio Output and Video Output go to the TV, and then Audio Output from the TV goes to the soundbar.
Or
From the satellite box Video Output goes to the TV and Audio Output goes to the soundbar.
This may help as well:
https://www.youtube.com/watch?v=Z27WtBy4IUs
Jan 07, 2015 | Philips HTL2101A/F7 Soundbar 40 Watts
Sharp lcd tv problems lc4664u
More than likely the Timing control PCB has failed.
Jul 17, 2017 | Televison & Video
My sharp 32 aquos has no red in picture; however, when I play a dvd - the colors are beautiful as usual. GZ
When a DVD player is working just fine on a television but the cable or satellite isn't that points to the cable or satellite. Either the cable(s) connecting the cable or satellite box to the tv are to blame or the cable or satellite boxes themselves are to blame.
Jul 19, 2010 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
V-chip activated
Hit the Menu button on the TV. 2. 'INPUT SECRET No.' should appear. 3. Press and hold both VOL (+) and CH DOWN (9) on the TV set simultaneously until the message 'INPUT SECRET No.' disappears. 4. The vchip settings should be disabled now and the Parental controls menu should be presented, 'disable' Status if need be.
Mar 14, 2010 | Sharp 32C-240 32" TV
I have 3 att uverse cable boxes...1 being the dvr unit. The room with the dvr unit only shows a black screen with live tv? When I go to watch a recorded show it works in the other rooms but is a black...
Is the cabling from the satellite receiver to the DVR hooked up right. It sounds like it's in single mode, but with the coax cable put on the wrong way.
Nov 23, 2009 | Computers & Internet
Speaker distortion on SHARP 37" Aquos Hi Def
When you are changing channels you are using the tuner of the sat reeiver. the tv does not know you are changing a channel . It is just receiving a constant signal from the SAT receiver. I would suspect a problem with the receiver. Try another one first .
Apr 24, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
JVC LT 32E479 UNABLE TO SWITCH ANY CHANNELS
go to menu select TV settings select add a channel  In the scan boxes  type 1 and 3 or what every you have your Satellite set to  Then hit start scan  The TV will come on reset to channel 3.
Jan 14, 2009 | JVC LT-32E479 LCD TV
New Sharp Aquos LCD 46 TV
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
Dec 28, 2008 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Flashing boxes on screen
Regardless of what the satellite company says, I would find a way to try another satellite reciever to start with. I have seen this from cable boxes and satellite recievers many times. I have also seen this with a bad LNB, distribution amplifier, or a bad active splitter, or a bad cable, or a bad connector.
There is a data loss somewhere, and the set is seeing what we call aliasing. This is a loss of data, and it shows as blocks.
It is possible for your set have internal aliasing if there is a fault on one of the processor boards. The only way you will easily know if the problem is external or internal to the set is to try another source.
From your description, if other sources work with the set, then this strongly rules out the set. To easily know if the fault is on the input that the sat reciever uses, if possible swap the position with the DVD player.
On the sat system, a defect in the reciever, the LNB, or any LNB splitters or a relay, or a bad connector, can also cause aliasing because of a signal loss.
Jerry G.
Apr 30, 2008 | Toshiba 50HP66 50 in. Plasma Television
Sharp 27F-630 27" TV
Dear eligas1312, Most probably your antinna is not reciving TV signals properly.Try to adjust it in a right direction at a proper height, also adjust frequency of various channel of Direct TV through menu button. regards ajay
Aug 04, 2007 | Sharp 27F-630 27" TV
Insignia IS-PDVD10 Portable DVD Player Logo
82 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
