Question about Brother HL-2040 Laser Printer
New Toner Cartridge Does not Print (HL 2040)
I have a Brother HL 2040 and I just purchased a new toner cartridge. However, when I print a page, nothing gets printed, with the exception of a few faint smudges. I was wondering if anyone had any ideas what might be the problem.
Thanks in advance.
    Scholar:
  • 113 Answers
Hi!  have you check you toner, it has a white strap, you need to strip it to open the nozzle of your toner. but before you do that you need to shake it first to have a sharp print out before you would strip that white strap. have a nice day
Posted on Dec 20, 2008
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
Toner light is flashing and printing has stopped
Hello ,
This problem is a common issue and easily fixed.
When putting in a new toner cartridge, the printer usually automatically resets the toner count.
In a situation like this, the printer did not automatically do the reset and so we must manually reset the printer.
To manually reset the printer, first, remove the toner from the printer and separate it from the drum unit.
With the toner cartridge in hand and the brother writing facing you, look to the left side of the cartridge. You should see an arc shaped opening with a white tab in it.
The tab is set at the right position and must be pushed back to the left side of the opening.
To push the tab back, you must turn the grey gear attached to the front roller upwards as you push the tab.
Once the tab has been placed to the left position, the printer will accept it as a new toner cartridge.
Thanks,
Pat
Apr 01, 2010 | Brother HL-2040 Laser Printer
Brother HL-2040 toner led stays on, won't print
There is a window on each end of the toner cartridge that you can cover with electrical tape and keep printing, it shines a light thru and when the toner is too low it says it's empty. The weight can be misleading.
Sep 02, 2009 | Brother HL-2040 Laser Printer
Replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Mar 31, 2009 | Brother HL 5250DN Laser Printer
Nothing prints
If you replace a new toner and sitll not working then you should push and hold on start buttom for 1 min
Feb 23, 2009 | Brother HL-2040 Laser Printer
Brother HL 2040 toner light flashing
Push the start buttom and hold for 30 sec.
Nov 26, 2008 | Brother HL-2040 Laser Printer
Brother HL 2040 won't print
Sounds like the toner cartridge is faulty. I would change the cartridge.
Nov 19, 2008 | Brother HL-2040 Laser Printer
I have a brother HL-2070 laser printer and have just inserted a new toner cartridge. When I turn on the lase printer it is coming up orange light toner & will not print. Its as if its not recognising...
Have you tried shutting down and restarting after the cartridge was in?
Also at Brother there is a new driver download for your model, and other info.
http://www.brother-usa.com/SiteSearch.aspx?sk=hl-2070%20manual
May 01, 2008 | Brother HL-2040 Laser Printer
I put a new toner cartridge in and the toner light remains on and will not print.
Actully i have hl-2040 brother printer
the problem is no lights are on
ready light not started plz give
me suggession my mail id is gmcharankar@yahoo.co.in
Jan 08, 2008 | Brother HL-2040 Laser Printer
HL-2040 Almost black Pages
Drum needs replacing, normal consumable, possible faulty toner hard to know when you use non gen items.
Dec 18, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
199 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
