Question about InFocus ScreenPlay 7200 Multimedia Projector
Light shutting down after 15 mins
I have replace light bulb (old one had ~500hrs) and problem still occurs. Fan motor will run indefinitly even after temp is cool. Projector seems to be working in all other aspects.
  • 2,237 Answers
It's overheating. clean it out and try again.
Posted on Dec 29, 2009
TV shutting down, lamp and power light blinking
I would try a new lamp. Lamps have varying qualities & usage conditions may cause varying life spans.So, even though the lamp may be 1 year old I would try a new one first.
Jan 07, 2015 | Samsung HL61A650C Television
How do you check a fan motor
You need to check the volts at the motor while it's running, to make sure some safety is not shutting it off. Then check the amps on the motor while it's running. Also you need to check your capacitor and wiring.
Apr 30, 2014 | Heating & Cooling
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
Controls, heating and turntable function normally, but there is an intermittent failure (approx 80 of the time) where the interior light and blower do not function when the microwave is operating .
follow this test and fix it; God bless you
1)
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
2)
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Oct 31, 2013 | Jenn-Air JMV8100A 1000 Watts Microwave...
JVC DLA-RS1U Projector turns off
I have a similar problem. JVC Project (DLA-RS1) shuts off after about 30 min to 1 hour of use. Everything turns off - bulb, fan, even the little light on the projector near the buttons. After 10-15 min the red light comes back on and you can start the projector.
I have seen this happen when I had installed a knock-off bulb. I believe the bulb runs a little hotter and the projector over heats. Now I am seeing it happen even with a JVC bulb.
I am in the process of taking the cover off the projector to see if anything is blocking the air flow (like a piece of broken bulb, which did break a while back). If a problem doesn't show up there I am going to check the fan to see if it is turning at full speed (maybe replace with a beefier fan?).
Does anyone have instruction on dis-assembly?
Apr 17, 2012 | JVC DLA-RS1U Projector
I have a samsung air conditioner - model AQV24NS and after 10- 15 mins it shuts down both red & green lights start flashing. The only wayi can get it to work again is to shut off the main power suply...
Please check outdoor unit. Compressor or fan motor getting high amps due to overheat. Clean condenser coil. If still problem, replace running capacitor. If out door fan less rpm replace fan capacitor. In some unit 2 in 1 capacitor is there. So replace one capacitor will rectify fan and compressor problem. Thanks. Helpful?
Jan 09, 2011 | Samsung Heating & Cooling
Radiator fan runs after car is turned off. Only occurs when A/C is run for more than 10-15 min. Shuts off after a few minutes, but is concerning.
That is nothing to worry about the fan remains running after the vehicle shuts off in order for the engine to cool down. Once the motor cools down sensors trigger the fan to shut it off.
Sep 10, 2009 | 2004 Ford Focus
Stops cooling after a few mins
Check the condenser fan motor It probley has bad bearings and over heats and shuts down
after 15 or 20 min of run time
Jul 25, 2009 | Heating & Cooling
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Panasonic AE900U Projector
Check the manual if you have it or on line. The symptom you are describing may be a built in warning that your bulb has reache 2700 hours. I think there is a reset process and then at 3000 it goes out. Spent today reading the manual because I have one and the red lamp light is blinking. I called Panasonic and found out the only place that services these units is in Leawood Kansas USA> The place is called Heartland Services.
Aug 12, 2007 | Panasonic PT-AE900U Multimedia Projector
InFocus ScreenPlay 7200 Multimedia Projector Logo
148 people viewed this question
Top InFocus Office Equipment & Supplies Experts
neOen
Level 1 Expert
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
