Question about Husqvarna Chain Saw 20" Bar
Fuel line for Stihl 025 chainsaw
I have a Stihl 025 chainsaw and the fuel line has collapsed like it was squeezed together with a pair of pliars. Can you give me some idea as to what happened? A part number for the fuel line?
There is a good video on this problem on you tube. should be easy to find.
Posted on Dec 31, 2009
    Sergeant:
  • 322 Answers
The ethanol in the fuel is what caused the fuel line to get soft and collapse. You can go to your Stihl dealer and buy a new fuel line and a service kit for that saw. The service kit will contain a new spark plug, fuel and air filter. The part number for the fuel line is 1123 358 7703. The service kit is 1123 007 1800
Posted on Jan 22, 2013
  • 211 Answers
Hi
It happens sometimes.You have to replace the fuel line.This is a trick.Remove the gas tank cap and take off the fuel line and remove the fuel filter.Take off the fuel line from the gas tank.Cut off the piece of the fuel line wich is larger and seals the gas tank.Now through that piece of fuel put an ordinary fuel but about the same diameter.Put all back and that is all you have to do.If you need farther info just let me know. best regards savumihai71
Posted on Dec 20, 2008
Stihl repair manual
You obviously have a fuel problem. Clean carby jets and also check restrictor in fuel line.
Aug 17, 2014 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Dont start
check the spark plug is there fuel getting to the carby might have to adjust idle screw
Apr 21, 2014 | Stihl Chain Saws, 017, 019, 021, 023 & 025
025 model is sucking air and will not run
Check fuel lines, fuel filter, check carb diaphragms and replace any of them if damaged
Jan 18, 2014 | Stihl 030 031 Chainsaw Air Guide
Saw will start but dies when rev
Check the pick up fuel line in the gas tank. If there is a fuel filter at the end of the line,remove and clean or replace. Use a small fexible wire to hook line and pull out thru gas tank opening.
Mar 14, 2013 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Missing 025 Stihl chainsaw part
Hi, you are correct it is the tank vent. Go to a stihl shop and purchase a new one, regards Phil.
Jun 03, 2012 | Stihl Garden
Scorched pistons in a STIHL chainsaw - and its not the fuel mixture
What side of the piston is scored? If it's the exhaust side, it's running too lean, ergo, it's the mix ratio.
Nov 16, 2011 | Stihl Chainsaw 42mm Piston Rings 025 O25...
Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
Feb 13, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
2,835 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
