Question about GE Spacemaker Washer and Dryer Electric Laundry Center
Dryer Selector Knob is Mis-aligned
The thin metal disc with the selector line on my dryer knob has been knocked out of place, and does not turn with the knob- making me unable to tell which dryer setting I'm selecting. When I pull the knob off the machine to fix it, I can't seem to figure out how to get the selector disc back in place, or where the selector line should go so it accurately points to the rite setting. Often, my dryer will go to the off position within minutes of me turning it on..leaving it impossible for me to get other things done while I have a load in. HELP! Can anyone tell me how the selector disc should lay properly within the knob??
SOURCE: Ge select electric dryer
it may be clogged on the inside of the machine not just the exhust tube.
Posted on Jan 10, 2008
  • 1894 Answers
SOURCE: TThe pull-push stop-start knob does
i think the knob is faulty
may be a small misplacement of some some support ring
Posted on Jun 25, 2008
  • 116 Answers
SOURCE: How do I remove the selector knob on washer
The main selector control know spins off by turning the selector inner knob counterclockwise. The outer ring will then pull off. The other knobs are held on with friction and should just pull off.
The best way to get behind the front panel is by removing the top panel of the machine. There should be 2 gray/solver tabs at the back of the machine near the top if you remove the 2/4 screws from the top then the whole top panel will slide forward then lift off.
Be sure to unplug the machine first.
Posted on Aug 02, 2008
SOURCE: Where can I purchase selector Knob for kleenmaid
Thank you for returning a reply to me email but I no longer require this service as I contacted a company who will come and look at the machine for a minimal fee. Thanking you. Jan
Posted on Oct 19, 2009
  • 14 Answers
SOURCE: GE Spacemaker Washer/Dryer wont start only washer or only dryer
check power from the out let make sure they got 220 v
Posted on Mar 03, 2010
What can cause an electric GE dryer to not start? Model number DCVH680EJ1WW. cogtinuity with motor switch, door switch, high limit fuse, thermistor & no cogn. with the thermodisc or heating element.
As a repair technician, just came across this crazy situation with GE / Hot Point / Moffat machines several times. It is all made by GE corporation.
The Dryer is not starting because your cycle selector knob is broken inside and it is just turning without turning the timer selector.
GE corporation machines are good. But those damn chinese plastic knobs break from inside. I have driven 50 km to find out the knob is broken. I had to charge the poor customer.
Apr 15, 2015 | GE Dryers
The machine is stuck in zigzag cannon move control knobs
If the buttonhole dial has been rotated so that its indicator mark is not at zero (vertical aligned with the plate indicator mark), the stitch width dial will not function. Turn the buttonhole dial clockwise to the vertical mark.
SewTechnical Home
Jun 05, 2014 | Bernina Sewing Machines
Maytag Neptune dryer, model mde6700ayw, cycle selector knob will not change cycles. It gets stuck on a random cycle even when I power off, power on. Tried to put in service mode but as the cycle selector...
you have a problem with this dryer,the computer board and other parts are no longer available,your better off replacing the dryer.if you go here you can see the parts
http://www.searspartsdirect.com/model-number/MDE6700AYW/3048/0151200.html?searchType=modelSearch&q=mde6700ayw&searchTerm=mde6700ayw
Sep 06, 2017 | Maytag Dryers
What is the heat selector knob?
This allows you to adjust the temperature to match what you are drying. Some fabrics and clothes require low heat or you may only be drying a small amount of clothes and don't need much heat. You also may not want high heat to avoid shrinkage of some clothes.
Jul 16, 2012 | Avanti D110 Electric Portable Dryer
Whirlpool Dryer LEO8857HQ. Selector switch. I'm not in front of the dryer now it's 1800 miles away in my sister's garage and she doesn't use a computer. The selector control knob came off in her hand and...
a piece of plastic from the original knob may still be on the shaft, thus preventing the new knob the ability to lock in place. Hope this helped Tim
Jan 14, 2011 | Whirlpool Dryers
WHDSR209DWW on/off button will not engage to spin the cycle selector dial
The cycle selector is not engaged onto the timer shaft. Need to remove the on/off knob by removing the plastic "U" clip. Remove the cycle selctor knob and check that the steel spring clip on the selector is fully seated. Re-install the cycle selector onto the timer shaft aligning the selector key with the with tthe notch on the timer shaft. Re-install the on/off knob.
The cycle selector and on/off combination is a poor design. Users press the on/off knob in and turn clockwise to set the wash cycle. If you're not gentle this action wears the teeth on the timer shaft and the user has to press harder and harder to set the wash cycle. This pressing causes the cycle selector to be pushed off the timer shaft and you can no longer operate the machine.
VERY IMPORTANT:
Stop using the on/off knob to set the wash cycle. Press on the cycle selector to set the wash cycle. Use the on/off knob only for starting or stopping the machine. Don't press or pull too hard on the on/off knob or you will wind up pushing the cycle selector off the timer shaft.
Jan 12, 2010 | General Electric WHDSR209DWW Top Load...
Have a 1970's elna su supermatic but cams don't work
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
Mar 11, 2009 | Elna 1010
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
135 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
