The printer is putting lines on the paper that are not there , Dell says nothing they can do ?
  • 3 Answers
What model of dell i can help you
Posted on Dec 20, 2008
New Ink does not show up on Paper!
Did you remove the plastic film off the cartridge before you put it into the printer?
Apr 20, 2010 | Dell A960 All-In-One InkJet Printer
After no problems at all, my Dell 926 AIO printer told me that there was a paper jam, but there was no paper stuck in it. Now, it keeps telling me that there is no paper loaded in it, but there is paper...
if you can, check to make sure nothing fell in it. ive pulled thumbtacks and a banana peel out of printers before. also sometimes the little rubber wheels that grab the paper dont grab as good as they once did. sometimes adding more paper or putting in less paper helps. i had this one printer that started not grabbing paper so once in a while i would get a wet paper towel and kinda hold it aginst the rubber things and like print a blank page so it would spin a little, but thats just me
Apr 13, 2010 | Dell 926 All-In-One InkJet Printer
Everytime i try to print or copy it keeps saying paper jam and theres no jam i can see i put just one piece of paper and its not running through
lift the printer and shake to check if it sounds like a piece broken inside.. turn the printer off take the power brick out from the back.. manually pull the cartridge to extreme right then center.. check if cartridge is aligned correctly.. if nothing of this works.. contact dell for replacement under warranty.. if out of warranty.. inkjet printers cannot be repaired if broken.. u can buy a dell v313 of same quality for $59 with warranty..
Dec 30, 2009 | Dell Photo 964 All-In-One InkJet Printer
I have a dell V305w printer and its not taking paper. i put in the right alignment paper 8.5 x 11 and its just not taking the paper
HAVE YOU CHECKED THE PAPER PATH,OPEN THE TOP SEE IF YOU CAN FEED A SHEET OF PAPER THROUGH ,TO ENSURE NOTHING IS BLOCKING THE PAPER PATH,IF NOT CHECK PAGES 100 -104 IN THE USER GUIDE http://support.dell.com/support/edocs/systems/v305/en/ug/pdf/ug_en.pdf
Aug 30, 2009 | Dell V305w All-In-One R840635AU InkJet...
MFP not recognizing paper yet continues to give paper jam errors
On the Manual paper feed you should see a piece of plastic that sticks down where you put the paper, it's called a Flag, make sure that this moves freely back and forth (or up and down)
If the flag is broken or does not move freely the printer will not know that there is paper in the MPF
if you need further assistance in this diagnosis please contact us at help@support.compufirm.net we are Dell certified
May 26, 2009 | Dell 3110cn Laser Printer
Dell AI0 926 All in One shows Clear Paper Jam with no paper in it.
I put my hand inside and found something clicked just below the right of the first two rollers. THen it worked i think whatever clicked must have gotten stuck but i dont know why
Oct 05, 2008 | Dell 962 Photo All-In-One InkJet Printer
Paper loading
I don't have a dell. But I do get that 1-side pulling problem with some of my printers. I solved that problem by positioning the paper with the paper guide (which is movable) to the exact size of the paper so that there is no free play. Usually this solves the problem. The paper guide must be exact, not too tight or too much free play for the paper to move around. Let me know if this helps.
Jul 25, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 printer paper jam; don't have a # sign or number to reset
Hi
If there is a error msg on the operator panel of the printer, try the following steps
1.press and Hold the start button and the cancel buttom on the printer and holding them down unplug the Power adapter from the printer , wait for abt 30 secs and then put back the power adapter and then release both the buttons.
2. manually move the rollers present inside the paper tray, lift the printer and shake it firmly , turn the printer upside down and gently tab on it , put back the power adapter and then turn on the printer , if it still gives the same error msg , then purchase the new printer
Apr 21, 2008 | Dell 924 All-in-One InkJet Printer
Dell photo 924 all in one printer paper promblem
Unplug the power adapter from the printer and then remove the papers from the printer , open the printer cover and look for any obstructions , lift the printer and shake it firmly, turn the printer upside down and gently tab on it , roll the paper tray rollers manually , put back the power adapter and then try printing a document with only one paper in the paper tray if it still gives the same error then its an issue with the printer and if the printer is under warranty then get the printer replaced .. or purchase a new printer instead of getting it repaired .. dell is offering a new printer 926 for $49 with 1 year warranty.
Do lemme know if that helps.
Bye.
Jan 19, 2008 | Dell 924 All-in-One InkJet Printer
49 people viewed this question
k24674
Marvin
Marvin
