Question about Canon EOS 400D / Rebel XTi Digital Camera
Manual Focus problem canon 17-85
I swithced to MF but it still auto focus.In dark area I test it to focus(MF mode).But it didnot let me release the Shutter button as it can not focus in that dark place.Both in AF and MF it behaved same.
pbinder
  • 6 Answers
SOURCE: My 300D wont lock on a point in its AF setting
If you are unable to focus in broad daylight and it just hunts through the whole focus range without locking, then it sounds like a problem with sub-mirror pin (also called the second mirror pin). My 300D just had this problem and I had to send to service to get fixed. I sent to http://www.keh.com/ as they were at least $50 cheaper than going straight to Canon. Just got it backed and it works like a charm again.
Posted on Jul 29, 2007
  • 155 Answers
SOURCE: Problem with Canon EOS D60 Digital Camera
You need to clean the gold contacts with a soft pencil eraser. Remove the lens, and clean the contacts on it. Then hold the camera so the lens opening is pointing down and clean the contacts on the camera. Ensure no debris gets into the camera body and none is left behind on the lens.
Put it all back together and you should be good to go.
Posted on Mar 24, 2009
SOURCE: Canon AF Issues
Change from auto focus to manual focus or focus using only one focal square and change the setting to One Shot. You may need to shoot in Manual (M) mode though. Any of the "auto" modes will not let you.
Posted on Apr 07, 2009
davesoucy
  • 148 Answers
SOURCE: Cleaned inside of viewfinder, now AF focus lights gone
Then you learn, when everything works fine, dont mess with it! Have a look at the gold pins that rely the body to the lens. Also check that your lens manual switch focus is engaged... Try a friend lens to see if its your cam or the lens...
Posted on Aug 04, 2009
empeethree
SOURCE: Auto focus suddenly stopped working
This may not be the same as your issue, but our AF stopped working as well. I tried all the recommended fixes - removing the card and battery, recharging the latter, removing the lens and cleaning the contacts, etc. None of those things worked. However, I then switched to MF, requiring me to turn the barrel, and I realized it was stuck and just needed a little force to get unstuck. Might have been the humidity. Anyway, our problem was solved - AF was back to normal after that.
Posted on Aug 24, 2009
Hi there. i owned a Canon EOS 60D model camera. The problem is, its AF option is not working except Auto n 'C' modes. While i am trying to use it in M mode with AF, its not working but in auto mode an
Are you sure you did not put the AF/ MF switch in the wrong position? Although I don't think it would focus in Auto mode. In all other modes, are you sure you selected a (or more) focus point(s) in the centre of the frame?
When the selected focus point is on the side of the frame it won't focus on the parts you want it to focus. Then while pointing to the point you want the camera to focus, please press the shutter release button half and what till it focusses. Then press it the whole way down. Be aware the camera needs enough light to focus and certainly can't focus with a lens wit a min aperture of 6 or a larger number. On your 18-135 you can shoot at f16 because it will first focus on wide open and only close the aperture after you pressed the button.
Jan 27, 2015 | Canon EOS 60D Digital Camera
Auto focus not working
Have you checked the lens AF/MF button?
Perhaps your lens is in Manual Focus mode?
Mar 21, 2014 | Canon EOS 550D Rebel T2i Digital Camera
Hi Ref: Digital Camera - Pentax K200 model It keeps auto focusing when in manual mode. Regards Chris
Putting the camera in manual mode still doesn't change the focus routine. If you want manual focus, there is a switch near the lens on the left allowing AF (auto focus) and MF(manual focus).
May 01, 2011 | Pentax K200D Body only Digital Camera
Why are all of my photos blurry? I have a Canon Rebel T2i
You have the focus set to manual. Either turn the focus ring yourself, or find the little switch on the lens that turns it on (MF = manual focus, AF = auto focus).
Feb 22, 2011 | Canon Cameras
Hi I bought my canon 1000d on september 2009 and a year later the autofocus doesnt want to work. In the viewfinder on the far right a number 9 has a green dot flashing next to it. Please help!! Ruthven...
The 9 you see is the maximum "burst" which is (pictures made in rapid succession) and is not an issue with your problem at this time the flashing green dot is the in focus confirmation light and it's good that you are seeing this as we will use it to remedy the problem.
Diagram
Manual focus switch
Diagram here
What I want you to do is put the AF-MF switch in the manual mode if it's already in manual mode then that was your problem switch to AF and go take some pictures. If it's in AF mode switch to MF make sure teh camera is on and look through the viewfinder at a subject say 15 feet (4.5 meters) away something that has contrast then turn the manual focus ring on the camera slowly until it appears to your ey that it's coming into focus when it's in focus the green light will come on solid, now you know what you are looking for focus an several different objects at different distances and focus manually. Now switch the lens over to AF (auto focus) and focus on the same thing but let the camera do the focusing What auto focus will not focus on in something with little or no contrast like water clear blue sky a painted wall mirror chrome glass and a few other things.
Here is another diagram to check make sure you are in the correct mode.
Diagram
Now for the focus point in the viewfinder make sure it's in the center position.
To adjust the focus point do this
Once you have the camera set to the center focus point and the correct AF mode (one shot) auto focus should return to your camera. Have fun Robert from London Ontario Canada
Jan 10, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
My canon rebel XSi will not auto focus
Actually what I found to solve the problem was to first set the lens in "MF" and practice taking a picture manually to see if that would work. When I did this, I discovered that the fine tuning portion of the lens was somehow stuck mechanically. I heard a loud click as I turned it. That was all it took to fix the focusing mechanism on the lens. Then I set to "AF" and Voila, the camera worked just fine.
Apr 04, 2010 | Canon EOS Rebel XSi Digital Camera
Your Sigma 28-300mm doesn't have a HSM-motor as far as i know. When you switch it from MF to AF, you also have to disengage the manual focusing ring by pulling it towards the camera, or pushing it away from the camera. Using the AF without unlocking the manual focusing ring may damage the AF motor.
I hope this helps,
/Chris
Jan 15, 2009 | Sigma 28-300mm f/3.5-6.3 DG Macro for...
Nikkon d50 wont auto focus
the D50 will only auto focus with an AF-S lens...make sure you are using an AF-S lens.
Also, check the swithc on the lens is set to "A" not "M" ...
Also, in the menu, check you set the camera as autofocus, not manual focus
Jun 07, 2008 | Nikon Cameras
Switching from auto to manual focus
AF/MF (Auto Focus/Manual Focus) * The AF/MF function works in CAMERA, M.REC mode only. * In most situations, it is better to use the automatic focus feature, as it enables you to concentrate on the creative side of your recording. * Manual focusing may be necessary under certain conditions that make automatic focusing difficult and/or unreliable. Auto Focusing * If you are inexperienced in the use of camcorders, we recommend that you make use of Auto Focus. Manual Focusing In the following situations, you may obtain better results by adjusting the focus manually: * A picture containing several objects, some close to the camcorder, others further away. * A person enveloped in fog or surrounded by snow. * Very shiny or glossy surfaces like a car. * People or objects moving constantly or quickly like an athlete or a crowd. Follow These Simple Steps To Set The Manual Focus 1. Set the power switch to CAMERA mode. 2. Turn the MENU DIAL up or down until the FOCUS is highlighted and then press the ENTER button. M. FOCUS(MF) will display. 3. Turn the MENU DIAL up or down until the object is in focus. Zoom out a little if focusing is difficult. 4. To return to AF (Auto Focus: ), press the ENTER button again.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Focus modes
There are four focus modes: S-AF (Single auto focus), C-AF (Continuous auto focus), MF (Manual Focus), and S-AF/MF (Simultaneous mode). (SINGLE Auto Focus): Focusing is performed once when the shutter button is pressed halfway. C-AF (CONTINUOUS Auto Focus): The camera repeats focusing while the shutter button is pressed halfway. (MANUAL FOCUS): The function allows you to manually focus on any subject while looking through the viewfinder. SIMULTANEOUS USE of S-AF mode and MF mode: You can fine-adjust focus manually by turning the focus ring after AF is performed in the S-AF mode.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
50 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
