Question about Combi Centre DX - Mango
Tap water dont get hot
Everything works fine........... central heating is great! but the water from the tap does not get heated either on CH/W setting or just water setting. ...... Maxi combi 80e 2 yrs old thought it was the selector switch but as I get no hot water on either setting it cannot be that.
  • 151 Answers
Check pilot light
Posted on Dec 28, 2008
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
My central heating works fine but the tap water is just warm at best. You certainly cannot enjoy a bath!
Are we talking about a boiler situation? You mention "central heating" and tap water.
If it's a water heater separate from the furnace then I would say a element going bad, assuming it's a electric water heater. If it's a single boiler unit, I would have to say call a service tech.
In either case, you will need to post more information regarding the equipment before a reliable answer can be given.
Nov 01, 2015 | Water Water Heaters
Hi I hope you can help I had a plumber come around and move my hot water cylinder in to my loft and now I can only get hw if I have ch & hw on together if I put hw on by itself my boiler over he
There should be a gate valve on the pipe from the central heating to the cylinder, it looks like a tap and is normally beside the cylinder. This is used to regulate the flow of hot water in the heating system through the pipe coil in the cylinder. If this is open too much it will let the central heating pump most of the water through cylinder and won\'t heat the rads properly, if its closed too much it will do the opposite. Ss I said it looks like a tap, so turn it fully clockwise, and then turn it anti clockwise about half a turn. See how this works and adjust it further to compensate. Hope this helps. Some plumbers forget to fit these but its easy to fit one, just cut the pipe carrying the heating through the cylinder and fit a stop cock (TAP)
Jan 04, 2015 | Dryers
Siemens rwb29 controller doesn't work properly. central heating comes up only when you select hot water, but not on its own
This happens to my rwb29 from time to time. You can try switching off the power to the controller for a couple of minutes with CH thermostat and CH programs set off. Or you can press the little reset button to the bottom right of the LCD screen. After 1 or 2 attempts these steps usually restore the independent control on my unit.
Nov 05, 2012 | Siemens RWB29
How do i set the heating/hot water timer on the LP112-24 acl controler ?
The instructions are available here: I hope I have been of help but please do not hesitate to ask if you have any further questions. Set the central heating Press the YES button, and the display will ask 'SET CH PROG?'. Press YES and you'll see ON1, the start of your first central heating period. Adjust it in 1-minute steps using the - and + buttons. If the - and + buttons are held down, the time changes in 10-minute steps. Press SET?, and you'll see OFF1, the end of your first central heating period. Adjust this in the same way, press SET?, then repeat the procedure for ON2, OFF2, ON3 and OFF3. Set the hot water When you press SET? after setting OFF3 for the central heating, the display will ask 'SET HW PROG?'. Press YES, then set your times in the same way. Remember, in this mode you can have different times to your central heating if you wish. When you press SET? after setting OFF3 for the hot water, the programmer will return to normal operation.
Feb 19, 2011 | Heating & Cooling
I have a Powermax 155 boiler that keeps losing pressure. Most of the time, I can usually work around this by closing the tap in the boiler until the pressure rises, but it's not working this time. I...
I would first check the switch on the front to ensure it is set for CH & Water. Push bottom of the switch, check you have a pressure of 1 bar on the gauge to the left of the front panel. If not, top up until it gets to 1 bar. Ensure a demand is being called for (the timer is asking for heat) by pushing the CH button until the grey line is alongside 24 hr. then check if the central heating pump vibrating. If still not come back to me for more info
Dec 13, 2010 | Heating & Cooling
MicroGenus27 No Hot Water
check HW and CH temperature probes check secondary heat exchanger for blockage check water pressure switch
Jan 03, 2009 | Combi Centre DX - Mango
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Combi boiler no DHW
if the boiler fires when the tap is opened then the diverter valve is working ok it must be a blocked plate heat exchanger which is the stainless steel rectangular block inside the boiler connected to the pump and the mains cold water.
it will be blocked on the central heating part probably with black scale. it is possible to clean out but sometimes it is better to just change the plate. but remember to flush the system as well or the same thing will happen.
Dec 14, 2008 | Water Heaters
Combi Centre DX - Mango Logo
163 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
