Question about HP Photosmart C5180 All-In-One InkJet Printer
Stripes on my pictures
Not colors more like something is dragging. it looks like the cartridge is imprinting on it? all cartridges are installed properly.
Thanks, Erin
Look in the paper delivery tray and there as som thin metalic strips that get bent down dragging on the paper. Bend them back up with a ruler and it goes away. Don't know what they are.
Regards
Mike
Posted on Jan 17, 2009
I'm getting a line that isn't printing through my printing from a Fuji Xerox DocuPrint C3055 DX
Possible reasons are: 1.empty toner cartridge, 2.dirt under one of the toner cartridge's developing roller, 3. dirt on the primary charge roller in the drum cartridge, 4. obstacle on the laser path.
Replace the empty toners first and try printing again. Follow the next steps if it didn't solve the problem.
Print a test page with 4 stripes across the page - black, cyan, yellow and magenta. See if all have the missing toner line or only one of them. If the white stripe is going trough only one color, inspect the cartridge with that color. It has to have the same stripe on the developing roller. See if there is some dust beneath it that makes the stripe and clean it with a brush. If the stripe is across all colors, then inspect the drum unit. The drum itself has to be evenly shining on the light. If there are uneven matte tracks on it, consider replacing. There should be a gap somewhere for the laser beam to pass and the drum is visible trough it. Look trough it for obstacles like piece of paper or hair. The primary charge roller has to be close to that gap inside, touching the drum. Look for dirt on it. Clean if possible.
Toner cartridges last approx. 6500 pages. The drum cartridge lasts between 14 000 and 28 000 pages depending on the color use.
Jul 02, 2014 | Digital Products Office Equipment &...
Persistent cartridge error
Gently clean the contacts in the carriage, and on the cartridges with a paper towel or coffee filter moistened with water.
For the poor print quality or missing print:
Perform the Blot Test
Remove cartridge from machine, fold a paper towel back over a couple of times so it is about 4 layers thick, shake cartridge up and down hard, shake it over a sink unless you want to clean ink off the floor.
Now blot the nozzles of the cartridge on the paper towel, for a black cartridge you should see two black stripes, for a color cartridge you should see three colored stripes, if you don't have all stripes the cartridge is clogged or bad.
Have you checked the expiration date on the cartridges you are using?
Are you installing new HP cartridges, or refills?
You may be able to recover a clogged cartridge by swishing the tip in a saucer with a very small amount of warm water, then gently wiping it on a wet paper towel, be gentle the nozzles are delicate.
And do not trust the ink gauge on the PC, cartridges can dry up from the machine just sitting, the cartridges are vented, venting is necessary to let air in so that a vacuum won't develop in the cartridge.
Mercedes Parts.
May 25, 2012 | HP Photosmart 5510
Prints in stripes
Hello ron.. Epson printers are engineered to print stripes when you use generic printer cartridges. That sounds like your problem. These printers have a chip that will detect if it is generic. When using generic cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. Joe
Thanks for choosing Fixya!
Dec 08, 2010 | Epson Stylus DX4200 All-In-One InkJet...
Keep getting right cartridge incorrect. what does this mean?
For the check cartridge error:
And do not trust the ink gauge on the PC, cartridges can dry up from the machine just sitting, the cartridges are vented, venting is necessary to let air in so that a vacuum won't develop in the cartridge. get more information and help for HP Printer Ink Cartridge .
Sep 01, 2010 | HP PSC 2110 Color Printer
I have just replaced the color ink cartdrige in my HP Deskjet 722c printer and I tried to print a color picture in bond paper and it was a total mess
A new ink needs a little cleaning before using. Just dab lightly on a damp paper towel and look for a inch log stripe of each color on the towel. If all colors are not there it won't print very well and you should return the cartridge. Some have reported no yellow in their new cartridges.
Jan 08, 2010 | HP DeskJet 722c InkJet Printer
Cannon multipass F60 scanner/printer striped color printing
What you have is a dried up color cartridge. You can try to use the <clean print heads> in the diagnostic tools section of you priner software. (usually, just try to print something & the window will appear) Sometimes you have to clean heads, then print test page like 2 or 3 times before it clears up. If that doesn't correct it, don't worry. Have your color cartridge filled (staples, office depot, & other stores do it cheap) - or - replace it with a new cartridge. You may have to run the clean print heads program after installing a new cartridge, but this will definitely fix your problem.
Jul 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
Pictures are printed with stripes and poor color
make sure your printer printed an initialisation or alignment sheet once you installed the new cartridge.
you can try a partial reset of the printer and check if the printer prints fine,also there is an option of cartridge calibration in the printer properties or the printer software installed in your computer
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printer will only print color pictures in black and cyan
Hi, this printer color cartridge contains all colors in one. So if you can print with one color means that the whole cartrige is ok but one or more colors ended. And you should had a low ink message on screen if it was genuine HP. Best thing to do is to go and buy a new one cartridge and see how it will go. This cartridge is green color.
Sep 05, 2017 | HP Photosmart 2575 All-In-One Printer,...
Losing Ink
Depending on how many times you have refilled the wells of the cartride the sensor inside may be going bad as the manufature of the cartridge only intended it for a one time use. My recommendation would be to buy a off brand compatible and refill those.
Mar 07, 2008 | Canon BJC 8200 Photo InkJet Printer
HP Deskjet 6980
Take a look to see if the printer Cartridge Carriage belt is hung up
or something else is jambed.
Sep 12, 2007 | HP PSC 2110 Color Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
Ben Johnson
