Question about Coleman Powermate Powermate 5000W Generator
Homelite LRI 4400 Home Generator-No output
3rd year of limited use, all of the sudden no electical output. have reset all GFI's and reset buttons.
I have a couple of new rectifiers, but don't know if that is the problem or where they go.
Ideas?
Does anyone know how to clear error codes for a honda es6500 generator
Depending on generator the error code is a wrong set governor, or a GFI on the electric side of unit. Push the reset button on the GFI an that should clear it. If not you will need a dealer.
Jan 27, 2015 | Honda Cars & Trucks
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
May 13, 2014 | Briggs & Stratton Briggs and Stratton...
Homelite LR 4300 generator only supplying 230v, even at the 120 outlets
Make certain the voltage switch is set to 120 volts, not 230 volts.
If you lost your user manual, you can download on in the link below. Just click on the "open as PDF" button and it will download t your computer. http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/electric_generator.html?p=16
Dec 20, 2017 | Electrical Supplies
Mitsubishi MGE 6700 generator. Starts and runs fine, but no longer putting out power. What would it cost to repair this issue?
These generators have a GFI outlet on them, and they do fail. I would suggest you check all output circuits and see if you have any output. If so, pull the GFI and see if it is getting power to the outlet. If so, replace the outlet.
Feb 20, 2011 | NEC Mitsubishi MGE 4000 Generator ROU...
Just up graded from a homelite 4400 to a craftsman 5600 generator 5600 does not have enough output as did the 4400 why
Some manufacturers tend to fudge the numbers and throw around the 'peak' output power as continuous and it isn't. Peak (or surge) is the power a generator will handle as starting current (for example) for a motor and can be 120-140% of the actual continuous power.
Check you owner's manual, find the detailed specs which will normally contain the maximum continuous current rating. If it is listed separately for 120 and 220 (240) volts look for separate current ratings for each output.
By multiplying the current(s) times the output voltages you can find the total resistive output into a purely resistive load such as an electric heater.
For example: 120VAC X 20 A=2400 watts. If other outputs are available such as 220VAC, multiply its current rating: 10A. or 2200 watts Adding those two results 2400 2200=4600 watts will give you the rated power of a unit.
You can also recognize stupid power claims if the engine's horsepower is given. One (US) HP = ~746 watts. Since no generator is 100% efficient, its a fair rule of thumb to guesstimate the available electrical power at ~70% of the engine's rating (although, this is often also wildly optimistic). 10 HP X .7= ~746 X 7 or a bit over 5,000 watts.
Oct 03, 2010 | Craftsman Electrical Supplies
My dishwasher hasn't been working for a while... It's plugged in and the breaker isn't tripped but it wont work the lights on the front aren't even working
fire her ****!! and send her packing and find a new one LOL there is however a reset button under the front you can try to see if that helps
Jan 14, 2010 | Dishwashers
When i plug anything to the generator it does not work
Try replacing the receptacle the 2 gang GFI unit can go bad, you need a 30 amp GFI female plug and can be bought at any hardware store, but be sure it is rated 30 amps on less, also try hitting the red reset button and the GFI button to reset.
Aug 16, 2009 | Coleman Powermate Portable Generator...
No output from my generator
check breaker, your outlets should be like a gfi
May 21, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Powermate 5000W Generator Logo
1,250 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
