Unable to connect to didg box
We have an LV 85E tv and are unable to receive signal for didtal tv through a digi box
chrispurs1
  • 372 Answers
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Posted on Jan 31, 2008
  • 3 Answers
SOURCE: unable to get signal input when i connect my pc
There are several fixes for this problem.
1) You can unplug the TV for a few minutes and try again.
2) You can turn off the TV then hold the Power button down for at least 10 seconds (resets the processor)
3) Go to the settings menu, select factory reset.
Good luck
Posted on Jun 11, 2009
budmrtn
  • 11361 Answers
SOURCE: ordered proscan 32LB30QD from Costco. The coaxile
Costco has very good return policy within 180 days, I would try to get the exchange unit instead.
Posted on Jan 06, 2010
SOURCE: Connecting to HD TV
This TV has no HDMI input socket. It Has a DVI input socket. Therefore you will require an HDMI to DVI converter adapter or an HDMI to DVI cable. The DVI is video only so you will require audio cables from your Sky box (Audio L and R ) which will connect to the back left of your TV (Audio L/R sockets next to the s-video and component video connectors)
Posted on Jan 28, 2010
  • 8457 Answers
SOURCE: Hooked my L32HD35D to a digital cable box. TV
Try it with the HDMI cable.The RCA component cable some time it don't work.
Posted on Jun 28, 2010
Iam unable to find why the tv is skipping from channel 2 -9leaving us unable to view 3/4/5/itv2.Is ther a possible transmitter fault
Your TV may be unable to detect the presence of a signal on those channels. Retuning could be necessary.
Dec 22, 2017 | Televison & Video
Re: tv unable to program channels
Hm..
So you want to connect your receiver thing to your tv ?
or your cable ?
Well if the antenna cable is hooked up, you should be able to simply run it up behind your tv and put it on the antenna plug.
The reveiver should attach to your tv with a cable provided.
Dec 27, 2007 | Televison & Video
Digital tv recorder
No, I don't think that is the issue... I don't think a TV exists that is incapable of decoding an analogue signal. We need more information about how your TV is connected... do you have cable or satellite? Do you use a cable or satellite "box"? How is your cable/satellite (if you have) box connected to your TV?
Oct 18, 2013 | Televison & Video
I m unable to watch live tv on my cell phone nokia c2-01 3g
I believe you did not follow the right setting that was why you were unable to watch live television on your phone please follow the setting given below and you will be to watch the live tv on your phone.
The Hauppauge Digital Broadway Box can be a small stand on your own gadget that connects to any Television signal and streams live Television wirelessly to your cell system.
Television signals could be connected to the box via: cable Television, satellite set top box, antenna or TV coax cable. Once the Television source is attached connect the box in your Wi-Fi network and then open a browser on your device to begin viewing from http://distan.tv
Regards
Jul 08, 2011 | Lands Phones
How do you connect the digi box to tv and vcr
Put the main aerial into the digi box,connect a fly lead from the other connection on the digi box and plug it into the vcr,then take another fly lead from the vcr and plug into the tv,connect the digi box to the tv with a scart lead.
Dec 12, 2009 | Televison & Video
Unable to connect to Digital satellite receiver
I threw the mitsubishi VHS recorder under a bus, just like ' YOU CHANGE , CHANGE ,CHANGE FOR MY SAKE'S' grandma, and invested in a new DVD recorder, 2 yr g'tee and latest tech. GODDAM A--- well old grandma and anyone or anything else that gets in my manical lust for power. CHANGE EVERYTHING FOR ME, ME ME, ER UM US US US.
THANKS FOR YOUR TIME GUYS.
Aug 20, 2008 | Mitsubishi Televison & Video
DVD recording.
Sounds like the DVDR is recording from the digi-box through the TV, so when the TV is switched of or into standby the signal is lost, causing the recorder to pause.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
Feb 05, 2008 | Philips DVDR3380/05 DVD Recorder
Unable to get HDMI signal into TV
In the setup guide, try going to the HDMI option where you turn the montior out to "on" for the HDMI output. I don't believe that the receiver comes with the HDMI out already turned on...
Dec 31, 2007 | Onkyo TX-SR605 Receiver
Problems with DVD/VCR Player and Tivo
How are you attempting to connect this? Can we get more information, such as your TIVO model and TV model?
Jan 13, 2007 | Zenith ZRY-316 Video Recorder
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
