I can access cameras from laptop at home...but I can't access from other locations...It's set with DHCP...and I'm trying to connect using the IP address for the unit...just as I do at home...but it's saying there is a firewall or other device that is blocking remote access?
i got the swann security system and right whan i plugged it in the tv screen starts rotating. its...
(More)
i got the swann security system and right whan i plugged it in the tv screen starts rotating. its not a still screen
I just spent $600.00 on a what I thought was a new cctv camera and dvr. only problem is the manual...
(More)
I just spent $600.00 on a what I thought was a new cctv camera and dvr. only problem is the manual is in spanish and the other is in french. I called frys and they tell me i need to contact swann security. I went to there web site to try and download a manual, but to no prevale. The system is a sw242-6t4. Now i know I can contact swann on monday and they will send me a copy, but you know how it is when you spend $600 bucks you kind of want to play with it now. If you think you could help me sooner please do.
swapped the cameras around on the inputs and now when i press any button it comes up with key...
(More)
swapped the cameras around on the inputs and now when i press any button it comes up with key locked.
I am having problems with my Swann Pro Net DVR's resolution. I am trying to get the cameras to work...
(More)
I am having problems with my Swann Pro Net DVR's resolution. I am trying to get the cameras to work outside, but when I record from the cameras straight to video the quality is OK. When I try to record to the DVR the picture is all pixelated. Are there known resolution problems or anyway to stop the pixelation?
I have a swann Camera Model sw231-wdc, i mounted it on a 360 degree swivel base,wires were frozen...
(More)
I have a swann Camera Model sw231-wdc, i mounted it on a 360 degree swivel base,wires were frozen and pulled apart. While putting the wires back together, a blue wire came a loose and i don't know where it goes. If i had the wiring diagram i could fix it. Thanks Ronnell..........
