Question about Whirlpool GH7208XR Convection / Microwave Oven
Cook Light Stays On and Microwave doesn't work
Clock Works, Fan work on all 4 speeds, Lights work on every setting and the control pad seems to function with navigation correctly but... the cook oven light stays on and trying to test the microwave with a coffee cup of water, it will not turn on!
Door seems to close correctly, that was my first thought!
  • My2CentsWorth
    My2CentsWorth Dec 21, 2008
    This was all great information. I was hoping to have some insight on what the problem might be because the microwave is brand new. It was just installed on Saturday and I already have a call placed into Whirlpool for service. I don't think I want to try solving this problem on my own because I don't want to void any warranty. Thanks again for your solution, I think you are right on and hopefully we can have this problem fixed before Christmas. You never realize how much you use a microwave until you can't use it!
    When the problem is solved by the Whirlpool service man, I will be adding an additional comment and hopefully providing a FixYA Top Rating! Thanks again.
  • Anonymous Mar 12, 2014
    water saturated the controls and now the controls do not work correctly. How can I reprogram the microwave controls?
  • Whirlpool Master
  • 9,098 Answers
You're close.
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel,
we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Posted on Dec 21, 2008
  • William Miller
    William Miller Dec 22, 2008
    Okay, thank you.
    If I had known it was under warranty I would have suggested contacting the manufacturer or an authorized servicer.
    I look forward to hearing what the servicer finds.
Lite stays on,clock works, timer works, but keypad will not set to heat
It could be the pads themselves. The touch pads are notorious for going bad. The light staying on could be a bad door switch. Check there first. There are three switches in the door interlock assembly. One of them could be causing the unit not to reset so it can cook.
May 03, 2015 | Maytag Microwave Ovens
Would like specifications to JVM1850SM2SS
  • 1.8 CF Oven Cavity
  • Electronic Touch Controls
  • 950 Watts
  • Display On/Off Yes (option pad)
  • Add 30 Seconds Instant-On
  • Cooking System CircuWave®
  • Defrost - Auto / Time / 1 lb. Quick Defrost
  • Delay Start
  • Express Cook Instant-on 1-6 minutes
  • Instant On Controls
  • Micro / Time Cook I & II
  • 10 Power Levels
  • Wire Oven Rack
  • Cooktop Lighting - Bright/Night/Off
  • Demo Mode
  • Interior Oven Light - Halogen
  • Night Light (option pad)
  • Child Lockout
  • Easy Mount Installation
  • Exhaust Fan 3 Speed Plus Boost (315 CFM)
  • Cooking Complete Reminder
  • Timer (On/Off)
  • Reminder (24 hr)
  • Sound Volume Control - 4 levels
  • Sensor Controls
  • Beverage Instant-On
  • Popcorn Instant-on
  • Potatoes Instant-on
  • Reheat Instant-On
  • Sensor Controls
  • Vegetables Instant-on, 3 pads (canned, frzn, fresh)
  • SmartControl System
  • Clock Plus AM/PM pad
  • Concurrent Programming
  • Custom Pad
  • Electronic Scrolling Digital Display - 2 line
  • Help Pad
  • Variable Scroll Speed - 5 Speeds (Options Pad)
  • 14.25 " Turntable - Glass Recessed
  • Turntable On / Off
  • 2 Wire Oven Racks; 2 Positions
  • Recirculating Charcoal Filter Kit JX81B
Dec 15, 2014 | GE Microwave Ovens
My microwave turns completely off... Touch pad and lights inside... I have to wait 10 seconds to 10 minutes and then it turns back on and will ask if you want to set the clock. Sometimes it will let me...
Hi Ben,
This has got to be an intermittent power to the control PCB problem. The control board asking to set the clock means that the CPU has been reset by losing power. First, make sure that the problem is not the outlet by plugging in a small lamp or digital clock to see if it works intermittently or resets. Leave it plugged in for at least 24 hours.
(If using a lamp, put in a small 20 watt light bulb or CFL).
It could also be a bad connection to or at the fuse holder in the microwave oven. If all of the wiring and connections look good, it's most likely a bad connection on the control PCB probably around the transformer on the board. Be careful.......
Oct 22, 2013 | KitchenAid KHMS2050SSS Microwave Oven
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
I need the specs (size, height, width etc) for the GE Spacemaker XL Model#JVM1631WB 004
Specs are:
Capacity
Oven Capacity (cu. ft.): 1.6
Features
Wattage (IEC-705 Test Procedure): 1000
Cooking System: CircuWave™ Plus
Power Levels: 10
Style: Over-The-Range
Clock: Plus AM/PM pad
Electronic Scrolling Digital Display: Yes
Electronic Touch Controls: Yes
Kitchen Timer/Timer (On/Off): No/Yes
Variable Scroll Speed: 5 speeds (sub-pad w/ AM/PM)
SmartControl System - Concurrent Programming: Yes
SmartControl System - Help Pad: Yes
Beverage (Convenience): Yes
Cook (Convenience): 9 Codes
Popcorn (Convenience): Yes
Reheat (Convenience): 6 codes
Add 30 Seconds: Instant-On
Child Lock: Yes
Cooking Complete Reminder: Yes
Defrost Type: Auto & Time
Delay Start: Yes
Display On/Off: sub-pad w/ zero
Express Cook: Instant-on 1-6
Reminder (24 hr): Yes
Time Cook: I & II
Time Preference: Control Enhancement (1/9)
Turntable: Glass
Turntable On/Off: Yes
Turntable Size (in.): 13-1/2
Cooktop Lighting: Bright/Night/Off
Night Light: Auto
Rack Type: Wire Oven Rack
Sound Volume Control: 4 levels
Easy Mount Installation: Yes
Exhaust Fan: 2-Speed
Appearance
Case Color: Black
Color Appearance: Stainless Steel
Door Color: Black/Stainless Steel
Handle: Designer-Style
Weight And Dimensions
Approximate Shipping Weight: 63 lb
Overall Depth: 15 5/8"
Overall Height: 16 3/16"
Overall Width: 29 7/8"
Cavity (W x H x D): 20 31/32" x 9 3/8" x 14 3/16"
Power/Ratings
Electrical Input - 120V Amperage: 15
Electrical Input - 120V Watts: 1480
Frequency (MHz): 2450
May 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
No power to GE Spacemaker Microwave
I have model GE Microwave serial # JVM2070SK02. I start to cook something and it shuts off 5~10 seconds. Keyboard is still lit up, but no clock, fan, light and you cannot operate anything on the key pad. Unplug the unit and it resets. Sometimes it cooks, sometimes it doesn't? It is getting more frequent with the shutting down problem?
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can't use the microwave at all
you have either a bad keypad or control board.
If you have operation of some buttons and not others its the keypad. if you have no operation out of the buttons at all you have a bad control board.
If you turn your microwave on and it sets and the timer counts down you have a bad interlock switch..
please let me know exactly what your microwave does when you set the cook time
Jan 08, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Nov 09, 2008 | GE JVM1190 Microwave Oven
Whirlpool GH7208XR Convection / Microwave Oven Logo
269 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
