Question about Brother MFC 240C All-In-One InkJet Printer
Paper jam and subsequent printing trouble
I was printing an order confirmation from my email when the paper suddently got sucked back into my Brother 240C All-In-One.  A paper jam notice came up.  I removed the back cover and removed as much paper as possible.  Next I lifted the top and removed the rest.  Since that time, I'm unable to make a clear copy of anything.  It comes out "shadowed," like two lines of print are on the same line.  I've only used this all-in-one a few times.  HELP!!!!!!!!!!!!!!!
    Problem Solver:
  • 8 Answers
Drmacee1,
Try uninstalling your printer and then reinstall this also clean this might help also fan your paper before putting into machine. Hope this helps
Posted on Dec 23, 2008
What's your problem?brother mfc-j6710dw paper jam
I had problem with Brother MFC-J6710DW complaining about paper jam. Went through whole paper jam procedure a few times with no avail and no visible paper jam anywhere. Found (googled) this to be a common problem for this device. Turn off / on didn't help either.
Finally ... I followed procedure to the letter, bowed possible dust away and ... pushed tray 1 all the way in. (It turned out it was not all the way in when I first started troubleshooting, and was pushed to the same inadequate position subsequently.)
This MFC is low-cost. Meaning it has few sensors, and subsequently is not very precise reporting errors.
Remember: "paper jam" alert may mean something not on exact place it should be, with this otherwise (so far) good value for money MFC.
Mar 26, 2012 | Brother MFCJ6710DW All-In-One InkJet...
I have a Brother MFC 240C. After I removed paper from a paper jam the printer reads: Print unable 50. See Trouble Shooting and Routine Maintenance chapter in User's Guide. I tried to look this up on...
You may encounter a paper jam while working with your Brother printer. You need to be cautious while feeding the paper to your printer. Paper jams are often obvious, but you might come across a situation when you do not get any indication that the paper has jammed up the printer. In such cases, you need to open your printer and visually inspect it to search for the jammed paper. If the rollers of your printer are leaving marks on the printouts, then there is a need to clean them. Using chemical cleaners such as benzine, thinner, or alcohol to clean the rollers might prove hazardous to your printer.
Nov 09, 2010 | Brother MFC 240C All-In-One InkJet Printer
I was printing an order confirmation from the computer when the paper suddenly got sucked back in to the printer.  I got a notice of a paper jam.  I opened the back and removed as much as possible.  Then I...
hi!  try this.  go to start menu, then select control panel, then select printer, then right click your printer model, then select properties, then click maintenance, then select nozzle check. if still didn't work out, try deep cleaning 3x. if still doesn't work out, try setting your printer properties to a high resolution.  have a nice day!
Dec 20, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother 2040 paper light .. continuous red
If you removed a piece. But more remains it must also be removed. Look closely along the paper path for something that will release to provide access to the path.
May 03, 2017 | Brother HL-2040 Laser Printer
Printing troubles
Paper jam:
Clear the paper jam. If the printer does not start printing, press the control panel button.
No paper:
Put paper in the printer. Then press the control panel button.
Misfeed:
Put the paper back in properly, and then press the control panel button. The printer will start printing again.
Mar 24, 2008 | Brother HL 1440 Laser Printer
Paper LED Blinking
Did you see http://www.fixya.com/support/r310860-lights_indicate
The Paper LED is flashing.
papereroor2.gif Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, click here.
Clean drum unit:
The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Jan 04, 2008 | Brother HL-2040 Laser Printer
No paper fed
I'm guessing that little piece of plastic has something to do with the paper sensor.  You may want to open that section and set it back the way it was.
Oct 27, 2007 | Brother Multi-Function Center MFC-240C...
Brother printer jams all the time
Be sure the paper tray is not over full and maybe even fan the paper before loading. Check all the corners that hold the paper as they are usually adjustable for different paper sizes and sometimes move or become unattached. The paper must lay flat and snugly in all places in the tray to load properly.
Mar 28, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 240C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
