Question about Garden
Stripped bar stud
Stihl ms 440 magnum chain saw and one of the bar studs is stripped, now bar and chain do not tighten properly..is there a fix besides replacing crankcase?
    President:
  • 1,388 Answers
Many Sthil chainsaws have replaceable bar studs. The stud threads into the case. Go here: http://www.baileysonline.com/itemdetail.asp?item=QA+0000+953+6605&catID=407
look for part by model number, usually no more than a few dollars. Enjoy
Posted on Dec 21, 2008
The threaded sleeves for the studs that hold the guide bar are stripped. What can I do to repair them?
remove bad studs with stud extractor and replace with new ones ?? or maybe normal bolts ?? (if in engine housing )
or in a bind ive even rethreaded them to fine thread (assuming course was old thread) with a die and used std fine nuts on them as well .
if studs go in plastic case/frame then case needs to be disassembled and then studs press out other direction
Mar 16, 2015 | Garden
I have a Stihl MS 290, runs great, but the chain keeps tightening it's self on it's own
That's an unusual problem, usually the opposite happens. After making sure the chain brake is off, loosen the two nuts that hold the bar. Be sure to hold the bar up when adjusting the tensioner screw and adjust until the chain is just snug, but not too tight. While still holding the bar up, tighten the two nuts firmly. Check to see that the chain can move freely by hand. Then start the saw and run the chain at speed with something in front of the nose to check for adequate lubrication. You should note a slight fine spray of oil on the object in front of the nose of the bar. Inadequate lubrication, a chain that is binding on the bar, or an overly tight chain can cause the bar to heat up and expand, further tightening the chain. A properly adjusted Stihl saw will use almost all of the chain oil in the reservoir for every tank of gas. Too much oil is better than too little. The oil feed may have to be adjusted for operating in temperature extremes. If operating in very hot conditions, be sure that the saw has not run out of chain oil. The oil feeds faster when hot.
Sep 19, 2014 | Stihl MS 290 Chain Saw include 20" 50cm...
My chain wont tighten on my stihl 044 chainsaw
Assuming you have the right length chain and its not just running out of adjustment, it would then probably be a stripped or snapped chain adjuster. Can be coursed when the bar nuts aren't dun up before starting to cut, the force of the chain saw will snap an adjuster no problems. If its striped it might smear like its adjusting in but when it gets to a point it will just stop
Nov 20, 2013 | Stihl 440 044 460 046 Chainsaw Clutch Drum
How do you tighen a chainsaw chain?
Depends on the chainsaw. On most Stihl saws there is a screw between the two bar locking bolts that you turn clockwise to tighten the chain. On other saws the screw is in front of the housing that the bar and chain come out of and face into the housing, parallel to the bar. Clockwise still tightens the chain.
In both cases you have to loosen the nuts on the guide bar studs and then adjust the tension adjustment screw.
For more info go to the manufacturer's web site and download the owners manual.
Oct 24, 2011 | Craftsman 16" Electric Chainsaw Chain Saw...
Looking for the studs that holds the bar in place. There is 2 of them that screws into the MS 310 Stihl chainsaw
You have to go through a Stihl dealer or some one that sells that saw. there are some places i have gotten parts on line but its much quicker if you go to the sellers of Stihl saws
Jan 08, 2011 | Stihl Garden
Where is the oil discharge hole on silver eagle 250-14?
If you take the bolts off the studs that the bar sits over, the ones you loosen to tighten the chain, you can then take off the housing over the chain sprocket. Loosen the chain adjusting screw, Pull the bar and chain off of the saw. The oil discharge hole is behind a plate on the back side of the bar about where the studs for the bar are. There is a small hole in the bar that the oil is injected into. This needs to be kept clean for the chain oiler to work properly.
Dec 02, 2009 | Hardware & Accessories
How would I replace the bar hold down stud bolt in my Stihl MS 310 chain saw? Thanks.
At our dealership we replace the Bar studs with Heli-Coil and locktite for $20.
NOTE: Remove the old stud by double-nutting and screwing out of the case and marking the end that came out. Take it with you to NAPA and get the correct Heli-Coil size and a small tube of BLUE Loctite. (Might be cheaper to let the Stihl dealer do it)
Hope this helps!
Sep 27, 2009 | Garden
Bar stud removal
only had one 20 years ago they were right hand nut side an left hand into block//used the two lock nuts tightened together to pull studs//like over tightening the lock nuts clockwise breaks stud threads loose ..install new same
Mar 16, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Stripped bolts
sounds like the bar stud is stripped out in the case. you might have to have a thread insert, like a Heli-coil, put in.
Mar 09, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
1,132 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
