Question about Fender (26741099) Microphone
Roc pro 700 fuse always breaks
Hello the fuse is always breaking i replaced the darlington power transistors( motorla)tip 142 and tip 147 (where shorted)by tip142 and 147(italian made )the amp worked for 10 min (the transistors where to hot )and shorted again ,then i replaced them with
( St )tip 35cand tip 36c this time the amp worked for 15 min can someone help with this? i checked all the resistors can u help me plz by giving me the exact equivalent transistor for the tip 142 and 143? what do you think the problem is?
2 Suggested Answers
  • 732 Answers
SOURCE: my amp breaks up too
colearthur16, Only a slight chance of problem with your speaker. You will need to prove that all stages of amplification of the audio signal from input to output are not being driven into distortion (clipping) because of a bad DC power supply rail to the low level amplifiers or the high power "final" output amp! To prove this, you will need the help of an electronics technician who has access to a variable audio signal generator (amplitude and frequency) and a cheap 5 to 20 megahertz oscilloscope to view the amplified waveforms of the amplifier stages in the Fender Amp. Remember the following statement for the rest of your life!!! "All musicians who use electronic amplification to play musicial notes through speakers should have between 4 and 8 hours of classroom instruction on how typical amplifiers (tube and solid state) operate and how to troubleshoot them when they fail to perform to rated specifications!!!"
Cole, have the Fender amplifier (not the speaker) tested by a qualified technician to prove amp is not at fault!!! 12fixlouie
Posted on Nov 08, 2010
Stage 100 blowing fuse,loud hum
Hi,If your blowing fuses then the problem is most likely to be faulty bridge rectifier or darlington output transistors.All readily available and not too expensive.Circuit diagram on Fender site or net easily found.Thanks Fender good customer service.
Oct 16, 2013 | HHB Radius 50 Tube Amplifier
Qsc mx 700 keeps blowing fuses after replacing all transistors with replacement parts not original
Have you replaced the IC , Q2 and Q2?
• Check the Differential Inputs ( IC1 ) and sorrounding components
• Check the Driver Stages
additional guides or suggestions:
Cross wired speakers and blown power transistor.
Beware also of counterfeit Power Transistors
Aug 05, 2012 | Audio Players & Recorders
Will not turn on
Try connecting the unit to the PC see if it powers, with 7xx series often the powered cradle will break so the unit dosent get power. A replacement can be obtained here
Hope this helps!
Feb 23, 2011 | Garmin nuvi 780 GPS
I have a problem with Behringer mix ( UB 1832-pro) does not work multi-efects. I need a power supply plan. This link (
Try this link:
On page 11 is the power supply. The TIP31 (T1) is the regulator for the +15 volt rail. The TIP31 is connected as a Darlington with a BC846 (shown on the schematic as "846"). This is a surface mounted tiny transistor.
NOTE: This regulator is NOT a voltage regulator but is actually an ACTIVE ripple filter consisting of the 2.2K resistor (R6) bypassed by the capacitor C4 (100mfd/25v). R8 (120 ohm) serves as a parasitic suppressor and base surge current limiter for the BC846 transistor (T4).
Feb 23, 2011 | Behringer Xenyx 1832fx Mixer 18 Input 32...
This is a Wagan 2003-6 400Watt with USB DC to AC Inverter. Worked great for almost a year. Recently fan was varying in speed under load. Then finally blew my vehicle cigarette lighter receptacle fuse. ...
A few thoughts on this. With the transistors, if these are a darlington style of transistor, it might show a short on a good transistor. The USB "transistor" is a voltage regulator, 12v to 5volts dc. With the inverter input, some inverters use a diode in the input to protect against connecting the inverter by reversed leads. This diode might be shorted and be causing your problem. If it comes to changing the transistors, it might be cheaper in the long run to buy a new inverter. The transistors might be problematic and might not be the only thing problematic. Experience here talking!
Feb 05, 2011 | Wagan 20036 400 Watt Power Inverter Corp
Unit will not power up
check fuse in power cord if using in car adapter. unscrew the silver ring at the tip of the cigarette plug DO NOT ALLOW THE SPRING TO SHOOT OUT WITH THE SILVER CONTACT PIECE INSIDE! remove the spring and contact piece then remove the fuse, look to see if it is scorched, you will either see black soot on the glass or a break in the wire that runs through the glass tube. Hold it up to the light. See if you can tell where the brreak is. Sometimes the break is at the verry top and you cant see so just replace the fuse with a new one form the hardware store, ETC. replace fuse spring contact tip and retainer ring then plug in and try again.
Nov 29, 2009 | Delphi Roady XT XM Radio Receiver
My samsung dvd/vcr v5600 will not power up.
Hi and welcome to FixYa,
Almost always, your described problem indicates a blown fuse inside the DVD/VCR combo. Exact location would depend on the model and regional version. What is common to all is that it would be immediately after the power cord as it enters the combo unit.
Some ideas to further guide you if the fuse is glass tube type:
  • if the break of the fusible wire is clean, then it would be relatively safe to simply replace;
  • if however, the glass tube is darkened with burnt marks, then there would be some other components defective such as the regulator transistor and/or filter capacitor.
Good luck and thank you for using FixYa.
Feb 21, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Receiver died out
Maybe a fuse in amplifier section is blown out already,caused by busted four darlington transistor or if this amplifier use a STK IC. This is the common problem of the amplifier,try to check this if ever a defected then replaced it with a identical rating.
Hope it may help you;
Jan 08, 2009 | Arcam AVR-200 Receiver
PS3 Nothing..No Power Light.. Nothing
Hi there, by the sounds of it you could have faulty fuses, Whether its inside the console itself or inside the Power adaptor its Uncertain. Before opening up Your PS3 i would suggest Checking the fuse in the power adaptor to make sure that is not fried. if it isnt. then it must be something to do with the power input to your PS3 Device. it could be either the Fuse or The transistors on the Power input Circuit. When you Pop open your PS3, Go straight to the back-end where the power input is located, and see if any of the fuses or transistors look fried, if they are. then that is where your fault lies !
Oct 27, 2008 | Sony Playstation 3 (PS3) Console
Fender (26741099) Microphone Logo
85 people viewed this question
Top Fender Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rick Moore
Rick Moore
Are you a Fender Audio Player and Recorder Expert? Answer questions, earn points and help others
