Question about Frigidaire FGF326AS Gas Kitchen Range
F 31 Frigidaire gas range
We had oven temp probelm had tech out he put in a bake ignitor. still having oven temp problems cooler than what set at. now we are getting a F 31 error code even in th middle of the night it beeps what is a F 31 error code
  • Frigidaire Master
  • 3,408 Answers
If it cooler that the temp set its the theromstat f31 sorry don.t know
Posted on Jan 05, 2009
Neither oven or broiler work. Upper elements work well. Why is the bake light flashing / blinking?
if it is not coming on then you may have the same problem again with the ignitor.
May 04, 2014 | Ovens
TAKE 1 HOUR TO HEAT UP
Is your range heated by gas? or electric. If gas this tip i wrote will help ya,
What the problem is when your gas oven ignitor glows,but no heat for the... posted on Jul 31, 2011
MessageRate.ThreadID = 9947539; MessageRate.ProductID = 0; oldtech2332.jpg oldTech2332
Rank: Guru
Rating: 95%, 82 votes
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
Aug 03, 2011 | Kitchen Ranges
Kenmore gas range 790.7230 (7240) broiler and oven smell when in use. have to open window or turn on fan to get rid of odor.
The problem with your oven is a weak ignotor, this following tip i wrote explains how to check it
Rank: Guru
Rating: 95%, 81 votes
I hope the helps Gene
Hello when i put my temp for my gas stove on say 350, the pilot is glowing but it doesnt seem to flame/heat up, and i get a somewhat odor of gas, could the therometer need replacing or maybe the ignition...
Your glowbar ignitor part must be replaced, Unplug the range and turn off the gas. Remove yje oven racks, The oven base pan. Then remove the flame spreader. You will see the glowbar ignitor attached to the side of the bake burner. Remove it and replace it with a new ignitor. Replace all the range parts.Turn on the power and turn on the gas supply.
Copy and paste this site for the location of the ignitor you can also purchase the part from them.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=111359&diagram_id=362260#d362260
Jan 01, 2010 | Frigidaire FGB24T3A Gas Single Oven
Oven not baking.
Sounds like the flame failure device is not working . or heat probe is out of position
Aug 07, 2017 | Frigidaire FGF337 Dual Fuel (Electric and...
I have frigidaire gas free standing oven range.When I press BAKE and set the temperature,the preheat and oven lights both lit on the display and I can see the ignitor red but no flame.
If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Nov 02, 2009 | Frigidaire FGF378AC Gas Kitchen Range
Bake does not work but broiler does.
OK, it is likley that the oven ignitor isn't working and needs to be replaced. To verify if this is the problem, when you turn on the oven to BAKE and set the temp at say, 350. Watch through the window, (or you can have the door open). Look at the bottom, back, center and see if you see a bright orange glow appearing under the bottom panel.
If you don't, that is why the oven won't lit the gas. There is an ignitor for both the broiler burner at the top and for the bake burner in the oven compartment.
The reason that the temp display reverts to 100 degrees is because that is the lowest default temp setting for the display and until the oven temp actually starts to increase, it won't change. So the temp display is working correctly for the BAKE function.
Here's a line drawing showing the part you may need. Ignitor Part # WB13T10045. The good news is that your oven uses the same ignitor for both the broiler and bake burner tubes, so you could swap them if you wish to confirm that is the problem before you go and order/buy a new one. These aren't cheap at $91 bucks, but you can shop around the web for a better price if you determine you need one.
Sometimes the ignitor burns out half way through but because it still lits/glows, people think it's OK, but it won't get hot enough to signal the gas valve to open and allow gas to ignite and get the oven cooking.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JGS905SEK1SS&productCategoryId=0124250&brandId=3272&modelName=GAS-RANGE&diagramPageId=00001&componentDescription=GAS%20&%20BURNER%20PARTS&documentId=G6090295&backToLink=Return%20to%20Sub%20Components%20list
Hope this helps you out and remember to disconnect the oven from the electric power before performing any repair work. Best regards!
Aug 01, 2009 | GE Profile JGS968 Gas Kitchen Range
Frigidaire Range - Oven does not work
If your ignitor looks real dull orange then that is what is wrong. It needs to be bright as the sun or it is weak.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2008 | Frigidaire GLGF386DC Stainless Steel Gas...
Low oven temp.
sounds like a bad oven/bake ignitor. very common problem on all gas ranges.
Oct 17, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire FGF326AS Gas Kitchen Range Logo
932 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Justin Duby
Justin Duby
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
