3G USB Modem internet not working on PS3
If I place the 3G USB Modem into my 60GB PS3, the PS3 just doesn't detect it. The light on the USB Modem flashes but even if I go into Network Settings, then into Internet Connection Settings and then select any of the options there it just, in the end, says that it doesn't detect any device, or something like that.As a side note, I have a Compaq laptop with Windows Vista (just in case).
  • 1 more comment
  • Anonymous Dec 31, 2008
    I have the same problem. I tried the seperate cord to see if i could connect it from the computer and then do it that way but it still wont detect it.
  • Anonymous Mar 17, 2014
    anytime i insert the modem on my laptop the device not detect and not lighting
    anytime i insert the modem on my laptop the device not detect and not lighting my modem is zte mf190 s
Erm...cant you just plug in your 3 usb to your pc and connect to your ps3 via the ethernet cable? that should work...but i think the main issue is that it might be too slow to play online...either that or you play online for ten mins and then your done for the month lol
Posted on Mar 14, 2009
  • 3 Answers
When you plug in a 3G USB modem into the PS3 which runs game-os, you should see a message saying it is an unsupported device. As game-os is a closed operating system from Sony, they must make change to their firmware to handle such 3G modems, so you need to ask them to support these modems. If they ever do support 3G modems, expect it to only work with Sony branded 3G phones or modems.
If you have other-os on your PS3, then you could load the appropriate packages to support 3G modems in you linux distribution of choice - but Sony have now removed other-os from PS3 firmware 3.21 and later - thanks for nothing Sony.
Posted on Jul 18, 2010
How to find imei number on huawei ec150 modem
Complete help at:
http://619tips.blogspot.com/2013/07/how-to-find-imei-number-of-datacard.html
Apr 04, 2012 | Computers & Internet
The laptop can not detect device when you try to connect the GPRS 3g
Try connecting it to a different port.
Also check whether your USB ports are working using any USB devices.
If the ports are working and the 3G modem is not getting detected, then you should try replacing the modem.
May 24, 2011 | Fujitsu ESPRIMO MOBILE V5515 V5555 V5535...
My usb modem [lemon 3g] does not get detected. when i plug the modem it does not show anything i.e usb icon detected hardware etc. when i clikc on cmy computer also it does not show any connection why is...
First, check for the power source, there should be a light indicator on the panel of the modem, else, power is a problem, check your adapter/power cable. Next, is use USB cable/USB port, try to use other USB cable/USB port. Another option is to check your Control Panel - Device Manager, see if there is a USB Modem currently installed. Remove/delete the device from your Device Manager. Going back to Control Panel, select Add Hardware. If still fails to detect, your Modem is dead.
Good luck.
TedMac
Sep 18, 2010 | Computers & Internet
I am using airtel MMX300G 3G USB modem ,but its
go dlink easy to use and cheap!! last a long time I have a dlink 524 for the last 10 years works great.
Apr 22, 2010 | Computers & Internet
The internet connection on my laptop is thru a sprint 3g usb mobile broadband device unfortunately tht is my only nternet connection, how can i connect me ps3 with this device
If you have a cross over cable you could connect your PS3 to your Laptop via the Ethernet port and choose internet connection sharing on the 3G device on your laptop, then just make sure the PS3 and the laptop ethernet settings are set to auto detect settings (DHCP).
Jan 01, 2010 | Sony Playstation 3 (PS3) Console
My wnr3500 router will not detect my usb760 modem
Hi, Well, this router will not work with usb modem. For 3g usb modem purchase MBR624GU. Make sure to check if ur usb modem is listed in the compatibility list. Hope this helps.
Aug 10, 2009 | NetGear RangeMax Premium Wireless-N...
Netgear 3G Broadband Router won't connect to the internet
Please note that the USB Modem will not cause issues related to IP address conflict(NAT behing NAT)
You need to mak sure that the USB modem is compatible with this router. As per the compatibility list this modem is comaptible.
http://www.netgear.com/Landing/en-us/3G_uSB_Modems
Please reset the router once and then upgrade the firmware on the router which can be downloaded from thelink below:
http://kb.netgear.com/app/answers/detail/a_id/7210
after upgrading the firmware, configure the router.
Rate it, if it helps.
Jun 26, 2009 | Computers & Internet
NOT GETTING INTERNET TO WORK ON MY PS3
If you have wireless make sure your modem is working if not wireless then make sure your wire is plugged in all the way
May 11, 2009 | Sony PlayStation® 3 (60 GB) Console
Connecting my PS3 to the internet using a 3G Verizon Broadband
Unfortunately the PS3 will not be recieving internet through this device, the USB connectors are set up to only work with PC or MAC specifically for that reason that gamers cannot use their Xbox or Playstation, and that is because Verizon offers a Wireless router cell phone data device which costs almost a thousand dollars, definately not worth it.
Jan 28, 2009 | Sony Playstation 3 (PS3) Console
I connot connect in internet eithernet not ditected
This will work: first thing I'd do is change your DNS settings on the PS3 to the open DNS numbers which are 208.67.222.222 and 208.67.220.220
Dec 18, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
1,527 people viewed this question
David Payne
David Payne
