Question about Frigidaire GLTF2940E Front Load Washer
No spin cycle
Frigidiare front load washer mmodel#GLTF2940E will wash clothes but will not go into spin cycle times out at 7:00 minutes.replaced both control boards no luck.could it be the door switch?
  • kingpin56 Jan 03, 2009
    when the wash cycle is done and goes into spin cycle it dosen't spin at high speed only tumbles the wash so the wash comes out still wet.
    Problem Solver:
  • 10 Answers
Yes, it is the door latch assembly. replace this and you should be good to go. You can get it from an appliance parts supplier.
Posted on Jan 02, 2009
Washer will not spin goes through all cycles but clothes are left soaked
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 16, 2011 | Frigidaire GLTF2940E Front Load Washer
The washing machine makes a lot thumping noise during the drying cycle. Sounds like it is bout to take off. A lot of rubbing during the wash cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Dec 12, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
No spin cycle, stopped running
Hello, sounds like this is going to be a pump issue, take the lower panel on the front off the machine, there you should see something that resembles a gas cap like on your car. It will be located some where near your pump...Unscrew this cap making sure you have some towels handy to mop up the water that runs out. Once you have pulled out the cap attached you should find a filter cage. You will likely find a bunch of debris,coins,lint and other stuff blocking the pump. Replace this cap or filter and plug machine in and try again, You should be good to go. If this does not fix the problem you are going to need to replace the pump. p.s not sure why you are looking to replace the door latch since you mention the machine is not spinning. The door latch has nothing to do with the spin other then locking. Good Luck!! if you have any toher questions or concerns please feel free to comment again. Mike
Jul 20, 2009 | Frigidaire GLTF2940E Front Load Washer
What does "IE" mean when it attempts spin cycle?
is it IE or LE please confirm it. if it is LE code the fixing procedure is given below This usually happens if you're washing on a delicate setting with a moderate load of clothes. Apparently, delicate also means very few items to wash. To clear the LE code - no need to unload the clothes:
1. Press the power button to turn the washer off.
2. Press the power button to turn the washer back on.
3. Cycle the spin cycle selection to 'no spin'.
4. Press start.
The washer should set to one minute, lock the doors, then drain out the excess water.
Once the 'End' cycle comes up, unplug the machine for several minutes.
Plug the washer back in, press the power button, then set the washer to 'normal' with 'low' spin setting.
Note that the only difference between the normal setting and delicate is the wash time and spin cycle speed. If you have a moderate to large load of delicates, use the normal setting on low spin cycle. The clothes really don't care. Also, make sure you're using 'HE' detergent - low suds. Regular degergent in a front load is not recommended.
Jul 19, 2009 | LG WM1814CW Front Load Washer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Kenmore front load washer 417-44082400
My kenmore front load did that just a few months after I bought it. Unfortunately it was the the electronic board {brains of cycles} that had to be replaced. Had to replace it 3 times!! Warranty did cover it. Look into your warranty--at that time the boards were $200-$250 each!!
May 13, 2008 | Kenmore 43042 Front Load Washer
Open Questions:
Frigidaire GLTF2940E Front Load Washer Logo
248 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
