Question about Canon imageRUNNER 8500 Copier
How to replace HDD IR5000??
I want to replace HDD in my ir5000, because old HDD is fault, can some body help me?? how to install new hdd in my machine step by step???
please, send to : yogie_dj@yahoo.com
  • ranvijayk Jan 29, 2009
    where i can find IR 5000 hard disk software
How to clear hard disk IR 5000 and where i can find hard disk software
Posted on Feb 11, 2010
  • 168 Answers
You need a hard drive formatted cor the machine just any hard drive wont work you can get a hard drive from Hytec or nationwide board repair , once you put it in you need to have a computer that has the canon service tool loaded with the system software for your machine .. in other words just switching the hard drive wont work unless you take it from a like machine sorry
Posted on Dec 20, 2008
I nedd Service Support Tools (SST) for canon IR8500.helping manuals ....please send me...
email: nani_nonchock@hotmail.com
Posted on Feb 10, 2010
My machine sharp MX 3100N is giving the error code U2-05, what steps should i use to solve it
This error refers to a discrepancy between the HDD & the machine. If the hard drive has not been swapped out & nothing has changed on the machine then try resetting the copier to see if that rectifies it.
To reset the machine you will need to enter simulation mode.
First, make sure the copier is in COPY mode.
Then press the following 4 keys in quick succession: # * C *
You should then have a screen showing simulation mode.
Then enter 16 & press either of the copy keys (black or colour).
This should then display U2 ERROR RESET.
Press EXECUTE, YES then press the CA key.
The machine will exit simulation mode & restart.
If after restart the machine displays U2 again then you will probably have a HDD fault. Unfortunately, the HDD would have to be replaced by an authorised dealer as new Firmware would have to be reload to allow the machine to recognise a new HDD.
Hope this helps.
Dave.
Jan 19, 2017 | SHARP MX-3100N
00602-003 error
Your hard disk needs to be replaced!! E602-003 is a bad sector read on the hdd, if you restart the machine it may work for a while but it WILL come back.
You need canon part number WM2-5230-000 (not sure how you would get it) it needs to be installed in the back of the machine at the top of the main body after the back cover has been removed.. Once this is done you dilemma begins, Canon uses a program called "service support tool (SST)" which is only a canon issued program, this program is the tool used to update all the software and firmware in iR devices. This can only be connected to a 2200 machine via usb to centronics cable with a "nethawk driver" driving the cable. Then SST need to have the firmware for the 2200 series registered (it does not come together) within SST, then connect cable and turn the machine on at the switch on the right hand side WHILE holding keys 2 & 8 together, this will give you a black screen which only shows "DOWNLOAD MODE" in the lower part of the screen. Then the machine is ready to accept the data. SST is extremely touchy, so if anything is not right you will get a lovely pink screen in SST saying an error code. To correctly set up the hard drive you must first format the HDD from within SST, then install the BOOT and SYSTEM versions (boot must be "N" at the end of it's version eg. 37.44N to be a printer or a stand alone copier will have a "C" at the end. You must pick the right one or you will not be able to print (if it has a PCL kit installed in the machine).
After all Boot, system, language, fax versions are installed restart the machine, wait for a couple of minutes intil all that data is written to the HDD and it will pup up ready to go.
Apr 22, 2014 | Canon iR5000-6000-L1 PS Ver 1.0
Remove password hdd toshiba mk3275gsx
1. The HDD password cannot be removed using Security Assist.
2. Using SETUP BIOS (i.e. start machine; Hold Esc; Press F1), Tab to the HDD Password section which should be displayed as follows:
HDD Password
HDD = Built-in HDD
HDD Password Mode = USER Only
User Password = Registered
3. Tab to the "User Password" field and simply enter the old password and then a new one twice (once to verify) as one would do normally. If you don't want a password, just press "enter" twice.
Hope above steps helps you. :)
Nov 12, 2013 | Toshiba MK3265GSXN - Hard Drive 320GB 2.5"...
How to remove error E000013-000 canon IR5000 Photocopy mashine?
Waste toner feedscrew (locked)It is likely that the feedscrew inside the waste toner pipe is preventedfrom rotating because of some fault. If the outlet of thewaste toner pipe is clogged with toner, remove the waste tonerdrive unit, and remove the toner. If otherwise, try turning the mainmotor clockwise by hand. If the screw rotates, wait and see whathappens; if the screw does not rotate, replace the waste toner feedingunit.
Jan 06, 2012 | Canon imageRUNNER 5000 Copier
I am a new macbook pro owner. My new mac will not recognize my external wd mybook which is several years old. What do I do?
Hello!!
The MAC is not recognizing HDD because it may not be in FAT or MAC OS X Journeled Format.
Please Follow below steps to Reformat the HDD to make it Compatible with MAC.
1. Connect the HDD.
2. Open Disk Utility from Applications -> Utilities
3. On left side of Disk Utility you'll find your HDD.
4. Click on HDD and select the Format TAB.
5. Reformat the HDD in FAT Format.
6. Click Apply.
7. Done.
Hope it Helps..!!
Jul 07, 2011 | Apple MACBOOK PRO WITH PARALLELS NOTEBOOK...
Whether Canon IR5000 printer can be a tool, through the com settings (data). how do I to connect the cable to the machine copies com IR5000.butuh lan similar devices or other connector?
If I understand what you are ask???? You need to know where the ethernet cable goes in to the copier?? The conector is above the main power switch on the right side of the copier.... The print funcation is a option with a IR-5000...... Do you have a ether net PCB installed???? If you do not, you need to get a new boot rom & more ram & the ether port and lastly, you need to have your hard drive flashed to print...... Good Luck
May 18, 2011 | Canon imageRUNNER 5000 Copier
How to reinstall canon IR5000
I have canon IR5000 machine. The data on the HD is corupted how do I reinstall the system software
Jan 24, 2011 | Canon iR5000-6000-L1 PS Ver 1.0
Want to replace 80Gb HDD with a bigger one. How? Do I have to copy everything from the original one to the new one before actually replacing it? how?
Before you change the 80 GB Hard Drive you can take the backup of your hard drive to the External Hard Drive or if you have any sata case so you put your new hard Drive in the sata case and make 2-3 partitions in the new drive and copy your data in the new hard drive except in first partition which will be primary C Drive for your laptop and will replace data when you install windows in it. after the windows is installed and your data is verified in your new hard drive you can clear your old hard Drive or use it as an External Hard Drive (as you like )
2nd thing which is more safer and reliable is that you make backup CD/DVDs for your data before proceed to formatting or even changing hard drives, it will be very useful and helpful for any unforeseen data loss
if you require more assistance regarding this feel free to reply to this post
Regards, BA
Jan 14, 2011 | Acer Aspire 9300 Notebook
Canon imageRUNNER 8500 Copier Logo
2,029 people viewed this question
Clive
Clive
old marine
old marine
