Question about Carrier Heating & Cooling
Carrier 50HX-48-301 icing up. - Carrier Heating & Cooling
  • mvpro Dec 21, 2008
    System has the proper ref., both coils cleaned, new filters, good air flows ofm ifm.
    The DB, looks OK and all connections checked.
    The DFT seems stuck open circuit.
    RSV will change and stay in heat mode when DFT is shorted closed.
    My guess is the DFT but I do not know the specs. to test it.
    The RSV may also be intermittently sticking.
    Tired of climbing up on the roof late at night to find the unit iced or stuck in defrost mode.
    I may have another DFT to put on the outdoor coil to rule that out.
    Thanks.
  • mvpro Dec 25, 2008
    After cleaning all interconects and relocating the sensor (top of OC), the system is working better than ever.
    No cold air during defrost or icing.
    I will see how it works when the outside temps get lower than 45 F.
    It will keep the entire house above 80 F now.
    Thanks,
    Mark
  • 334 Answers
That is caused by either................
bad defrost board/sensor
Low refridgerant.
Lack of airflow.
Make sure you have a clean filter and a clean, unobstructed condensor coil.
Refridgerant can legally be cheched only by an EPA certified tech.
You can test the defrost board in a few different ways, but I need more info from you regarding that defrost board before I can go further.
First check the airflow/filter.
Posted on Dec 21, 2008
  • Danny Clark
    Danny Clark Dec 21, 2008
    I would suggest running a test defrost.
    Jump out the sensor (If installed) and the test points to see if it kicks into defrost. By bypassing the other components you can determine if its the board.
    Isn't the timer installed on the board with your unit?
    Defrost boards go bad on a regular basis.
    Judging by your comments on airflow and refridgerant levels I'd say it has to be the D-board and/or timer/sensor.
    Many technicians replace the timer/sensor automatically when a board is replaced.
Carrier Air conditioners
change filter and clean outside unit with water. pull the outside fuze before cleaning.
Jul 29, 2012 | Heating & Cooling
Heater blowing cool air
Is it set on summer switch which is the fan running all the time blowing cold air
Feb 15, 2012 | Heating & Cooling
Carrier N3 flashes three times (catalogue says "indoor coil sensor malfunction"). How can i fix this??
Hello THECOOL The sensor is a freezestat sensing ice.Try a new air filter.Low air flow is a cause of freezing make sure the intake is not blocked and all the supply outlets are open.
Aug 03, 2010 | Carrier 38CKC042 Air Conditioner
I have a Carrier Heat pump that is iceing up in cold weather and not defrosting properly. Where is the switch to decrease the time between the defrost cycles? I understand there are 3 settings prossible...
switch for defrost is inside condenser your options are usually 30, 60, 90 minutes. you can not decrease times between defrost it is determined by a coil sensor it senses ice on coil and puts unit into be aware that heatpumps are only effecient down to certin temps.the switch you describe is length of defrost.
Feb 11, 2010 | Carrier 38CKC042 Air Conditioner
Inside coil ices over
You have 3 ton unit. Reasons for icing are stopped up filter.dirty indoor coil and low on refigerant. The first two you can do but the last you need a service tech but ask for free estimate first. RUSS
Jul 16, 2009 | Carrier 38CKC036 Air Conditioner
Icing up air conditioner carrier 38tg
check your filter. If its really plugged that would cause to ice up or if its low on refigerant that would also cause to ice up.
Jun 24, 2009 | Heating & Cooling
Carrier heat pump has ice on outside pipe leading to unit. Air not cold inside. Any suggestions???
this is sign of low freon. you have a leak and ice is clogging the interior coils so little or no aire can pass thru it. Cut it off and find the leak.
May 04, 2009 | Carrier Heating & Cooling
Carrier PTAC Condenser ices over.
You are describing normal operation for a heat pump unit.
Feb 20, 2009 | Carrier 52CQ315 Air Conditioner
Heating & Cooling Logo
167 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
