Question about Dryers
Do I need an air vent through the wall for a dryer
When fitting a dryer in my kitchen do need an air vent going from the dryer through the wall to the outside
  • 3,463 Answers
If it is a condenser dryer, then you need no vent at all, as the steam condenses back into water, which is collected in the m/c\so you can place it anywhere.
If however it is a normal dryer, then it is advisable to have it vented.
You do not have to have it vented through a wall if you don't want to, you can hang the hose through an open window or open door,so long as the steam gets out of the dryer.
Obviously it is better if you can go through a wall, then you don't have any pipe to see, but it is not imperative that you do so..Hope this helps you..
Plz rate my suggestions .
Thanks, and a merry xmas.
Posted on Dec 20, 2008
Hoover Dryer Model D6792A. Trying to find a user manual or find out how to use the rear vent once its panel is removed
If I remember correctly, there is a venting kit that you purchase which consists of a fitting to go on the back of the dryer and a large diameter hose which you put out the window or door to vent the hot air from the dryer. There used to be another kit which allowed you to connect to a wall outlet which vents directly outside.
Apr 09, 2015 | Dryers
About to fit a through the wall external vent kit to a westinghouse dryer LD605EB but instructions refer me to the dryer instruction manual which I don't have. Help.
Hi dalys...
You do not need the manual for this problem.
What they are going to tell you in the manual is that you will need to hook the exaust of the dryer to the external vent pipe using a clamp to make sure it does not come loose.
As long as you follow instructions about venting the hot air to the outside of the house then you have done the correct procedure.
Please take time to rate me
Aug 25, 2011 | Dryers
We have question to ask you for Miele Laundry dryer model T4804 C. Our client will install this model in the apartments. They suggest us to connect Dryer vent pipe to the main kitchen exhaust duct of the...
if you use the kitchen exhaust it will ruin the kitchen ducts and forse flow hot air and lint onto the range hood into the kitchen . . stupid advise .. it needs to be ducted directly through the wall to outside using a rain gard the temp can get as high as 47 degrees hot but not too hot it forses air out at a ratio of aprox 15 psi
merry christmas
Dec 22, 2010 | Dryers
Just got a new tumble dryer with built in vent and hose. Trouble is i have a hose and vent already fitted to outlet (wall) in kitchen what can i do? Will i need to take out the whole fitting in the wall....
Take hose off the vent and then stuff plastic into the vent and take some drywall mud and fill the rest of the vent with mud. Doing that will keep criter out of you home
Jul 21, 2010 | Dryers
Can i vent into kitchen ?
You can vent into the kitchen, but, the amount of moisture that will be present in the air will cause dew/sweat to build up on walls,windows,ceiling everything in the room,and I mean alot of moisture!!!
If you are asking if this will harm the dryer, the answer is no the dryer will be just fine.
Good Luck !
Apr 21, 2010 | LG DLE2050 Dryer
How do i fit the flue to the wall?
The flue fits through the wall and fits to the vent on the outside, the vent should be screwed to the outside wall.
Feb 22, 2009 | Smeg KSED65X-1 Kitchen Hood
The thermo fuse keeps going out on my kitchen aid dryer
you need to check the wall vent and dryer vent it sounds like 1 or both might be clogged,if blowing cold air know the heater box fuse has blown again-mike
Jan 24, 2009 | Dryers
How do you fit a dryer vent that has to go through the wall?
Unfortunatly you'll need to either knock, hammer and chisel, or drill, using a core drill, which you can hire from a tool hire shop, a hole through the wall. Then connect up the dryer hose to a vent kit which will fit in the hole in the wall.
You can buy the vent kits from most DIY shops and electrical shops (they don't cost much). This is the best way.
Alternatetivly you can buy a special filter box that the dryer hose fits into. This is best if the dryer isn't next to an outside wall. Again most DIY shops and electrical shops sell these.
Good Luck!
Nov 28, 2008 | Dryers
Air vent
Many home improvement stores such as Home Depot , Lowes etc carry Vent kits. I would encourage you to pick up one of these and install it through your outside wall. Normally, the outside portion of the vent has a flapper to keep outside air and critters from coming into your house when that vent is not in use and also has a short section of ( typically) 4 inch vent line that projects through the wall cavity and into the living space. Most flex lines should be atteched to that. If you are usintg a gas dryer, it is strongly encouraged and may be code requirements in some areas to use only solid ducting to the outside. Electric Dryers do not have the same exhaust gases and can be ducted with a plastic flex line. Hope that helps...
Aug 12, 2008 | Dryers
Dryer takes too long to dry
This complaint is most often caused by the dryer's vent being blocked with lint. Dryers need to be properly vented, otherwise the moisture in the air can't be properly carried away. Vents that go out the roof are particularly problematic-- the dryer may take far too long to dry clothes and the vent pipe may even drip water that can't be exhausted. Minimum size for a dryer's roof vent is 4 inches. If your dryer has chronically poor drying, if possible, have the vent moved to where it exits a house wall near the dryer. The vent should be made of 4-inch aluminum rigid duct and elbows or, where absolutely necessary, flexible metal (but not flexible thin foil). Do not use flexible plastic duct-- it restricts air flow and is combustible. The dryer should vent outside--never into a crawl space, wall, ceiling chimney, or other type of flue. The bottom of the exhaust hood should be located at least 12 inches above the ground. Here is what to do: 1) Check the lint trap and clean it. 2) Be sure the dryer isn't pushed so close to the wall that it pinches off the airflow through the vent's air duct hose. 3) Check the point where the air duct vents away from the house. Be sure plants, birds, or anything else hasn't blocked it. If the duct vents out the roof, it could easily be blocked with lint. 4) Disconnect the air duct hose from the back of the gas dryer and clean out built-up lint. Note: For safety, first turn off the gas to the dryer, then unplug the dryer; this means you will have to re-light the pilot light later if the dryer has one (read your owner?s manual for proper re-lighting techniques). 5) If necessary, clean out the ductwork from the dryer to the exterior wall where it vents; this may involve disconnecting sections. One trick that sometimes makes this job easier (but only if the dryer duct is fastened firmly at all connection points) is to blow lint and debris through the duct and out the exterior wall vent, using an electric leaf blower.
Jan 18, 2006 | AEG T57800 Electric Dryer
Dryers Logo
59 people viewed this question
Top Dryers Experts
