Question about Dryers
Hotpoint TDC62P Condenser Dryer no heat
Have replaced the thermostats again, worked for about 5 minutes before blowing cold again. My husband wonders if we have put the thermostats in the wrong place? Should it be orange wires to the green spot thermostat please? We have a multimeter if you can tell us what the voltage should be at the thermostat. Also could the problem be due to another component, such as the element or dryness sensor, and if so why do the thermostats keep blowing? Your help would be much appreciated.
Kind regards
  • woodies00 Jan 06, 2009
    Many thanks for all your help.
  • 3,463 Answers
Hi
Re your on going prob with dryer.
You should be reading 240v at the heater and stats.
To be sure the stats are faulty or not, you need to remove the connections to them and test for continuity through them both.
Set you meter on the ohms range, you should get full scale deflection if they are o/k
if you do not get a reading, then they are faulty.
The orange wires should be on the left side stat, and the blue on the right side stat.
It is possible you have got the stats the wrong way round, the one with the green spot on should be on the left. They are rated at 130c for the green spot,and 106c for the other one.
To be sure you have the right stats, the partnumber should be 1701774.
It is imperative you have the right ones fitted, as they changed the part number depending on the date code of the dryer.
If the stats are o/k then it is possible that the pcb is faulty.
Hope this clarifys things for you.
Good luck.
Posted on Dec 22, 2008
MY HOTPOINT AQUARIUS TCM580 CONDENSER DRYER STOPS WORKING AFTER ABOUT FIVE MINUTES USAGE AND IN SO DOING TRIPS OUT THE MAIN HOUSE FUSE, WHAT CAN CAUSE THIS PROBLEM
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Oct 05, 2014 | Hotpoint Dryers
Hotpoint CTX21 ELA
Check and lobe the fans! The evaporation coil fan could be stuck, worn out or blocked. That fan is the cold air circulator and if it doesn't work, nothing will get cold! Also check the condenser fan usually located next to the compressor to blow room temp air across the condensing coil and across the defrost drain water pan. It's the hardest working fan and really takes the worst beating with dust, pet hair and heat.
Aug 21, 2014 | GE Refrigerators
Hotpoint Condenser Dryer Shuts Off After 5 Minutes
what is your model number is then we can get started then okay
Feb 01, 2013 | Dryers
No hot air blowing - cold air only. Hotpoint Aqurius condenser dryer.
We have a full video library on appliance repair video’s
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
Jan 02, 2010 | Hotpoint Dryers
MY HOTPOINT CONDENSER TUMBLE DRYER NO LONGER HEATS UP. IT NOW OMLY BLOWS COLD AIR
This sounds like the thermostats or heater
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
Nov 17, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
I have a hotpoint aquarius condenser tumble dryer
Common faults -
Nov 06, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint tdc62p changed thermostats as blowing out cold air,
Make sure that all filters are properly cleaned, and that the air inlet and outlet vents are clear. Make sure water container is empty.
The best way to clean the filter at the bottom is to run cold water through it, this will clear out all the lint.. Make sure you have the correct stats ( there are many for the hotpoint range) and that you have them in the correct position on the heater back plate.
Plz rate this solution.
thanks.
Dec 16, 2008 | Hotpoint TDC32 Electric Dryer
Dryer has no heat
We have the same problem as posted above (dryer not heating up) only we have a Kenmore gas dryer Model 76702693. What should we do? Please help. Thanks.
Sep 11, 2008 | Kenmore 74832 Gas Dryer
Hotpoint CTD00 condenser dryer not heating up
sounds like a thermostat fault, there is two on these machines and although only one will be at fault both should be replaced
Jul 24, 2008 | Dryers
Dryers Logo
232 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
