Question about Zebra 110XiIIIPlus Label Printer
Can't get barcodes to scan?
Hi, i'm having trouble trying to print barcodes that will scan properly. They look "patchy" and have broken lines. I've tried tighening and loosening the tensioner springs on the print head with no luck? I've also tried printing diffrent barcode densitys to see if it made a diffrence again with no luck... Any help or advice would be greatly appreciated. Thanks! Chris.
    New Friend:
  • 3 Answers
Change your printing speed, it will make it print darker and have better quality of print
Posted on Nov 01, 2013
    Problem Solver:
  • 17 Answers
Did you try the PAUSE test? if not turn off you printer press and hold PAUSE button then power on the printer after a 4 sec release it will print note u must pause it bcoz it will continue printing.. then look out the print out look for the white vertical line if it has your printhead is defective..
Posted on Mar 20, 2009
How r u Trying to print a barcode to the printer??
Posted on Dec 10, 2008
  • 53 Answers
Have you tried different darkness settings? it sounds like you only need to turn the darkness up a little.
Posted on Nov 09, 2007
  • steven
    steven Nov 01, 2013
    And slow down the print speed, doing that will make it darker and better print quality
Barcode Print aliginment is not proper in windows7
Try a different print driver. Go to Zebra web site and download driver for Windows 7'
Apr 22, 2014 | Zebra Office Equipment & Supplies
BROTHER MFC J435W BARCODE PRINTING PROBLEMS
Sounds like a problem with the printer. The software that came with the printer should have some tools that might help you, My old Epson printer came with a set of tools, one in particular tool (which may help you) was head aligment. This use to fix the issue of non straight lines being printed. Head cleaner was another tool i would use to have thin consistent lines printed. Check your printer install cd and add the extra software if all you have installed is the basic driver.
Dec 14, 2013 | Brother International Brother MFC-J435W...
S605 ink printing patchy
A firmware update for your model addresses print quality issues. Please visit the Lexmark website to download and install the Lexmark S400 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
Try to print again to verify that the print quality has improved.
Should the problem continue, it could be that the printhead itself is the problem. Please contact Lexmark Technical Support Center for assistance.
Feb 04, 2012 | Lexmark Interact S605 All-in-One Color...
Dear sir or mam ,i m having argox GE200 barcode printer which is not responding. when m giving print no response from the printer and any error also not showing.wat to do?
Hi.. Just follow these steps, hope this may trouble shoot your barcode printer.
1) Restart Your Computer/ Barcode Printing S/w / Barcode Printer/ and try now.
2) Even if it does not work, check the cable connectivity with printer and system
3) Even it is not working, try printer calibration or labels feed options in printers.
4) Check the proper sensor adjustments in printers,
Hopefully this should help you to get back your barcode printer online.
If you have any other queries with barcode printers, please email/contact us.
Regards Kirubakaran.Rv Web Marketing Manager Trridev Labelss Mfg Co Leading Labels Manufactures In Chennai Mobile - 96000 07995 www.trridevlabelss.com email kirubakaran.rv@gmail.com
Sep 03, 2010 | Argox OS-314 Label Printer
LS4278 scanner can't read digits
Hi, try scanning French Windows barcode from the USB section of the LS4278 Product Reference Guide. The barcode is on Adobe page 147 of 414. You may also have to scan the Enable Keypad Emulation barcode from Adobe page 150 of 414, but I would do this only after testing with the French Windows setting first. I suggest saving a copy of the document before printing the barcodes just to make it easier to print. Hopefully this will resolve the issue.
Oct 16, 2009 | Symbol LS 4278 Barcode Scanner - P/N...
Incomplete patchy printing
Please try to do a printer head cleaning. You can do it by getting a small earbud and soak it with a small amount of water. Or try to adjust it by doing an alignment. Usually, the printers have this functionality. Please refer to the user manual.
Aug 13, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Barcodes not scanning
Very possible you have a bad printhead. If you have a bad dot in your print area, it can cause barcodes to not scan. Look to see if you have a blank vertical line running down your label.
Dec 31, 2008 | Epson TM T90 Printer
Z4M is printing fine white lines in the barcode
As the label comes out of the printer...it sounds like your printing in picket fence mode (vertical bars). You most likely have 1 or more pixels out on the printhead...try cleaning first...if that fails... you will have to replace the printhead.
Apr 16, 2008 | Zebra Z4M Printer
Metrologic USB Voyager scanner
refer the manual and scan the default barcode and scan the usb interface barcode properly.
Feb 01, 2008 | Metrologic Instruments 9520 Voyager
Zebra 110XiIIIPlus Label Printer Logo
215 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
