Question about Acer TravelMate 2300 Notebook
Hi, my Travelmate 2410 seems to have the LCD damaged. It's still blue with 3 big stipes. Brightness controls are working properly and backlight lamp is ok. If i connect to external monitor, everything it's ok. Any suggestion? Vi3da p.s. sorry for my bad english
    Problem Solver:
  • 15 Answers
Http://www.laptoplcdpanel.com/productlist.php?cname=Acer_Laptop_LCD_Screen
new lcd screen between $125 and $150
sometimes not easy to install
Posted on Dec 20, 2008
I have a korg pa50sd, but its lcd brightness is too high..how to control this? it is very difficult to read?
There is no adjustment to control the brightness in korg pa50/sd.
It is hardware problem.
-Is the white backlight that is too high?
or
-normal backlight,but words is too dim?
Both of that case,can be caused by damage / change of voltage control for lcd. Perhaps there are parts that are damaged or have changed in value. Typically capacitors etc.
If the backlight is too bright, then the damage is in backlight controller, may transistor or an inverter transformer.
Proceed with the repairs to the experts.
Jul 08, 2015 | Korg Music
By lightning, burned the lamp and the circuit that feeds the backlight lcd tv sony kdf e55a20, was replaced as the circuit as the lamp, but the screen looks good with the only who does not have...
Being a Lightening strike you are fortunate that only the board was replaced.,but it seems the damage is more than what was seen. The heavy discharge can damage many components to reduce value and be insufficient to deliver the required output.
I request that such a case might need to be checked by swapping the boards/LCD panels to confirm and so it is best to take an estimate from the service center
Jul 30, 2011 | Sony Televison & Video
My dell e1404 laptop is having a issue with the screen. When you turn on the computer the screen will come on for about 30 seconds and then go off. When it's on everything looks normal. once it goes out...
The inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. The inverter board converts low voltage DC power (few volts) supplied by the motherboard to high voltage AC power (few hundred volts) needed for the backlight lamp.
When the inverter board works properly, the backlight lamp gets power and the LCD screen lights up. As a result, the image on the screen is bright. If the screen is dimming down, means that the inverter is failing in it;s job to supply the needed voltage to the Backlight.
The Inverter is mounted underneath the display screen and is connected by a two wire plug.
Nov 07, 2009 | Dell Inspiron E1405 Notebook
My screen is dark when the computer logs on (but I
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness.
Sep 24, 2009 | HP Compaq nx9030 Notebook
Black screen on acer 242lc lights come on power up
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 18, 2009 | Acer TravelMate 242LC Notebook
How do I get rid of a blank screen on my laptop
Check out
www.lcdparts.net
Sep 16, 2009 | Dell Inspiron 1501 Notebook
My monitor isn't showing a picture properly. It is on and working because I can see the picture very dimly and the green power light is on. The frame around the screen was recently damaged - the screen...
I'm assuming you already tried the brightness adjustment.
From your description, the LCD screen itself seems to be intact. The problem seems to be backlighting which could very well have been damaged by a perimeter impact.
If it's still under warranty, contact the manufacturer. Tell them it just stopped working. Don't elaborate on the details.
If not, find an accredited computer repair shop. It's not a big deal to fix as long as the fix is performed by a trained professional.
Sorry, I wish there was a magic button to push.
Best regards,
Mike
Aug 17, 2009 | ViewSonic VA721 17" LCD Monitor
How can i replace the backlight of teh LCD Monitor
Before bying parts hold down the "Fn" key and hold down the up arrow - this usually increases screen brightness
Apr 26, 2009 | Acer TravelMate 4320 Notebook
Acer 2410 display having 3inches wide black vertical line at the right end
Hi...there,
The problems.. your panel are damaged. Don't bother to replaced...will cost you a lots of $$$.... It's time for retired...
Oct 14, 2008 | Acer Refurbished 11 3 STN LCD DISPLAY **...
Half my laptop lcd has gone out
Hi
The inverter board regulates the power to the LCD backlight, it doesn't affect the display, just the light.
From my experience I would say that either your LCD cable is damaged or maybe partially unplugged, or the LCD itself is damaged.
The first step would be to unplug the LCD ribbon cable and then plug it back in making sure that it is properly aligned and well seated. Does the LCD now work? If not, try getting another cable off... you know, that auction website (I don't give them free ads) and see if that works.
If it's not the cable then you can be pretty sure that it's the LCD as you have already said that it works on an external monitor so it's not the video card.
Hope this helps.
Thomas
Oct 13, 2008 | BenQ FP731 17" LCD Monitor
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
