Question about Kenwood KDC-MP532U
I have been having trouble with my car stereo system
After i installed a battery capacitor i started having trouble with my system just shutting off for no reason. After I go in the trunk and just move around wires it comes back on. what do you think could be the cause. Im thinking it is the ground wire not being properly connected but could that cause the entire system to shut off if not connected. I dont think it is a power problem because the radio still stays turned on, just no sound is playing. so maybe an antenna wire problem. please help. and could u also tell me how to properly install the battery capacitor to make sure that isnt the problem to begin with
  • ridingbig Dec 20, 2008
    how would i know if the amps channels are blown
  • 62 Answers
Did u properly charge the capacitor before u turned it on if not that could b a problem
Posted on Dec 20, 2008
  • 1 more comment
  • dustin allen Dec 20, 2008
    did u properly charge the capacitor before u turned it on if not that could b a problem
    you could also have blown the amps channels or check your ground it may be loose
My mazda protege 2002 started shaking after I put in a new stereo system I thought it might be my battery terminals not hooked up to the battery properly but it wasn't Any suggestions
Firstly remove the stereo system and see if that fixes the problem as if it started after you installed it then you have interfered with the power systems for the ECM. Best have the stereo system fitted professionally if that is the case.
Apr 19, 2014 | Cars & Trucks
Engine Cutting Off
you have a serious electrical problem. It is related to the stereo. Disconnect the stereo and hard wire the stereo system directly to the battery with an inline fuse. My spidey senses tell me you are in a german/ european car? Major elevrtoical issues/ design.
Mar 10, 2014 | Mercury Grand Marquis Cars & Trucks
I put fuel pump ,crank sensor, fuel filter, tune up and I still do the same start and shut off
Does it have a SECURITY system in it ?
Is the SECURITY Light on or Flashing Sparatickly ?
Any Trouble codes ?
POSSIBLE - * MAF sensor (Mass Air Flow Sensor) has gone BAD causing car to start then shut back off . * Security has kicked in ( Due to changing stereo system or battery went dead or didn't have one on it for a little while .
FIXES - *Replace Mass Air Flow Sensor (in between the throttle and the air filter box) . * Take to Dealer and have computer Flashed/Reset if SECURITY is at Fault . I recommend the MAF sensor
Hope this Helps , Flaming Ratchets Auto Repair
Dec 05, 2013 | 1990 Pontiac 6000
I installed a brand new kenwood stereo in my 1999 acura cl 2.3 i moved it out of garage when i was finished parked it and locked it up with the car remote and when i went to use it 10 minutes later it
My guess is your car has an anti-theft system that was attached to the stereo that your stereo install interrupted. You will need to contact the dealer about the issue.
Nov 12, 2013 | Acura 2.2 2.3 3.0 CL 97 98 99 1997 1998...
I put a new stereo in my 1990 Suburban and it blew the fuse for the dome lights, dash lights. It says on the box that it is putting out 3 times the wattage as my old stereo. What can I do to fix that?
Aftermarket stereos are designed to work within the power specifications for most vehicles, if you are experiencing blown fuses I would suggest re-checking the stereo wiring for a crossed, exposed, or improper connection. If you have ruled out all of these then you can install a capacitor to power your system more efficiently. Most car audio stores sell these and are installed between the connection to the head unit and battery. I hope this helps =)
Sep 29, 2013 | JVC AM FM CD DET FACE CAR STEREO
I have a clarion cz100 hooked up to a 1000 watt autotek amp and it is connected to a red top optimum battery. When i turn it up to BUMP it if im not moving the stereo will shut off. I had it hooked up to a...
some stereos will shut off if the voltage drops below 12 volts. measure your voltage at the battery with the car at idle and stereo turned up and all accesories and lights on. you should have 14.4 volts with the car running. the batteries voltage is 12.6 volts so you have to have more than this to be able to maintain steady voltage to your components. if the voltage drops too low when the bass hits it can shut off your radio. a capacitor can help this and the safe number is 1 farad for every 1000 watts. if you plan on adding any other amps autotek and phonix gold both make a digital capacitor that is compact and go anywhere from .5 farad to 10. the bigger the cap the better. if your voltage readings are ok then check that your speaker output wires are not touching.
Dec 23, 2010 | Clarion CZ100 Car CD MP3 Player
Viper 5901 Starting issues
i need to adjust the time that it waits to start for my glow plugs in my 2001 ford excursion diesel 7.3. I need it to wait another 10 - 12 sec.
Sep 12, 2009 | Viper Security and Remote Start System...
I just installed a Pyle Marine CD player in my street rod. It works perfectly until I start the engine, then the sound cuts out. I switched it out with another car and it works fine in the other car.
You should be looking for a large capacitor to insert in the stereo's power leads. One farad, more or less. The CD shuts off when the battery voltage drops below a certain voltage. This prevents the voltage dropping below the threshold while cranking. Available at Wal Mart, Canadian Tire, Radio Shack type stores.
How to link:
http://wiki.answers.com/Q/How_do_you_hook_up_a_1_farad_capacitor_to_your_amp
Picture of one:
http://www.amazon.com/Pyramid-CAP160DBL-1-6-Farad-High-Performance-Capacitor/dp/B000MCKAYW?tag=dogpile-20
Jul 15, 2009 | Car Audio & Video
First reinspect your power and ground connections, vibration may have loosened them.
Then be sure that amp location has proper ventilation, (overheating will cause shout down)
A 2400 in a closed space will definitely need exhaust fans to help circulate cool air around the amp.
The cap should be mounted close to the amp and properly charged before use. It is connected in-line with the main power lead paying close attention to the power in and power out terminals.
Power in = from the battery
Power out = to the amp
Good luck
Aduz
Mar 15, 2009 | Rockford Fosgate Punch 801S Car Audio...
NO memory in kenwood kdc-mp205
check your wiring in your vehicle to make sure that the yellow wire from the stereo gets "constant" power. It it what keeps your stereo's memory, and powers the audio amp in the stereo. If this wire is loosing power when you shut the key off in your car, you will loose all of your settings...bass, treble, tuner, clock, and also where you left off on your CD.
Dec 27, 2007 | Kenwood KDC-MP205 CD Player
Car Audio & Video Logo
60 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
