Question about GE EasyCam Webcam
GE top load washer less than 5 years old Model WSDR2080DOWW Problem agitator won't spin; motor works; water in and out OK Questions: Is this a type I or type II washer and Any suggestions to fix?? Thanks
  • 565 Answers
If its Ge type of cam then the drivers are here
If it was helpful rate Fixya
Posted on Dec 27, 2008
How to replace seal of ge top load washer
You have asked a number of questions. How old is the Washer?
Based on your questions, it may be time to replace. No I am not a
GE Rep. Parts can be ordered online. Google Appliance parts. They may be able to help with "how to's". If newer machine, still warranty? If so check with GE. Otherwise, if the tub isn't being over filled and spin out doesn't send water outside the outer tub which could explain the dripping. Verify gasket leak by leaving water in tub and measure height of water very carefully let stand several days and remeasure.
Remove top should be springs on the front. Push in, to release, tip-up top. Tub must be removed. Remove the agitator by removing the top plastic, should reveal top nut holding down the agitator. You will see a number of nuts holding the agitator tower to reveal gasket. There may be rusting and pin holes causing the leak. I would check this before attempting gasket. I had a similar issue, used JB Weld epoxy about 5 year ago, still not leaking. Possibly the agitator tower has a seal leaking at top. If so that is in transmission and should be replaced as well as the bottom gasket. It may be $200 part.
Due to all the trouble, I replaced it to prevent future failure. You may find a lightly used replacement washer for about that price.
Nov 18, 2014 | GE Washing Machines
Washer won't agitate with clothes in. Will agitate when empty with water
It's a whirlpool top load and 17 years old.
I checked the lid switch, water level switch and they are okay. I replaced the motor coupling. The old one was chewed up and crumbling.
When I put everything back together and turned it on to check if it would spin, I heard a buzzing sound and after a few minutes there was a burning smell.
What should I check to diagnose this problem? would help to have make or model numbers to show age of machine
Nov 26, 2012 | Whirlpool Washing Machines
Ge top load washer won't agitate or spin after
what is your model number is then we can started then okay
Sep 15, 2011 | GE Washing Machines
Doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Jun 02, 2009 | General Electric WHDSR316G Top Load Washer
GE top load will fill with water, not spin, agitate, empty water
very familiar with this look under machine if black dust found it has a broken motor coupler, very easy to change
Dec 22, 2008 | GE WDSR2080D Top Load Washer
GE WDSR2080D5WW Top Load Washer
sounds like the agitator is bad not hard to replace look up on internet agitator replacement for that model
Sep 10, 2008 | GE WDSR2080D Top Load Washer
GE washer eill not drain or spin.
if the unit is at least 4 or 5 years old, most likely the pump is clogged with the same hair.....that clogs vacuums. you probably can fix it yourself provided you can get to the pump without too much trouble. i'm not familiar with all the brands designs. maybe someone else on this sight can help. if this is not the problem than most likely some of the timers points are burned. if the unit is more than 10 years old and/or the unit has been used unusually alot there is the possibility that the transmission has problems, but that is pretty unlikely. hope this helps.
Mar 05, 2008 | GE WDSR2080D Top Load Washer
GE Top Load Washer 10 yrs. old, used for 3 years, stored after that
the water must drain out of the tank b4 it can spin make sure the pump is working ok
Nov 17, 2007 | GE WBSR3140DW Top Load Washer
GE EasyCam Webcam Logo
222 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
