Question about Hyundai ImageQuest L50S 15" LCD Monitor
Monitor will not power on
I have my monitor plugged into the wall and when I press the power button nothing happens... I want to fix this. It would even be a help if you had tips on even opening up the monitor
How can i open this monitor,
model l50s (yundai)
Posted on Dec 18, 2008
  • 21 Answers
Carefully remove the other covetr,isolate all wires connecting the electronic board to the crt and the earthing pad.once you acess the pcb,test the fuse first,if there is continuity,cover it back and seek proffesional service technician as further troubleshooting requires specialised knowledge.try your best,cos no one can fix every thing,most of the time we need other peolpe's services.i admire your courage. eyo7 eyoifiok2005@yahoo.com
Posted on Apr 02, 2007
Display not working, power button LED turns on blue for 1 second and won't turn on again
Have you tried checking with another monitor. Meaning that if the second monitor does not come on then the problem is with your computers mother board. But if the monitor other monitor you check it with comes on then of course it is your monitor.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
BOUNCING CHARACTERS/DISPLAY
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 22, 2014 | AOC 19" LED Monitor e950Swn Black
How do I get rid of osd lockout
Fix One:
Plug in the monitor and power it up. Hold down the Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait 20 seconds and try again.
Fix Two:
Turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
Fix Three:
Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Fix Four:
The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. This could be tricky unless you know what you're doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have warranty this is where you want to contact the manufacturer.
Apr 12, 2011 | Packard Bell Computers & Internet
Dell E177FPv, 17" TFT LCD Flat Panel Monitor will
I think you might have the same problem I did with my E178FPb. I made a video on how I fixed it.
Apr 04, 2011 | Dell E177FP LCD Monitor
Desktop: Gateway LX6810-01 PC will not power on. When I hit the Power button on the tower, a long continuous BEEP comes on and nothing appears on the monitor. After the BEEP, the On light (on tower)...
Thank you for using FixYa
I would try shutting down the computer in the normal way, and turning off the monitor.
Boot up and turn the monitor back on.
If it still doesn't work, then I would check the cables and power plugs and wall plugs.
Check the mouse and keyboard cable and any other cables plugged into the computer.
The next step requires a seperate monitor or laptop.
Try unplugging the monitor and pluging in another monitor. Most laptops have a common
VGA adaptor jack or even an Svideo jack.
If the other monitor does not work, Then take to a qualified technician for repair.
It could be your power supply in the computer or video controller.
I hope this was useful and please comment if this was helpful to you.
Mar 24, 2011 | Computers & Internet
Power Save mode on, can not use computer
If your computer is indeed running, simply unplug your monitor from the wall, and then plug it back in. This will bring your monitor out of power save mode instantly.
Apr 22, 2010 | Dell Dimension 8400 PC Desktop
Desktop monitor went black & and wil not power up
Try the fuse on the monitor power cord, and if this does not cure, you will have to get another monitor....pretty good prices on ebay!
Jan 04, 2010 | Computers & Internet
I have had the Hyvision MV220 monitor for 2 years now. I powered it off last night and it will not power back on this morning. There's a clear dot on the power supply and I'm not sure if it should be lit...
The light should be lit on the power supply when its plugged into the wall. Sounds to me like the power supply might be bad. Plug it into another working outlet and if it still doesn't light up then the power supply is bad.
If it lights up then you know the outlet is bad.
Dec 10, 2009 | MegaVision MV220 Monitor
How to turn off burn-in mode if botton on Monitor
I didn't have the monitor connected to the computer, and that's why the power button was unresponsive. After connecting it, the solution above worked for me.(My KVM switch was set to a computer that was turned off)
Oct 07, 2008 | Sceptre DCL9a
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Hyundai ImageQuest L50S 15" LCD Monitor Logo
343 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
