Question about Goodman CLQ36AR49 Air Conditioner
My two goodman split type air conditioners arent working...
One of them is stuck blinnking on timer mode and the other is just being slow it heats up but its takes forever. It just sits on pre def all day then randomly turn on...
meBNme
  • 334 Answers
SOURCE: Goodman Air Handler motor will not turn off.
Look at your Thermostat wiring.
If there is a green wire going to the "G" terminal, disconnect it.
If it stops running, you have a bad T-stat.
If it keeps running, you either have a stuck fan relay or a low voltage control wiring malfunction.
Those are usually related to one of the safety switches having problems.
If green is not going to G, let me know, and we will determine which one is indeed the fan wire and go from there.
Remember, when you rate the solution, it closes further dialog, so only rate when you are satisfied with the discusion.
Thanks for visiting FIXYA!
Posted on Jan 03, 2009
  • 306 Answers
SOURCE: Goodman air conditioner will not turn on outside
When ever you hear a buzzing like you are hearing means one thing one of the fuses on the outside disconnect box is bad. Only getting 1/2 the power. Find the bad fuse and get the same size and will be good to go. ken
Posted on May 02, 2009
  • 52 Answers
SOURCE: air conditioner not blowing cold air
Hi Deb,
The Suction line is the larger of the two, and the smaller is a liquid line. That said the ruber you refer to is insulation and does a very important job so do not remove it . I need to know if the outside unit is clear and free from obstruction and debris? have you noted any other worring sgns lately? ie is this system constantly running?
Posted on May 20, 2009
  • 340 Answers
SOURCE: I have a Goodman air conditioner. My outside unit
If you are sure of the power then ya have a control problem thermostat set correctly? could be open low pressure switch I would call for service. Tom
Posted on Jul 03, 2009
gear001
  • 59 Answers
SOURCE: moved into a new house with a goodman air
Well it might be a heatpump. Where it uses the A/C portion of the system to draw heat from out side and place it into you home. If its a new home I would call for a Check-Up its only $60 to $80. But dont buy anything you dont need like a new thermostat. Just tell them to check the refrigernt levels and to tell you if everything is runing ok.
Posted on Oct 16, 2009
My Goodman split unit has bumping/knocking noise sometimes (not everyday) when heat first kicks on in the mornings only. What could this be? Also in defrost mode should the unit blow cold air?
May be the fan in the external unit is ruined or the internal pump is comming loose. But note that the pump also make much effort until the gas flows smoothly through the pipes .
Feb 27, 2015 | Goodman Heating & Cooling
Teco Split air on will not heat the room
Are you sure it's a heat pump type? If so, there is a valve in the outside unit that may be stuck or not getting power from the pcb. Give it a tap and see if it changes over
Jun 26, 2012 | Heating & Cooling
Goodman mini split model # wmh24-1a error code snowflake light stays on and 4th light from left blinks. i need to know what that means?
It's not an error. you have it set in auto mode and it is cooling. when it switches to heat the lights will switch as well. Set to cool only and it should go away.
Apr 28, 2011 | Soleus Mini Split Air Conditioner
Can not get Goodman 3-ton heat pump out of heat mode and into cooling mode
The reversing valve may be stuck. It allows the unit to switch between heating and cooling. You may be able to give it a tap but only on one of the ends, not the sides, and only lightly. You could also unplug the reversing valve from the circuit board. Some reversing valves are energized in heat mode some in A/C mode. When you unplug it, if it shifts, you will hear a loud hiss as the valve shifts and the pressure equalizes.
May 04, 2010 | Goodman CLQ36AR49 Air Conditioner
GSH13 Goodman heat pump split system is running a long time in cooling mode and will not cool below 74 degrees. A lot of condensation generated. The low side pressures 78 to 81 and high side pressures are...
Check sub cooling and super heat. the New ac units are very critical to charge. There is a charging chart on the inside of the cover to the unit outside. Check temp difference across coil. Should be 18 to 22 degress. If you have an ampmeter. Check the heat strips one 5 kw might be stuck.(sequencer). This would cause you not be able to pull down temp. Goodman unit are hard to charge to get the temp difference across coil. Feedback please
Jun 14, 2009 | Goodman CLQ36AR49 Air Conditioner
Air con stuck on cooling mode!
Is this a Mini Split Ductless type Heat pump? Has it worked in the heat mode for you before? Have you tried killing and reapplying power to both the indoor and out door sections? Does it have a wireless remote? Are the batteries new in it?
I have to assume a lot because there is a lot of information missing to really know how to help you.
If these items helped would you please grade me accordingly. Thank you and GOOD LUCK.
Mar 03, 2009 | Panasonic Heating & Cooling
Airconditioner LG LSk181-N2 shutting off
Sounds like your aircon is stuck on heating mode. Or. The outdoor fan speed is affected by ambient temperature, or low refrigerant. In heating mode the indoor fan will come on for a while to sense temperature and will then wait for the outdoor unit to pump up pressure and build up heat.
Feb 01, 2009 | LG LS-K1830CL Cool Mini Split Air...
Goodman heatpump. Crazy pressure in heat mode
Check the TXV valve on the outdoor unit, it could be stuck closed. We have been experiencing the same problems with the 410 systems and the TXV was the culprit. Good Luck
Dec 19, 2008 | Goodman CLQ36AR49 Air Conditioner
Heat Pump or not???
This is an air conditioner. Based on the numbers you gave me, this is what I come up with. Thanks.
C= Split system
KL= Air conditioner
30= 2.5 ton
1= 208 230 v
D= Revision
Jun 23, 2008 | Goodman CKL49AR49 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
173 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
vance jones
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
