Question about GE Nautilus 24" Built-in Dishwasher
Dishwasher won't turn on
The machine has power coming into it but will not turn on. We checked to make sure the motor would run, it does. What do you suggust. The model # GSM2100G02WW Serial # 5L738201B
    Problem Solver:
  • 3 Answers
Make sure you have nothing blocking the door to the washer, reload or empty the dishwasher and try to start it empty.
I couldn't figure out why mine did the same thing. I spent $$ on a repair call. The service man rearranges things and it started.
Just figured I would put my 2 cents in.
Posted on Jan 02, 2009
My candy future3 dishwasher just won't start the
test the following steps and fix it. God bless you
Power Supply
The main power supply is the first thing to check. Also remove the toe kick and the cover on the power box and check the connections. Also check the 120 volts at the power box
Hi - Limit Fuse
This will fail if your dishwasher overheats and occassionally with power surges. This is easy to check, inexpensive and a quick fix. Just check the terminals for continuity ( remember always remove one wire) if you have none replace the hi- limit fuse
Door Switch
This is the second place to look. Again an inexpensive easy fix. The following video will walk you thru checking the door switch The power comes into the main power box and usually runs to the door switch next before entering the main control module.
Main Control Module / Timer
The main control module or mechanical timer controls all the functions of the dishwasher. To check this you will need to find the 2 leads that supply the power to the control. They will be marked on the wiring diagram. They usually come from the hi - limit fuse or the door switch. When the door is latched you should have 120 volts entering the main control. If you do not the problem is not the control. If you do have power entering the control but none of the functions work properly or it does not respond at all you will need to replace the control module, this is easy to replace but not very inexpensive to purchase. Consider the age and overall condition when purchasing this part.
Motor
The motor may have failed. If the control illuminates on electronic versions the problem may be the motor. To check the motor refer to the tech sheet located behind the console cover on most models, this will sometimes have the ohm reading of the motor. Also check each lead to the metal housing of the motor to check for shorts in the motor. If you do not have the ohm reading specicifications, check for continuity if none replace the motor. Make sure the motor is receiving power.
Float Switch
If the float switch has failed or is stuck the dishwasher control may not respond. The float switch is easy to check and replace.
Jul 22, 2013 | Dishwashers
Frigidaire dishwasher has no power and won't start
Hi - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Oct 17, 2012 | Electrolux Fridigaire Lp Conversion Kit...
My bosch dishwasher won't start
see this causes and fix it. God bless you
Power Supply
The main power supply is the first thing to check. Also remove the toe kick and the cover on the power box and check the connections. Also check for 120 volts at the power box.
Hi - Limit Fuse
This will fail if your dishwasher overheats and occassionally with power surges. This is easy to check, inexpensive and a quick fix. Just check the terminals for continuity ( remember always remove one wire) if you have none replace the hi limit fuse
Door Switch
This is the second place to look. Again an inexpensive easy fix. The following video will walk you thru checking the door switch. . The power comes into the main power box and usually runs to the door switch next before entering the main control module.
The main control module or mechanical timer controls all the functions of the dishwasher. To check this you will need to find the 2 leads that supply the power to the control. They will be marked on the wiring diagram. They usually come from the hi - limit fuse or the door switch. When the door is latched you should have 120 volts entering the main control. If you do not the problem is not the control. If you do have power entering the control but none of the functions work properly or it does not respond at all you will need to replace the control module , this is easy to replace but not very inexpensive to purchase. Consider the age and overall condition when purchasing this part.
Motor
The motor may have failed. If the control illuminates on electronic versions the problem may be the motor. To check the motor refer to the tech sheet located behind the console cover on most models, this will sometimes have the ohm reading of the motor. Also check each lead to the metal housing of the motor to check for shorts in the motor. If you do not have the ohm reading specicifications, check for continuity if none replace the motor Make sure the motor is receiving power
Float Switch
Oct 17, 2012 | Bosch SHU9915UC Dishwasher
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
Power is not coming on
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Wagner Spray Tech Wagner 915 1,500-Watt...
My dishwasher won`t start. NO light are open. The electrical power it's ok.
It is possible that themachine does not start off the cycle because there are errors or feedback fromthe inputs. For the program to start up the main program controller mustinitiate the INLET/PUMP MOTOR/DRAIN to workwhen it is commanded .If this does not happen then the voltage at thesepoints must be checked or the faultrelates to no voltage/drive from the controller. This means the controller is asuspect.Check howto remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html If thewater flows then the flow should be good, if not the inlet valve is bad or thereis dirt in the filter. Also check the flow at the inlet of the water line. Whatis most important for the motor to start functioning is that the door switchmust be ON when the door is shut or this will be an error for starting themotor. The water pressure must be good and the spraying must be seen to begood. If there is low pumping or pressure then the spray arms will not turnaround to inject with pressure. If sothe pump must be checked for clogging.To replacecheck this link:http://www.espares.co.uk/advice/dishwashers/a/3/1293/how-to-replace-the-spraying-system-on-a-dishw.html Finallyafter the wash the drain valve will be activated, the water is allowed to comein to rinse and then finally the drain valve/pump activated so as to drain offall the water.Make surethat a fault in any of the cycle will relate to the specified action, so checkthe command from the program module and then the executing device be it thevalve or motor or pump. Please check the link below:http://www.espares.co.uk/advice/dishwashers/a/3
Jan 27, 2012 | Blomberg DW 15140 Full Console Dishwasher...
My model DU810swkqo dishwasher will not drain completely [leaves about a couple of qts of water in the bottom after cycle.It has started dripping water out the bottom of the door.Can or does it need drain...
Hello
If the water won't drain from the dishwasher, first manually remove as much water as possible and then check the sump area for paper or any other large object. Make sure the door is properly latched. The pump will not drain if the door is not latched properly. Check the belt, drain line, air gap, drain valve and solenoid assembly, the motor, and the pump. If your dishwasher uses a belt to drive the pump, and it has broken or come off the pulley, replace it.
A cup or so of water in the sump area of your dishwasher is normal. It is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
If you have recently installed a garbage disposer in your home, make sure that the drain plug on the disposer has been removed. It's just a little plastic piece that blocks the hole where you hook the dishwasher drain hose. If your dishwasher drains through the garbage disposer, you need to run the garbage disposer before you run the dishwasher to make sure that the drain is clear.
There is a drain hose between the drain valve or pump and the garbage disposal or drain line. If an obstruction has blocked this, then your dishwasher won't drain. The drain hose is connected by clamps to the drain valve and the disposer or drain pipe. Remove it and visually inspect it for a clog or a kink. Try to remove any debris. If it is in good condition, just put it back on, and if not, purchase a new one to install.
If you don't have an air gap in the drain line, at least use a high drain loop. Making a large loop about 18" off the ground with the drain line can prevent any back flow into the dishwasher from the sink.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it's possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
Like the inlet valve, there is also a drain valve on most models. When no power goes to the drain valve it remains closed and prevents water from leaving the machine. When the valve receives power during the drain cycle, the solenoid opens and allows the water to leave the machine. If your drain hose is attached directly to the pump, you don't have a drain valve. The motor simply reverses and the pump sends the water in the opposite direction, which is out of the machine.
If the motor doesn't turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
Small objects can sometimes get stuck in the pump. When this occurs, you'll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.
Aug 06, 2011 | Dishwashers
My dishwasher didn't drain the water out on the end of the clicle? What could be the problem?
Hello, Thank You for using FixYa. I will be helping you today.I would start where your drain line connects to the house drain,This is where most blocked drains happen. Disconnect the drain line and put it in a bucket and try to drain the dishwasher. Chances are its blocked somewhere you just have to find it.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Microwave Ovens
Hello. after washing water still inside of machine. MAYTAG QUIET SERIES 300.
Hello there and thank you for choosing fixya
Drain line/air gap
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt
One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor
If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer
Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Jun 29, 2011 | Maytag Dishwasher
Dishwasher will not fill up.
Set the controls to off then power off at the mains for 30 mins and then power mains back on and run a drain program or a full wash program. If the water won’t drain away then the most likely problems are the door interlock switch is faulty, the drain water motor is faulty, there is a blockage in the drain outlet pipe or filter – this will need unblocking, there is a blockage in the water pump – this will need to be unblocked, the controller board is faulty – but this generally shows an error code. First turn off the mains power to the dishwasher then check the internal filter and screen and clean it thoroughly. Then check the waste water hose and any outlet valve and make sure that it is unblocked and free of any obstruction or waste material. If you have access to the water pump you can check that it is free of obstruction and is able to turn and that none of the impeller vanes have been damaged. Then if all this is OK then try turning on the mains power and running a hot wash cleaning cycle to flush out any remaining sludge / debris.
If the outlet pipe is clear and the pump motor is turning and there is no pump damage then there has to be a blockage somewhere. You could lay the out pipe flat on the ground with the end draining into a tray to see if any water actually does come out. If it does then you do not have a total blockage. This is because it will be most likely draining out of the machine due to gravity and shows that there may be a partial blockage of the pump is defective even though the motor may be running. You will need to remove the pipes to and from the pump to check for blockages and also remove the pump to inspect for damage to the impeller or a blockage in the pump housing where the hoses connect. If the pump housing is clear and the impeller can be turned freely with your fingers then the direct coupled or belt driven linkage between the motor and the pump is the most likely broken and will need repair or replacement. If the impeller cannot be turned easily and does not turn with the motor running then the impeller or the direct linkage is either seized or broken and will need replacing. If your pump and impeller is belt driven then check that the belt is not slipping – this will normally result in increased noise and a possible smell of burning rubber
Dec 30, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
104 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
