Question about Brother SE-270D Computerized Sewing Machine
Bobbin Problem My Brother SE-270D is brand new. I have made two simple dresses for my daughter and have logged maybe 2 hours doing so. As I started sewing a pair of bloomers, my bobbin started making a clicking sound every so often. The clicking sound grew more frequent as I continued. When I inspected the fabric of what I sewed, there are several loops in the thread on the bobbin side (the stitches on the top side looked fine). I took the bobbin out and put it back in several times, I changed the tension, none of that worked. A friend with much more experience than I said the machine is pulling too much thread through from the bobbin but she has no idea why. Any thoughts?
There is a thread tenchener screw that the repair center has to ajust so it will have the tenchen Dan
Posted on Apr 04, 2007
Brother se 2700 will not sew on knit fabric
Check that you are using a ballpoint needle, designed for knits. Also, be sure that the thread is not 100% cotton thread.
Jul 15, 2014 | Brother SE-270D Computerized Sewing...
I have a Brother Se 270D sewing/embroidery machine. It makes a terrible grinding sound and won't go all the way up or down. I have removed the thread, bobbin, and bobbin case and cleaned all of...
Take it in for service, hopefully it is still under warranty, I have sneaking suspician that your motor is causing the problem. I had a machine that did that and it turned out to be the motor.
Apr 20, 2011 | Brother SE-270D Computerized Sewing...
Having issues with my Se-270D can you help
The brother machines are notorious for jamming if there is even a tiny bit of lint in the machine. Take out your bobbin, unscrew the plate, take out the bobbin holder. Use a pipe cleaner or paint brush to brush all around inside the machine and pull out any little threads/lint that has collected in there. Replace the bobbin holder by lining up the screw toward the front. Replace the plate and screws. Make sure your bobbin doesn't have any little nicks around the edges that could catch thread. Replace the bobbin and rethread. Replace your needle (this needs to be changed often) rethread your upper thread. Test stitch.
Mar 16, 2010 | Brother SE-270D Computerized Sewing...
I'm new to embroidering. I have BrotherSE-270 Disney. I have read through the manuel several times and am confused about the bobbin thread. Do I use tread specficaly for embrodering or will regular thread...
Your machine probably came with brother embroidery bobbin thread (one spool, white)...I used it until it was gone and did buy more embroidery bobbin thread at a regular superstore (it wasn't brother brand though)...however, I have since used regular thread and not had problems. HOWEVER, be sure it is good, quality thread - none of that $.50/spool stuff. That knots up and simply doesn't look good if it does work. Good luck!
Jul 08, 2009 | Brother SE-270D Computerized Sewing...
Brother SE-270D sewing machine bobbin won't wind
the rubber ring on the bobbin winder has probably gone bad which would mean replacing it but you can buy a portable bobbin winder called a sidewinder for around 20.00
Jun 16, 2009 | Brother SE-270D Computerized Sewing...
Error message on Brother SE-270D
I had the same issue a few years back but with actual symptoms of malfunctioning. I had mine fixed under warranty. The service tech told me it was a faulty circuit board. Works perfect now. I think the warranty is only for the first year to cover labor and parts. Not sure how much it would be out-of-pocket. This happened within 3 months of a brand new purchase. Hope this answered your question.
Mar 16, 2009 | Brother SE-270D Computerized Sewing...
Instrucitnos for Brother SE-270D Timing Problem
This is not really something you can do yourself (been there, tried that!). The machine has to be almost completely disassembled to get to the timing mechanism. Trust me, it's worth the 30.00 to have it timed.
I think http://www.allbrands.com has a generic timing explaination for sewing machines (use the drop in bobbin one)...I found it easy to follow...but once I realized I had to unplug all the components for the computerized functions... I took it in to the dealer. If you contact Brother & your machine is under warranty, they will pay for the repair (they paid for my first two re-timings). Now I know you HAVE to use BOBBIN thread that is 60 WT only in the bobbin. You will continue to have problems if you don't. Also, this machine uses the class 15 bobbin, but make sure its model number SA156A, which is a hair taller than the SA156 bobbin..both are class 15, but the tiny difference is very important.
Jul 26, 2008 | Brother SE-270D Computerized Sewing...
Brother SE-270D Jams below needle plate
Comment by margecam52, posted on Aug 12, 2008 It's the bobbin thread. Also, it does not have to be Brother brand. Any 60wt thread will work. I get mine at http://www.threadart.com
They have it on large cones, and I use a cone holder to fill my bobbins. I have not had a single problem since. I like this thread because it has a sheen to it. I also have a longarm quilting machine & I use this bobbin thread 95% of the time. Also, be sure to check the bobbin area (remove the plastic & the metal plates) for lint buildup... I have a small, soft artists paint brush that I use to remove the lint build up with. I check after every embroidery run.
And for the thread not coming through...mine does it when I change thickness of threads. There is an adjustment wheel on the front of the machine, I turn that...seems to make the difference...not even sure that is what it's for...but it works for me.
Oct 12, 2007 | Brother SE-270D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
159 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
