Question about Frigidaire GLER642A Electric Dryer
I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The dryer continuously dries - does not shut off when clothes are dry. Runs non-stop.
  • hotpimp54 May 11, 2010
    does the timer advance
    Sergeant:
    New Friend:
  • 322 Answers
To the person asking for the user manual, you can get the documentation you need here:
Frigidaire heavy duty dryer manual
Posted on Dec 06, 2014
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Posted on Jan 17, 2011
My whirlpoool dryer runs but shuts down before clothes dry and won't start back up untill it sets awhile
oh oh sounds like a bad motor with burned windings? let me guess it shuts down after about 20-30 minutes?
May 26, 2014 | Frigidaire FER311FS Electric Dryer
I have a Frigidaire Gallery Heavy Duty electric dryer, the dryer run non-stop even on auto-dry mode (timer doesn't advance) but the clothes aren't drying either.
Timer will not advance unless the element is working. Suspect bad element or bad thermal fuse on element housing
Dec 11, 2013 | Washing Machines
I have a frigidaire dryer gler642as3 model it ran for two hours and didn't stop also when you open the door during the cycle it shuts the drum off but the dryer gets very hot you can't touch it what can it...
Well the timer could be defective. But believe it or not a clogged dryer vent can do some of the same things. Without air flow, the heater will heat, then when it doesn't circulate and and dry clothes, it gets hot and the hi temp overload near heater should turn it off, then when it cools it will start the same cycle over. Make sure you have good air flow coming out of the vent outside. If in doubt disconnect hose from dryer. Make sure to remove any lint. Put a panty hose leg over the hose and try the dryer. If it heats ok now, then you know your vent is clogged (panty hose will keep lint from spraying allover your laundry room)
Oct 28, 2010 | Frigidaire Timer Knob
Friidaire Gallery Dryer, Model # GLER642AS3, S.S. # XD50808416 does not heat when in operation
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 14, 2010 | Frigidaire Dryers
I have model # crgr7900A31 gas dryer front end loading. The dryer will not shut off. It continues to run.
Hi, If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Apr 14, 2010 | Frigidaire FGQ332ES Gas Dryer
Why is my Frigidaire Gallery dryer not getting hot enough to dry clothing?? It gets warm to te touch but cant dry the clothing within the time settings.
Check out this tip and the other ones at the bottom of that tip...
if you have a gas or electric pick the tip that are for your dryer..
http://www.fixya.com/support/r4312805-dryer_maintenance
heatman101
Mar 25, 2010 | Frigidaire Dryers
GE Profile dryer - automatic dry never stops
ok go back to that page and
look in the
backsplash, blower section
you are looking for part
230
Oct 15, 2009 | Dryers
Frigidaire combo washer/dryer screws inside come off
The drum shaft came loose from drum. You can YouTube it for procedure of disassembly of dryer. Remount shaft, if screws are bad may need new shaft with screws, make sure it is tight to drum. While you have it apart you can clean out lint.
Sep 27, 2017 | Frigidaire GLER331A Electric Dryer
We have a Frigidaire Gallery dryer with a moisture sensor. I've had this model in the past with no concerns, but our current model doesn't seem to work as well. When set to an "automatic" cycle...
mamch,
You said,We have a Frigidaire Gallery dryer with a moisture sensor. I've had this model in the past with no concerns, but our current model doesn't seem to work as well. When set to an "automatic" cycle (where the moisture sensor is used) the clothes don't always come out dry and it has to be turned on again. Would there be any reason for this?
What's the model # and the age?
There are two types of moisture sensors.
One has to strips of metal on a black disk looking thing on the dryer rear wall and the other works on steam rather than contact!
Could be you had the better on before that was the contact one rather than the steamm sensor!
How long to dry a load of clothes ?
Sep 18, 2008 | Frigidaire Dryers
Frigidaire GLER642A Electric Dryer Logo
1,640 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
