Question about Clarion RDB325D
Clarion RDB545D Preamp Output
I have a Clarion RDB545D and the preamp out put is not working. Is there a way to turn this on and off? Or am I just going to have to get a new unit.
Thanks
  • rocxing Jan 02, 2009
    I also have this problem w/ a similar Clarion deck. How would i get into the menu if thats where i can control it?
  • 62 Answers
There should be a way it may be called sub out in the radio menu
Posted on Dec 20, 2008
I have a hcdh771 compact system and I want to add a Sony ps-lx52p turn table. Can you please help me do this.
You need to buy a phono preamp to add in between the LP player and the music system. Can connect the LP player output to the phono preamp input and output of the preamp to the aux input of music system.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 18, 2016 | Sony Audio Players & Recorders
Where do I connect a turntable to the AVR132? Do I require a phono preamp - if so where does this connect into the receiver?
Most amps / receivers that lack an input specifically labeled "Phono" will require a preamp for the low output that originates from turntables with modern, MAGNETIC cartridges. If your cartridge is a *much* older (1960 ~1985) CERAMIC type, it will not likely need a preamp as the output is greater than a magnetic type.
You should select an unused stereo (left & right) INPUT device such as "VID2" Connect the output of the preamp to these jacks and the turntable should be connected to the preamp input as per manufacturer's instructions.
Oct 23, 2015 | Audio Players & Recorders
What kind of pre amp do i need to operate my parasound HCA-2205A high current power amp
Any preamp should work. A preamp goes into your system between the amp and the other components which plug into it- CD player, FM tuner, Turntable.....etc. It's takes their output signal, processes it as my be Volume, bass, treble... and then send a sufficient signal to the amp to drive the amp to power your speakers. As long as the preamp output is enough for your Amps input any will work as most will be.
Nov 02, 2014 | Audio Players & Recorders
How do i attatch preamp to marantz sr9200 for phono
If you are talking about a phono preamp, take the output rca cables from the turntable, "red and white" plug it into the preamp input, "labled" next take a red and white cable wire male ends, "3 to 6" feet long, and plug the one end in the output of the preamp, "labled" and finally plug the remainder into the AUX input of the Marantz receiver matching the colour codes so the left and right channels don't get mixed up, you now should be good to go.
Apr 15, 2012 | Marantz Audio Players & Recorders
What are the RCA plugs for on the dxz855mp
Hi, your head unit has 6 RCA preamp outputs and 2 RCA sub-woofer preamp outputs. These outputs connect to amplifiers if you care to use them. You can read all the specs and download the users manual at the following URL:
http://www.crutchfield.com/S-lAJZzNi4tYJ/p_020DXZ855/Clarion-ProAudio-DXZ855MP.html#details-tab
Please let me know if you have more questions.
Dec 13, 2011 | Clarion DXZ855MP CD Player
I have a Pioneer VSX-515 6.1 system and I am trying to hook up my phono to it. I am not sure which input to use. Right now the only input I have is my CD player.
Like many newer receivers, this model doesn't have a phono input. I guess manufacturers think nobody listens to vinyl today. You can still hook a turntable to one of the extra audio inputs on this unit, but you'll need a phono preamp. The output level from the turntable is too low to drive a "line level" input directly, and the preamp boosts and equalizes the signal so it will work properly. Radio Shack still carries a preamp; you can order online or find it in some of their stores. Many other sources are available online, and if you have a good stereo shop in your area they probably stock one. Plug the turntable to the preamp input, connect the preamp output to the receiver and that's it. You'll also need an AC outlet nearby as the preamp needs power.
Mar 21, 2011 | Audio Players & Recorders
I own a Fisher X-202-B tube amp which I have restored with new caps. It played very well for 2 weeks,then one input section suddenly went dead. It doesnt matter if I use tuner,AUX or phono,there is zero...
i) It is possible that one of the electrolytics has been put in with wrong polarity. Check in the faulty channel preamp. It may have caused the HT to collapse in that preamp section - look for burnt resistor.
ii) Also compare the corresponding voltage on the anodes of the preamp valves in the working & non-working channels. This will tell you which area is faulty.
Feb 15, 2011 | Audio Players & Recorders
Some where there is a button to switch between a powered AMP and a Nonpowered AMP. Can you Tell me Where to Do that??
I might need some clarification on your question and what you are needing this receiver to do . But let me take a shot at this. Your amp has a powered output via the speaker terminals and a preamp output via your record output rca jack or any other rca jacks label preamp out or preout. I is no switch to turn your power amp on while leaving your preamp on, but you can switch the speaker a and or b switch off if you like. If you are refering to a powered subwoofer set up you would connect this to your preamp subwoofer out jack then very the level with the subwoffers volume control. You might need more detail in your question if this is not what your looking for.
Jul 16, 2009 | KLH R5100 Receiver
How do I connect a Polkaudio powered subwoofer (psw 125)
Connect a set of stereo RCA cables from the 'Output 2' on the Hafler to the line imputs on the Sub.Turn on the '1+2' output switch on the Hafler and rock out!
Dec 16, 2008 | Marantz PM7200 2-Channel Amplifier
Car Audio & Video Logo
201 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
