Question about Dell Dimension 8300 PC Desktop
System battery is low
When I turn on the computer the following message appears on my screen: "Alert! System battery is low. Strike F1 key to continue, F2 to run setup utility." When I press F2 there are a lot of options but none of them appear to cure the battery is low problem. What should I do?
    Master:
  • 763 Answers
It should be replace the bios battery from the motherboard. circle silver color and it should be available on some computer shop.
thank you for using fixya
CHARCOIS
Posted on Dec 20, 2008
  • Charris Suaybaguio
    Charris Suaybaguio Dec 20, 2008
    if you can still locate the battery then try to look on your manual for information.
    CHARCOIS
  • 679 Answers
Go to radio shack and pick one up, you should get a half dozen on ebay for a few dollars, I keep them in with my computer tools, they have bailed me out on more than 2 occasion, take the old battery with you as they aren't all the same, good luck
    President:
  • 1,073 Answers
Replace the system battery, no more no less
Good luck to you
  • Dell Master
  • 19,396 Answers
You need to replace the CMOS coin shaped battery that is located on the motherboard.
  • Ginko
    Ginko Dec 20, 2008
    You need to phisically have the Bios battery replaced. By pressing F2 you only enter in bios settings, do not change anything on that menu, as the computer may not start afterward.
    Changing a CMOS battery is not a difficult operation, and the battery is cheap, but if you have not done it before, there is always risk to damage the motehrboard.
    See How to replace the CMOS battery.
-"Alert! System battery voltage is low. Strike the F1 key to continue, F2 to run the setup utility". Wie bekomme ich die Fehlermeldung weg?
to me it seems like your battery is not charging.use volt meter to check output from your adapter or change battery.
Whatever you do do NOT keep using computer until its sorted as you can ruin your windows installation or hard drive
Dec 06, 2016 | Dell Computers & Internet
CPU Fan Failure
ask the Dell support of directions, they will guide you.
Mar 27, 2012 | Dell Inspiron 620 ST Desktop Computer...
I have a Dell 8200 PC. It is 8 years old. since last week and everytime I restart my PC, I receive this alert: Alert! System battery voltage is low. Strike the F1 Key to continue, F2 to run the setup...
The cmos battery on the motherboard needs to be changed, it keeps the date and time and other functions in check. The battery is silver in color and shaped like a round coin, I would recommend a tech to set up the bios for you to make sure everything is working properly.
Feb 23, 2011 | Computers & Internet
I have a DELL Vostro 1500 laptop, since the last 2 weeks it appeared a message when i turn on my laptop, it says: " The AC power adapter wattage and type cannot be determined. The battery...
Certain models talk to a chip in the adapter, sounds like this one has gone bad. At this point you can live with, buy a new one or pick up a used. This is a fairly popular model and you should be able to locate one from a dead laptop.
Mar 06, 2017 | Dell Vostro 1500 Notebook
Have a Dell XPS 600 problem. I am getting a message when I turn on the computer, "Keyboard Failure Alert! System battery voltage is low. Strike the F1 key to continue, F2 to run setup utility." What should...
If you have another keyboard try swapping it out and see if it reads the new one. Also a stuck key could possibly cause this error. System battery message probably means you need a new battery for the motherboard. If you replace the battery get the new one before removing the old one. If you leave it out too long you can clear the CMOS
Oct 14, 2010 | Dell XPS 600 PC Desktop
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Strike F1 to continue, F2 to run the setup utility
Got to BIOS by pressing F2,check or any floppy setting and disable it even in boot order setup.This will solve your problem otherwise replace the lithium CMOS battery.
As you have reset the BIOS setting to it's default setting.Floppy drive is enable by default whether your system have a physical floppy drive or not.
Dec 24, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Latitude delld610 Boots with the following
press F2 to get into the dell bios and be sure the HDD is listed as first to boot, Then if restart turns the same error, press F10 and run the pre-boot system assesment check. if error 0141 appears, your HDD is failing and needs to be replaced
Aug 24, 2009 | Dell Computers & Internet
Strike F1 key to continue, F2 to run the setup utility
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
May 28, 2009 | Computers & Internet
Dell Dimension 8300 PC Desktop Logo
149 people viewed this question
Alun Cox
