Question about Magic Chef 31000 Gas Kitchen Range
Oven Door Hinge Squeaks
The oven door hinge on the right side just started squeaking a little while ago, what can I use to lubricate it? The oven is in use about 4 years now and it is level. Magic Chef,, just three years old, oven door screeches upon opening. When hot, it's worse, but also squeaks slightly when cool. Tried WD-40, my favorite, even with the thin tube attachment to reach far within the hinge. Worked 'til I used the oven once, then back to fingernails on blackboard. Thanks in advance?
  • 640 Answers
Its not the hinge,,its the sping in the hinge,,you have to replace it,,,be careful with ludes on stove...onthejob
Posted on Jan 19, 2009
Putting door back on but hinge wont release to put back on
Hi Susan, this is AP! Thank you for your post.
I understand you are having trouble putting the door back on your Frigidaire wall oven. Without knowing exactly how you removed the door I cannot say with certainty how to reattach the door. However, when removing the door did you pull up the lock located on both hinge supports and engage it in the hinge lever hooks? You might have had to apply a little downward pressure on the door to pull the locks fully over the hinge lever hooks. Then grab the door by the sides and pull the bottom of the door up and toward you to disengage the hinge supports. If so, then to reattached the door grab the door by the sides; place the hinge supports in the hinge slots. Open the door to the fully opened position. Disengage the lock from the hinge lever hooks on both sides. Make sure the hinge supports are fully engaged before unlocking the hinge levers. Then close the oven door. There are instructions with images to remove and replace the oven door in the owner's manual. I hope this information proves helpful for you.
Mar 14, 2014 | Frigidaire FEB30S6D Electric Single Oven
Squeaky door
Buy a spray can of silicone lubrication and spay the hinges wipe off any over spray rotate the door 3 -4 times also clean door seals thoroughly, repeat if necessary.
Mar 10, 2014 | Maytag MSD2756G Side by Side Refrigerator
Remove oven door from hinges
the door is removed with the hinges in place. with the door open, lock the hinge sections together with the little clips on lowest hinge section. When locked, lift up on the door (not the handle) sides, swinging it up until it can be pulled out. Install in reverse order.
Feb 17, 2014 | Thermador Ovens
Oven door keeps open ay ideas about the fault cheers
make this test and fix it. GOD BLESS YOU
Door Hinge
An oven door repair may be needed if the door hinge breaks or is bent out of shape. Oven doors have two door hinges, a left and right. On some ovens the same hinge is used, on other ovens the right hinge and left hinge have different part numbers. The door hinge sometimes is sold with all necessary parts and springs, other times the parts need to be ordered separately. An oven door repair for a door hinge is a relatively easy repair for a do-it-yourselfer.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Outer Door Glass
If the outer door glass is broken, it can be replaced. This oven door repair requires that the oven door be removed from the oven and layed down on a sturdy flat surface. The outer door glass is made of tempered glass. Use eye and hand protection when performing this oven door repair.
Nov 04, 2013 | Kitchen Ranges
Is there any grease points for the door hinges? The door squeaks every time we open.
Hello. Get a can of a penetrating lubricant called WD-40 with a tiny tube applicator included. Open the door and you will see part of each hinge where the door meets the appliance case. Spray the penetrating lube on the exposed part of the hinge and then open and close the door a few times. Repeat as necessary. J.
Jul 01, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Squeaky Door
Open the door and look at the bottom hinge. There is a plastic piece between the door and the hinge, this is called a cam, it helps keep the door in different positions. The cam should not move when the door moves, if it does you should be able to tighten the screw holding it on. If it does not move then a little lubricant on that cam should help.
Apr 18, 2010 | GE Â 17.9 Cu. Ft. Top-Freezer...
Frigidaire dishwasher door squeaks when opened and closed
I had the same problem and this worked like a charm:
http://www.blog.applianceoutletservice.com/2008/12/frigidaire-dishwasher-door-squeaks.html
All you'll have to do is take off the kick plate, actually remove the cords, and lubricate with soap (lower tech than spray silicon, but it's worked so far...)
Aug 22, 2009 | Frigidaire PLD4555RFC Dishwasher
Replaced hinge on smeg double oven but now oven doesn't heat
I have the SMEG F170-5 and had this problem after cleaning and replacing the door. It wouldn't heat unless I banged it shut. This action made the internal switch trigger, so I had to remove the oven (4 screws, slide out) and remove the right side panel (4 screws). The switch is actuated by the right hinge strut and it must have become bent slightly. I bent it a bit towards the door so that it would just a little bit more likely to make the switch trigger with the door closed and it now works fine.
Jun 12, 2009 | Smeg S351X/5 Electric Single Oven
Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
May 23, 2009 | GE Ovens
Magic Chef 31000 Gas Kitchen Range Logo
904 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Sal De
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
