Question about Coby MP-C7085 MP3 Player
Coby MP610 can't play while charging
I just got a new Coby MP610-4G MP3 player. I want to use it as a dedicated MP3 player for my car. Here's the setup I'd like to achieve:
1. connect the player's stereo output to my (cigarette light socket) FM transmitter's stereo input.
2. connect the player's USB port to the transmitter's USB port for continuous charging.
Both steps 1 and 2 work flawlessly when connected on their own. However when I try to hook both simultaneously, Coby player goes automatically into a standby mode and stops playing (the same can be reproduced when you hook the player to a PC's USB port while playing music on it).
I read all Coby manuals I could find, searched the Net for a possible solution, and could not find any. So, is there a way to force Coby to play while charging?
Thanks in advance.
  • Anonymous Mar 29, 2009
    Have the same problem guess I will have to get another one
    Problem Solver:
  • 5 Answers
Nonono
Posted on Sep 17, 2009
How do you put a video on the Coby MP620 [4 GB] MP3 PLAYER
You can put a video on the device using "Coby Media Manager". To install it:
1. Plug your device into the computer
2. When the Autoplay menu appears, select "Open Folder to View". If no Autoplay menu appears, then look for the device in My Computer.
3. Launch the "coby-cometlite.exe" file and follow the setup instructions.
4. Now you should be able to use "Coby Media Manager" to automatically convert and transfer videos to the device,
Mar 05, 2011 | Coby MP620 MP3 Player
When I plug in my mp3, i cant sync because wmp doesnt recognize the mp3 at all. I was trying to find software or driver download to help fix. please help!
Hi, Looking for Drivers.
In order to download the right driver for a Coby MP3 player, you'll need to go to the Coby website support page where you can download software drivers (See Resources). To find the driver you need, you first need to identify which device you're using. Select "MP3 & Portable" under where it says "Select a Product" on the first box on the left. In the second box, it will be "MP3 & MP4 players." The final box lists all of the MP3 and MP4 players that Coby produces. You'll need to find your MP3 player in this list. The designation will be letters and number such as "Mp200". It should be listed on the box. Once your MP3 player is selected, clicking on the "Submit" button at the bottom will cause the text "Available Downloads for Mp200" (or whatever your MP3 player is called) to appear towards the bottom of the screen. Underneath, there should be a link for "Driver," if there is one available for your player. Clicking on that will allow you to download it.
Installation
If you click "OK" on the download screen, your driver should install. It will likely be in a ".zip" format, which means another program is needed to "unzip" the file so that you can install it. An example of such a program is WinRAR (See Resources). This program needs to be installed first, before it can be used to unzip your driver file. After you've downloaded the program, opening the installation file will begin the installation process. Choose a directory for where the program will be installed. After installation is complete, you can go back to the ".zip" driver file. Double-clicking on the file will bring up a new window. You can now drag your driver files from inside the .zip folder to any folder on your computer that you wish. There will be a file marked "Setup" among the unzipped folders. Opening this file should allow you to install the drivers you need on your computer.
Also Coby mp3 player not recognized by the computer.
Why is my Coby player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Coby mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Coby mp3 player can connect to your computer in MSC or MTP mode. Exceptions are Coby mp3 player Connect and Coby mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for Coby Players when used with Windows OS.
The Coby player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope that helped..
Feb 21, 2011 | Coby MP-30523 MP3 Player
Cant play video
1. Turn on the MP3 player, go to Settings/Setup - System - Change USB mode to MSC
2. Connect the MP3 player to the computer
3. The MP3 player will show up as a Removable Disk drive under 'My Computer'
4. Double click on it, it will load Coby Media Manager, follow prompts to install
5. Click the 'Movie' tab at the left hand side of Coby Media Manager, the software will scan your computer for video files.
6. Once your video shows, right click the video, and click 'Sync', this will add the video file to your MP705 with the correct format.
If you need the Coby Media Manager:
http://www.digdash.biz/product/coby/coby_media_manager/install/coby-mediamanager-2009b0924.exe
Nov 14, 2010 | Coby MP-705 Digital Media Player
I have a new computer and need the software for my coby 610MP3 player. What is the download software website? ANd how do I download itunes to this mp3 player for my sons.
Go to cobyusa.com for Coby support.
Specific downloads for the MP610 can be reached if you enter MP610 in the Product Search bar.
When you need Coby Media Manager go to the link "fix for MP822" on the support site cobyusa.com: the fix is the Media Manager from Coby, it can be installed for Windows as well as for Mac.
When using other software programs like Windows Media Player 11 or iTunes, look in the help function or internet site for the used program.
For transfers mainly go through next steps:
0. First install and update the software you will use for transfers
1. Running the software program, the player can be detected in the used software program when connecting the USB cable
2. Setup the library in the used program: the location of the media files must be marked to have access to the data
3. Create a playlist: for example put songs in a list
4. Transfer the playlist onto the player: synchronize the list
5. Wait until the data finished synchronizing; wait for the message you're allowed to disconnect, after that you can take out the USB cable
Jun 13, 2010 | Coby MP-610 MP3 Player
How to get songs back in the coby mp3?
On the MP610 you could use either Windows Media Player 11 or Coby Media Manager for transfers of songs.
Next steps are important for adding files onto the player:
1. The player should be detected in the software for transfers, when connecting the USB cable.
2. Setup your library in the software (Add to library): There has to be a list of folders in the software manager, where your music is located on the computer.
3. Create a playlist in the software: make a list of songs, you want to transfer onto your player
4. Sync the playlist onto the player.
When needing more help, just add text in this reply.
May 11, 2010 | Coby MP-610 MP3 Player
My coby m600-4g mp3 player is connected to my computer through a usb port how ever my computer is not picking up the device. How do i get my computer to recognize the device as removable media?
You can install Coby Media Manager from the manufacturer.
Go to cobyusa.com
Select Support
Select the download Media Manager fix for MP822
Follow up the installation of Coby Media Manager for the operating system on your computer.
After the installation, run Coby Media Manager.
In Coby Media Manager, In the page top select: Tools > Device Manager...
From the Devices list select the matching MP600 AC or AL version.
Add >>
Select OK to setup the matching player as Favorite device.
In the Device Manager under Configure... or Device Configuration you
can choose between manual or automatic setup for synchronization
and the output file format can be changed.
Apr 23, 2010 | Coby MP-610 MP3 Player
My coby mp touch isnt connecting to my pc
Turn on MP3 player
Go to Setup > System > USB MODE
Put the USB MODE to MSC
Reconnect to the computer
Your computer should then recognize the MP3 player.
Apr 12, 2010 | Coby MP-705 Digital Media Player
My coby -mp 610-2g was hookup to my cpu and i
Having devices connected during reinstallation of the Operating System will lead to a faulty detection on the USB ports.
Connected devices will not be recognized.
How to get the USB ports functioning again:
>0. First disconnect all apparatus connected to the USB ports.
Step 1.1 will take a long time again, I'd prefer step 1.2:
1.1 Perform a new installation of Windows XP (the long way) or
>1.2 Delete all USB hardware in the Control Panel (the short way).
>2. Install the software for your device and perform an update.
Update Windows Media Player 11 and / or Coby Media Manager.
>3. Open the software WMP11 or the Coby Media Manager.
Connect the device and make a setup for connection in the
software you use.
When you need more help for software or hardware configuration, just add a comment.
Apr 04, 2010 | Coby MP-610 MP3 Player
I HAVE A COBY MP3 PLAYER MP610-4G AND I WANT TO KNOW HOW TO DOWNLOAD MUSIC ON IT I WAS GIVE A CAR AND IT WAS IN THE GLOVE BOX WITH NO MANUAL THANK YOU RON
1. You can get the Coby Media Manager here:
CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
2. You can get a PDF Manual here:
http://www.cobyusa.com/?p=doc
or click on one below:
Available Downloads for MP610
Downloads for MP610 1.8" Video MP3 Player
Mar 24, 2010 | Coby MP-610 MP3 Player
I need to know what type of USB cable I need for a Coby MP-C543? And what is the best brand to buy?
I can understand your problem. Coby MPC543 player doesn't need any dedicated USB cable it works with the regular USB cable itself... Kindly revert if you have any errors. Thanks in advance...
Jan 11, 2010 | Coby MP-C543 MP3 Player
Coby MP-C7085 MP3 Player Logo
406 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
