Question about Dell Computers & Internet
Computer won't power on
Computer will not power on, the power button is lit up yellow but nothing will come on
  • Mark Robinson May 11, 2010
    try taking the battery out and booting with mains only...what happens then ?
  • 55 Answers
If the light is glowing yellow that normally means a bad power supply. You can check this with a volt meter or you can replace the power supply unit if this is a desktop.
Posted on Dec 20, 2008
Power button not turning computer on
this is most likely a short in a computer component, You need to unplug everything from the computer incl CPU, Memory, Add on Cards, Hdds, the lot, just have motherboard plugged in and push power, if it powers up (there won't be a pic but you will know it's working) start replacing parts one by one until it won't start and that is the faulty part. If it does nothing with just motherboard plugged in the motherboard is at fault and needs to be replaced, If you have had the motherboard out make sure no of the metal mounts in the case are shorting out anywhere under the motherboard as this will also cause the same fault.
Mar 06, 2012 | Acer Aspire Z5600 PC Desktop
Steady yellow light
To reboot unplug the unit for 30 minutes. then plug back in. This may fix the problem, and try this link for troubleshooting PDF.http://homeappliance.manualsonline.com/manuals/mfg/bionaire/127176.html...
Apr 20, 2017 | Holmes Products BH3955-U Bionaire Utility...
My computer won't start up and is blinking yellow. How do I fix it?
An steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Nov 16, 2011 | Dell Inspiron One 19 All-in-One Desktop PC...
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
Gateway 500xl pc will not turn on power button is lit up yellow
A LOT of Gateway computers will go into this catatonic state because of a dead battery. The battery is on the motherboard -- it looks like a metal disk about 1" in diamter. Check it or replace it. This applies to laptops too (not the actual laptop battery, the CMOS battery -- a laptop will have one on the motherboard too)
Hope this helps
Mar 13, 2009 | Gateway 500XL PC Desktop
Have a yellow amber light blinking
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 25, 2008 | Dell Dimension 8400 power supply ** FREE...
My Dell Monitor isn't working....yellow light?
A yellow light indicates no signal input. Test it on another machine.
Feb 16, 2008 | Computers & Internet
Power on problem for XD7500
Hi. You need to check a few things. make sure you have power on both the red and yellow wire with the key on. If only one has power the radio will not work. If the red and yellow wires are switched it can also affect the way the redio operates. One is constant power for memory the other is key on power so the radio knows to shut off with the ignition key off. also make sure that you have a good ground connection on the black wire.. if nothing works yes you probhably have a bad radio. the dual brand radios are notorious for poor solder connections on the mainboard due to the way they build thier cheap circuit boards..
Aug 02, 2007 | Dual XD-7500 CD Player
Computers & Internet Logo
96 people viewed this question
Alun Cox
