The pin inside the charger port might be broken.
Look in the hole where you put the USB (on the device) there should be a tiny flat tongue sitting in the middle, if it's bent and touching the inside of the hole, it will need repairing. It's a very common fault.
You might be able to temporarily fix it yourself by trying to straighten it with a tooth pick. It's supposed to slot inside the micro USB plug.
First thing to do is try another charger, if that does not work then you need to repair the jack on the main board or get a new main board. They are not easy to repair.
I had this problem too. You can either use an android phone charger (easiest) or you can wrap the charger around it from top to bottom, still having it plugged in.
what model of ipad is it if its the third then its probably dead you need a different charger than the one apple supplied if you have or know anyone with maybe a Samsung charger for an s3 or s4 use your cable but use there Samsung plug it has a usb slot on it and would provide more power to charge it as the third gen drains very quickly and the charger they supplied isn,t enough to keep it going
First make sure your charger is working properly. Check it with a volt meter or use a friends charger that you know is working. Charge your Coby Kyros for 4 hours. Use a small needle and gently insert in into the "reset" hole on the back cover on the left side. Hold it down for 5 seconds then release. Try restarting your tablet. If these don't work, you will have to get professional help to check it out.
Possible charger damage.
If you know someone with a charger you could use, you should first plug their charger into your unit to see if it works, if not, plug your charger into their unit.
If your unit will not charge with new charger, you may have serious damage, if the other will not charge with your charger, your charger is broken.
The original chargers are known to wear out. Fuhu offers to replace (one time) with a more robust cable/charger. After that, ebay has lots of options for chargers and charging cables for the Nabi.
