Error 5100 first appeared due to pwer failure, and I corrected it with several different strategies, for example asking for a scan work instead of printing, that usually worked and re-set it. However, now it failed during printing and I can not get it to work at all. I tries to scan and then the scanning task is cancelled automatically.
Also, i have tried to align the printing and i keep on having problems, the lines are broken in some cases and the only time it prints ok is when I do texts and I use small type (palatino 10 for example)
hi!
try other remedy. for example, placing the usb connection behind your cpu instead on the front, if still didn't work out, try to uninstall your printer driver then reinstall it, then restart.
the broken line that you've seen and the reason why it doesn't print smaller font size is due to 1. low ink 2. the nozzle was clog (better clean it) 3. it needs replacement of cartridge to a new one.
don't panic, relax, okay?
Was this helpful?
Yes
No
Popular Solutions for Canon PIXMA MX700 All-In-One
After trying to run perferated card stock the printer never loaded if form the back and then...
(More)
After trying to run perferated card stock the printer never loaded if form the back and then produced an effor code 5700. I have cold booted unplugged and it remains locked out with the alarm light on
I get an error code 5100. Printer does not start to print. I have checked the printer head and...
(More)
I get an error code 5100. Printer does not start to print. I have checked the printer head and cleaned it. Only on print catridge is low and flashing.
