Question about Conair Weight Watchers WW-87 Body Fat Glass Scale
How to utilize the WW87 Glass Body Analysis Scale?
I'm trying to use the user function so I may know what my BF Weight, BF%, Body Water, and Bone Mass are. The problem is, I don't have the manual and when I use it in user mode and when it gets to the weight and I stand on it, all 4 sections say ERR...Only one time it worked, but I have no idea how I did it. May you help me?
  • 1 more comment
  • Anonymous Dec 28, 2008
    I too have the same problem. The scale indicates the weight in user mode, however all other readouts display as ERR.
  • kentlodge Jan 24, 2009
    OK. but if you dont have a manual, how do you set and use the bmil function please.
  • wildorchi135 Jan 24, 2009
    I know my numbers from the scale but now I need to know the ideal numbers for my %water and bone mass. Does anyone know of a website I can go to with tables and ideal number ranges i.e. I am 45 year old female and I assume my number would be different than a 20 year old.
Not only barefoot but also wet your feet before you step on the scale. I always weigh in right out of the shower.
Posted on Jan 23, 2009
I discovered that it helps if your feet are slightly damp. I usually wipe them with a washcloth before getting on the scale. They don't have to be WET, just every so slightly damp.
Posted on Jan 21, 2009
Select the appropriate User number, hit set.
Select the appropriate height, hit set.
Select the appropriate age, hit set.
Select the appropriate gender, hit set.
To use, select the same user number, wait for 0.0 to appear, and go for it.
Posted on Mar 22, 2009
I had the same problem and think i figured it out. here's what to do.
set your "user" setting by pressing user, then the arrow keys to adjust your height and age, and to indicate male or female (make sure you get these right because it's impossible to figure out how to re-se them).
after you get it set, press "user" until your user number comes up (1, 2, 3, or 4). the readout will display the same info you entered as your settings, followed by 0.0.
get on the scale, making sure your heels are on the metal pieces at the bottom of the scale. (some people seem to think it works better if your feet are slightly damp, although in my case it didn't matter).
the scale will first display your weight (ouch!) and then a few seconds later, the bottom line of text that includes body fat in lbs, body fat %, water % and bone mass index.
you can compare your #s to the table enclosed. hope this helps!
Posted on Feb 01, 2009
  • CMey
    CMey May 24, 2014
    What do you do if your user button no longer seems to be working? How do you fix that?
You have to step on the scale BAREFOOT to get the other readings.
Otherwise the scan fails and you get all ERR.
Posted on Jan 09, 2009
How do I obtain the bone,muscle,hydration,fat and calorie measurement on a dquip body fat/hydration monitor scale (infrared transmission body fat scale) I see the weight on the scale Bella
These measurements are based on BIA (bioelectrical impedance analysis). As you stand on the scale, you stand on electrodes, which generate small electric impulses which pass throughout your body (and different tissues of course). Different tissues have different electrical conductivity and resistivity due to their different hydration (e.g fat tissue contains very small % of water, that's why its resistance is high), so the scale measures the % of different tissues in your body by analyzing the resistance(this analysis is quite complicated and not very accurate).
Jan 18, 2018 | The Health & Beauty
Just replaced battery in my Conair WW87 scale and the numbers now do not display fully. Broken up
Recheck the battery connections and check the batteries, this type of display most times means low battery voltage.
Sep 12, 2016 | Conair Weight Watchers WW-87 Body Fat...
Goes to 88888 no matter what. How do I fix that?
Are you over 330 pounds? If not, remove the batteries and count to 10 and replace them.
Description Item # 00835165000P Model # 4GNC25302 The GNC WirelessWeight GS-7006 Digital Bathroom Scale accurately measures weight, body fat, water hydration, bone and muscle mass. This item features a removable wireless display that can be conveniently mounted on the wall, so you can see the readout clearly. Built with durability in mind, the scale is made from extra-strong tempered safety glass. The GNC bathroom scale also features an energy-saving auto on/off function and auto zero.
  • Removable wireless wall mount readout display
  • Measures weight, body fat, water hydration, bone and muscle mass
  • Energy-saving auto on/off and auto zero
  • Extra-durable tempered safety glass
  • Weight capacity: up to 330 lbs
  • Requires one 9V and 2 AAA batteries (included)
Apr 28, 2016 | GNC Digital Bathroom Scale
How do i reset my digial bathroom scale
Remove all the batteries. In ones with memory, there are two sets, a 9 volt and 2 x AA.
Jul 16, 2015 | GNC Digital Bathroom Scale
How do I get the User button on my Conair Curves scale to work again, so the scale does more than just measure my weight?
You need to press the buttons to use the functions. Do your buttons work properly? Or is that your problem? The manual is available for download at: http://www.conairscales.com/catalog.php?b[1]=1&product_id=437
May 24, 2014 | Conair WW405 Weight Watchers Tracker Scale...
Please tell me how to get an instruction manual for Weight Watchers scale Conair WW87
Conair has the manual on the product site: http://www.conair.com/weight-watchers-glass-body-analysis-scale-p-940.html . Scroll down for the link on the left. The direct link to the manual is http://www.conair.com/instruction_booklets/ww87_11ad124065_ib_FINAL.pdf .
I hope this helps.
Sep 18, 2011 | Home
What do the number mean on Curves Plastic Body Analysis Scale?
F = Body Fat
W = Water
B = Bone Mass
M= Muscle
Aug 31, 2009 | Health & Beauty
What do the three numbers represent? Weight is obvious, but "f" and then the last one?
http://www.conair.com/instruction_booklets/06AD15055%20IB%20TH313.pdf
I think this is the manual for the above mentioned product. Does it say f or BF? BF is % fat with in your body, although the techonolgy used is not too acturate, you can use it as a guide, to ensure the best possible acuracy be sure to use it at the same time of day preferably before drinking or bathing/showering. Usually first thing in the morning after you use the rest room is best. It uses electrical impedence to measure for the extra measurement features and these factors can skew the readings.
H20 would be water content, and
bone is bone denstiy which is important to keep take of espicially if you are an older female, or on medications that affect bone density. Although i am not sure how acurate the readings would be and highly reccomend if you are at risk for ostioparosis or any other diseases or on medications affecting bone desinties to check in with your doctor about testing and monitoring.
Apr 24, 2009 | Conair Weight Scale "Thinner" with Body...
Conair Weight Watchers WW-87 Body Fat Glass Scale Logo
7,085 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
