Question about Pioneer SD-533HD5 53" Rear Projection HDTV
My pioneer model sd-533hd5 shuts off after 5 mins and goes to stand buy
  • Pioneer Master
  • 5,138 Answers
Replace Both of your STKs ,if it has the STK392-110s do not go back with these they do not hold up use STK392-180s for parts call Electronix Parts 1-800-223-3205.
Posted on Dec 22, 2008
Pioneer SD-533HD5 53 in. Rear Projection HDTV Television - Need Manual ....
ManualsLib has the manual for the SD-533HD5 here: https://www.manualslib.com/manual/384249/Pioneer-Sd-643hd5.html . (The manual covers two models.) Once you modify the picture parameters (starting from STD, REF THEATER, GAME), these are stored as the User mode. If you press Menu when done changing the parameters, that input should maintain the User settings for the last setting until you change the Picture type. If you modified the parameters for STD and then return to that input and change the Picture to GAME, any modifications to the GAME picture parameters will become the new User Mode. See page 50 of the manual for the details: https://www.manualslib.com/manual/384249/Pioneer-Sd-643hd5.html?page=50#manual .
I hope this helps.
May 27, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
When I turn on the sd-533hd5 the picture has a green hue until it warms up. This can take 5-10 min. Mark
Hi,thats sounds like its the green tube override may need to replaced, or the green circuit drive transistor defective;
that is all i can say from here,may be maked check by a technician?
hope that give an idea about the problem
regards Alan
Oct 20, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
Cannot use convergence on remote for Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-533HD5 53 in. Rear...
Ur convergence it dead.Must know how to solders.Tries these Websites.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit.
Dec 29, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
My sd-533hd5 keeps blowing the 5 amp 125v fuses
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Dec 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Where to buy a convergence ic
This link may help you with the convergence problem: http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
You can just put the search "convergence ic" into EBay and get a list of sellers for the ic's.
Jun 26, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Sd-643hd5 shut down
its the problem in the power supply board of your tv.
check for the fuse on the power supply board.
for any blown capacitors or ics.on the powersupply board.
calling a tech is much advisable.if do not have proper technical knowledge.
it will not be too costly to get it repaired.
it is worth getting it repaired.as this is a common fault faced by many customers.
thanks.
Jun 22, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD 5575 - Needs to wam up
best thing i can suggest is buying a can of freeze from radio shack and spraying each ic/transistor till the problem appears again.
Nov 11, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Not turning on
Power supply board pull,then remove original solder on 5 volt
regulator pins then resolder + replace 4 amp fuse........T.
Oct 25, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
173 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
