Question about Makita BMR100 Radio
The radio's ac adapter does plug in
The radio's ac adapter does not work, can easliy be ordered from Makita. Radio works perfect from battery
Bought used ,is adapter equipted with a male part if so it is broken off in adapter slot. How can this be removed from adapter slot? Remove the front ?
  • 44 Answers
What kind of ac adaptor for mikita bmr 100
Posted on Jun 13, 2009
I had a similar problem and decided to take the radio apart to try and fix it. If the male part of the adapter is broken off inside of the radio, the only solution i could see would be to replace the radio"s adapter connection. That is the black piece the power cord plugs into. To do this you need to find a connector exactly like the one you take out and you also have to know how to solder components on a board. And if you decide its not worth it, you can just continue running the radio off of the makita batteries.
Posted on Jan 20, 2009
Makita radio working via electric but not on battery. battery is charged
Check the battery it may have a high internal impedance.
Nov 27, 2014 | Makita BMR100 Radio
Makita radio stoped working
mine shows 'E' on display. was sent away to be tested by Makita they said nothing wrong, faulty battery. bought new battery, still doesn't work. Makita not pulling their weight
Jul 04, 2014 | Makita BMR100 Radio
Hitachi UR18DSL site radio. works when plugged in, but not when fully charged battery inserted
test the battery with multimer for to see is o.k with the voltage. measure. Otherwise you can put the package with plastic bag(windzip) and put by 24 hours in the freezer from your refrigerator for to revival of your battery. and try again in your radio. ( this is smal secret for revival battery rechargeable.
God bless you
Nov 07, 2013 | Tivo DirectTV Remote Remote Control
I have had a Sony ICF SW7600 for the last 18 years. Now, it only wishes to work on batteries and not on the AC adapter anymore. What can be the problem and how to fix it
I have the exact same problem here in Europe with my perfectly with my Sony shortwave after 18 years. If I fiddle with the ac adaptor in the radio plug, it works for a while. I have replaced and soldered the yellow tip adaptor twice in 18 years and hopefully the problem is with the power plug and not the radio plug.
Any help is appreciated.
Dec 20, 2012 | Sony ICF-SW7600 AM/FM/SW Radio
My radio wont turn on when using batterys?works fine with the power lead tho?
my makita radio will only work with the ac power adapter and not any of my battery's it says to change the back up battery's which i did and still the same thing? has this happened to anyone else?? is there a easy fix for it?
Nov 25, 2010 | Makita BMR100 Radio
My Cobra Road Trip handheld CB won't switch over to battery power when I unplug the 12v adapter. How do I open the casing to check if the spring behind the connector can be repaired or replaced?
Make sure you have good batteries in it ,and installed correct. There should be a switch behind the battery,i think.... but there is a switch on it for ac or dc,switch it to dc,make sure you have the ac plug adapter end unpluged from it in order for it to work......hope this helps.....
Jun 28, 2009 | Cobra HH 38 WX ST CB Radio
ICF 2010, no sound suddenly
If the radio does not work with headphone then the external jack for audio may have broken loose from it's soldered points. Simple re solder may make the repair. Beyond that it would have to be diagnosed by a technician.
May 28, 2009 | Sony ICF-2010 AM/FM/SW Radio
Makita radio blinks e
usually the blinking E means the backup batteries are dead.
the backup batteries are AA and should go in the lower compartment on the rear of the radio.
just make sure you install the backup (AA) batteries in first, then insert your main battery to run the unit. doing it backwards wont always clear the "E" notification
Nov 25, 2008 | Makita BMR100 Radio
I have ASUS A3AC laptop bought in Australia. Now I am facing problem with AC power adopter I believe. Laptop only power up if i push it hard and try few times to connect and re-connect. Due to faulty...
All you need is a power plug adapter. At Radio Shack you can find one for US plugs to any other plug in another country. They will be able to order a reverse adapter, one to adapt Aussie plugs to US plugs. I'd start there and they'll find you one no doubt about it.
Regards,
Worldvet
Oct 21, 2008 | ASUS Computers & Internet
Makita BMR100 Radio Logo
1,648 people viewed this question
Top Makita Audio Players & Recorders Experts
Gil Shultz
Are you a Makita Audio Player and Recorder Expert? Answer questions, earn points and help others
