Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
TV turns off by itself
My TV turns off by itself several times. It will come back on, but only after resetting it.
  • lovebunnyok Jan 23, 2009
    Just to let everyone know. The problem got worse. It came to where it would not even turn on. Got it fixed. Had Sears come out. Come to find out, it was a loose flyback and a couple of the capacitors were loose, not faulty. I paid 220 to get those fixed, and TV is good now...so far. Keep your fingers crossed for me.
  • RCA Master
  • 5,138 Answers
Capacitor leaking/bad cp150 2200uf 16v and 2 others cp114-cp120 220uf 35v
Posted on Dec 21, 2008
2 Suggested Answers
SOURCE: tv turned itself off. turn power back on, picture
You have a problem with the main power supply regulator IC chip and the first step is to have that replaced. Does the set turn off this way when you play a DVD? Often a DVD will play fine all the way through when the reg IC is failing because the signal strength of the DVD is lower than the broadcast signal. If you replace the reg IC and the problem persists then you have to troubleshoot the High Voltage Shutdown circuit.
Posted on Dec 07, 2009
Hl72a650
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
Samsung TV model LN32A450C1DXZA, after turning the TV on it will turn itself off shortly after and then turn itself back on shortly thereafter. Then it repeats that several times before staying on.
If the tv is still under warranty, this can be repaired at no charge.
However, if not under warranty, you will need to have the CAPACITORS on the main power supply circuit board tested (or replaced).
The capacitors responsible for the power supply can sometimes fail - open the back panel. If the capacitors on the main power supply board look too fat, or signs of burning near the solder joints, then you've found the problem.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Samsung LE Televison & Video
The TV will turn on from remote many times and then won't turn on at all from the remote or directly from the TV itself so we end up unplugging the power which seems to reset the TV and then it
Having to unplug suggests a issue where the set is getting confused, if using any kind of box for signal or have a receiver in line remove power from all and after several minutes plug back.
Dec 17, 2012 | Vizio VS420LF1A TV
My Hisense TV just stopped working is there a reset button
What if the menu doesn't stay on long enough to get the lock setting changed Is there a way if we take the backing cover off to reset TV?
Apr 21, 2012 | Hisense TA42P40M 42 in. Plasma Television
The blue power button will blink several times but will not turn the TV on. What could be wrong?
Tries tv unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting.Now the tv should be working again.If still have the same problems.Than this tv have power supply board problems.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Feb 25, 2011 | RCA Televison & Video
The television turns itself on and off, sometimes several times a minute.
the processor has garbage in it, or a bad connection, or a stuck button, The first to do is too clear the processor , by unplugging the set from the wall for 40Min., and that will reset it back to normal.
Feb 11, 2011 | Philips Magnavox 20MS3442 20" TV
50" plasma panasonic 720p tv has several colored
Flashing error codes could be the Direct tv box itself.Because tvs have problems within itself don't flashes error codes on the tv screen,the problems,just show up.Tries tv and Direct tv satellite box unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting and the Direct tv box updates it softwares data's.The problems should be solved,if have the same problems,first call Direct tv for a replacement box,see how it work out.Than turn ur attention to the tv.
Feb 08, 2011 | Panasonic TC-P50X1 50 in. Plasma HDTV
The picture will go black and the sound will go out. At the same time, the green power inicator will flash. Then the picture and sound will come back on for several seconds and then it will go out again....
My TV had the same problem. I called Sony yesterday and they told me to reset the TV. I did so yesterday, and it seemed to work. Here is the transcript with instructions:
Please turn ON the TV. While holding down the RESET button on the Remote control, press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button.The TV will go thru the initial setup, and should work normal.
Aug 02, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
129 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
