Question about Sony Cyber-Shot DSC-P150 Digital Camera
Camera can not switch off
My DSC-P150 refuses to switch off completely after pushing the on/off button. The screen shuts off for less than 3 seconds and comes back on. This has happened after a series of shots in a rather humid conditions. I have to get the battery off to stop the camera otherwise it will completely deplete the camera. I have tried teh reset button, but not to avail. It had happened to me before, also caused by some humidity, but always disappeared after complete drying. Any ideas? Thanks for suggestions
Camera: DSC-P150 Sony Cybershot 7.2 Megapixel
Problem: Camera wont turn off. It turns right back on a few seconds after I hit the power switch. The camera intermittently turns on by itself.
Solution:
I recently experienced the exact same problem. The solution is to remove the battery, and fully disassemble the camera. Start with a clean desk or table top. Have a tray ready to hold your screws they are very tiny. Do not loose them stores do not sell replacements. Your best luck to find replacement screws would be ebay. Have a good lighting these small detailed parts strain your eyes. Remove the 7 small silver Phillips head screws on the outside of the case. Separate the case carefully, and partially with your finger nails. Unplug the small electrical connector with 2 wires work it slowly back and forth with a small flat head screwdriver then gently pull on both wires. Slowly separate the case a little further so you can see what else needs to be unplugged. Proceed to remove the LCD screen and remaining screws. disconnect all of the tape style electrical connectors by gently twisting and pulling along the two outer tabs with a small flat head screwdriver. Work the connectors little by little back and forth with the screwdriver. Be patient and do not force anything or else it will break. If you get frustrated set the camera down and take a break for a while. Caution stay away from the flash area. This is the Shock Zone Danger! I repeat Danger! There is a battery looking thing probably a capacitor located near the flash. If you touch the contacts or tape connector on the contact side with the screwdriver or your fingers it will shock your pretty good. It is pretty hard to avoid especially because this connector also needs to be unplugged. Remove the camera into two halves.The trick to removing the connectors with no tabs on the sides is to flip up the black tab with your finger nail and pull the wire tape out with your fingers. Completely remove the circuit board from the camera. With an old, clean, soft tooth brush, and 91% Isopropyl alcohol scrub the circuit board clean so it is shiny new. Be sure to clean all of the connectors male and female as well as the wire tape contacts. Flip up those black plastic connector locks and clean those terminals. Corrosion build up from the moisture or water exposure caused this condition where the camera turns on a few seconds after you turn it off. Your goal is to remove all of that white, powdery, flaky looking corrosion. You may have to look closely but its there. After you have fully detailed and inspected your circuit board allow some time for these parts to dry. Use a can of compressed air to speed the drying time, and remove dust from other hard to reach areas. Use q-tips to clean the lens and view finder etc. Do not soak anything in the alcohol only apply a light amount to the soft bristled tooth brush and q-tip. Reassemble the camera very carefully in the reverse order. Be sure to put all of the screws back in there correct locations. There are only two screw sizes that you will be removing small silver ones and a little bit bigger black ones. Leave the black lens and motor assembly alone. After doing this my camera is 100% fixed. I hope this helps everyone out there resolve this issue. If you follow these directions and it works for you too please email me your results to abyssthought@gmail.com. Good luck to all.
Posted on May 05, 2009
    Sergeant:
    Champion:
  • 326 Answers
Hello, drying is the option that can not always cure the problem. The circuitry inside the camera is very sensitive to humidity & moisture. In your case I would advice getting a professional help from the technician with best references. In future please avoid the high humidity exposure or purchase a special case for this kind of use. If you need more info please advice
Posted on Apr 03, 2007
White screen , no image showing, no menu showing, no image in picture taking
if it takes a picture then it is a broken lcd screen... if it does not then it is a broken sensor and lcd screen... with the menu not showing that has nothing to do with the sensor just the screen.
Nov 12, 2012 | Sony Cybershot DSC-T50, DSC-T30, DSC-M2,...
We are a non-profit resale store and were donated a Sony Cybershot DSC-:150 camera but there wasn't an Instruction Manual. Where do I find one on-line.
Copy and paste this address into your browser to download what you need. http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCP150&LOC=3
Sep 02, 2010 | Sony Cyber-Shot DSC-P150 Digital Camera
Switches on and switches off immediately
I had the exact problem. After searching online for multiple solutions, the following worked for me... Press and hold the power button while at the same time use your fingernail to pick and pull at the lens assembly. Pull the lens assembly at the circular ring gap between the housing and the barrel of the lens itself. It only took me about 3 to 5 tries to get it to work. It's been working fine ever since. Good Luck.
Jun 14, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
My less than 2 year old sony dsc-w100 keeps powering off and on
my only idea would be that the power button is glitching out...anything in the manual about this?
Jan 22, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Its not a camera its a electronic dictionary
The cracked LCD itself can not be fixed, however a replacement LCD is always an option.
They are fairly cheap, running around 40-50 dollars.
Here is a link to one on eBay -
http://cgi.ebay.com/Sony-DSC-P100-P120-P150-Digital-Camera-Parts-LCD-SCREEN_W0QQitemZ250125094940QQihZ015QQcategoryZ64352QQcmdZViewItem
Hope that helps!
Nov 17, 2007 | Sony Cyber-Shot DSC-P150 Digital Camera
Sony cyber shot DSC-W1 Digital Camera
I found an online manual for your camera. Page 84 talks about the USB Mode Normal with the 4 dots underneath. It also show a troubleshooting area for this and it is on page 96. Hopefully this will get your camera working right again. Here is the link to the pdf manual. http://www.docs.sony.com/release/DSCW1.pdf
Aug 25, 2007 | Sony Cyber-Shot DSC-W1 Digital Camera
Which memory stick ?
Several of the Sony cameras require a high speed memory stick for 640 x 480 30fps movies. Here is a clipping from the Sony P150 specifications: "MPEG VX Fine with Audio (640 x 480 at 30fps), (MPEG VX Fine requires Memory Stick PRO media)"
Sep 08, 2005 | Sony Cyber-Shot DSC-P150 Digital Camera
Sony Cyber-Shot DSC-P150 Digital Camera Logo
250 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
